Just over a year old. there is power to the unit
SOURCE: Whirlpool Dryer Model # LE7680XSW1
David,
You have a pretty old dryer. Replacement is recommended because new dryers use less electricity and more than make up for the price with the savings on your electric bill.
However, if you still want to use this dryer, you will need to replace some internal switches. In order to guide you through that I recommend you use our premium service.
If you need to find a local repair service, please type your zip code into our repair service search engin located on our site.
Good luck,
CH
SOURCE: Whirlpool dryer does not start and beeps.......
Same problem here, however I can assist the start by rotating the drum while pushing start. May be a capacitor problem???
SOURCE: whirlpool dryer won't heat how can I fix?
Hey, I just read an article online titled, Testing for 240 Volts to Your Dryer - Without a Voltmeter, here's the link http://www.davesrepair.com/DIYhelp/DIY240Vtester.htm
I am not sure how you could test anything else though, such as the thermal fuse or thermostat, without the Volt/Ohm Meter. They are about $10 at any big box home store--we just went ahead and bought one.
SOURCE: My whirlpool dryer heat up. But does not spin.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Check for belt on drum half way back on the drum running from left to right. If belt is missing or broken replace with part number 341241 later in this process.
Looking down inside dryer on left and right see a 5/16" hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Rotate front panel to right to get it out of the way watching to ensure wiring is not damaged.
Place new belt over drum groove side down if old one was broken. Check white idler pulley for free rotation before installing in holes of floor under motor pulley. Replace with part number 691366 if rotation of pulley is not free or if it appears worn. Loop belt with ribs inward and pass through the open space in the idler arm below pulley then pass loop over motor pulley rib side down. The configuration at the motor should now look like the Whirlpool model in the image below:
Belt and pulley configuration
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Reverse disassembly process to re-assemble.
SOURCE: Our Whirlpool Senseon Dryer stopped heating. It's
I had the same problem. I replaced the thermistor,heating element and another part and still didn't correct problem. i finally had a friend come check it and believe it or not it was the 30 amp fuse in my fuse panel of the house.Come to find out the dryer will run and everything works like it should on 1/2 of the 220 plug but the other half runs the heating element.Both fuses must be good. I replaced the 30 amp round fuse and it works and heats perfect. I hope this helps you and saves you some time and money.
Tommy
