1994 Jaguar XJ6 Logo
Anonymous Posted on Jun 03, 2009
Failing Instrument Module Jaguar 1994 4.0l Sovereign
I was driving along when I noticed all the dash warning lights flash on, a few days later they did it again I noticed that they went through the same cycle as when starting the car next time while driving the whole dash went dead and stayed so until I restarted the car.
Eventually the dash stayed dead so I have replaced it with a good unit (out of a 1994 4.0l) from EBay now the speedo does not work the rev counter only works up to 3000rpm the fuel gauge only reads half full when the tank is full but all other instruments and warning lights work as normal I have a 1994 Jaguar 4.0l sovereign vin69**** are there different instrument modules for that year? have I bought a bad module? Has any one the wiring info for this model's instrument plugs?
Peter
  • 1 more comment
  • Anonymous Jul 10, 2009
    Hi All
    This instrument module is finally fixed, having bought a spare which did not work properly I decided to
    check the differences with a voltmeter, first I removed my module then removed the shroud from
    the instruments pack(4 screws). Then the back panels from each module to expose the printed
    circuit boards, next I refitted the original instruments in the car,(on this module nothing works)
    and switched on the ignition.
    I assumed that there is an open circuit somewhere, so for simplicity I picked
    the two large blue axial capacitors and checked voltage at the positive end of both, one had battery voltage
    the other had 6 volts aha!. next I swapped instruments (on this module all warning lamps work normally
    the fuel gauge and rev counter works partially the speedo does not work) and again checked the blue
    capacitors at positive terminals both had battery voltage Eureka!!! Swapped over instruments again and
    fitted a jumper cable to link both positive terminals and the instruments came to life and all was working
    allthough my finger holding the jumper in place got a bit warm!. Next I removed both printed circuit
    boards from the instruments then placed a large plastic bag over the hole in the car dashboard area,
    and through 2 holes I had made in the bag pulled the wiring plugs (this for safety). and connected
    the original circuit board back into place.
    Now it was a simple matter of tracing the circuit from the capacitor positive terminal back to the
    power input at the smaller plug fitted at lefthand end viewed from drivers seat.
    (with lights off and key to ignition-on there are only 2 terminals live ) I was looking for a component with
    batt volts on one terminal and 6 volt at the other(the IC chips where beyond my capabilities to test so
    were ignored) the first was marked R100 so was swapped no good, the next was marked 1N4 004 when I
    swapped it out I had batt volts at both pos terminals on the blue capacitors, I rebuilt the module and
    refitted it into the car and all is good.
    This required patience and perseverance swapping PCB's after each test took time,
    I also started as close as I could to the source of power to the board.
    The faulty part is marked 1N4-004 and I think is a diode.
    Look here for module removal instructions
    Peter
    Hi All
    Peter
  • Anonymous Jul 12, 2009
    This problem is solved
Anonymous
Level 2:
  • Expert 103 Answers
  • Posted on Sep 29, 2009
Anonymous
Expert
Level 2:
Answers
103
Questions
0
Helped
37591
Points
237
Colin Stickland
Level 3:
  • Jaguar Master 22,516 Answers
  • Posted on Oct 31, 2009
Colin Stickland
Jaguar Master
Level 3:
Answers
22516
Questions
Helped
6990262
Points
66324
Havent a clue to be truthful ,have the same model myself and it came with a workshop manual,but i have to get ready to go out now because we have GUESTS ,,,,one of the benefits of living in spain --everyone wants to come and see you ,free holiday more like.,Tomorrow i will try to copy the wiring diagram with the scanner but trust me it doesnt tell you a lot .Block connector with no colours or numbers .More like guarding trade secrets,must go getting yelled at ----
Why does 03 Jaguar S-type not try to turn-over now when it jump-start fine a few days ago?
Using the key FOB, turn off the alarm/unlock once the jumper cables are attached and then try to start.
Warn light box on theright side of dash don't show any simbols ie door open, seat belt not fitted etc but flashs amber.
the common prob with old xj40 with odd readings on insrument pack is bad connection inside the pack itself with good eyesight carefull dismantling and a soldering iron it can be fixed
1helpful
Mercedes C180, 1996 saloon. All brake warning lights on dash illuminated, and the speedo inoperative. Brakes work OK but no ABS.
Hi. Thanks for your question. For issues related to brake warning lights on dash illuminated for Mercedes C180, 1996 saloon. You can visit https://www.reliable-store.com and download the entire workshop manual which includes all the information along with the diagrams for better understanding. Good day!
Need a fuse diagram for a 99 Torneo
Sounds like the ignition switch going bad.
My dash bored wont stay lite at night with my lights on in my 1992 Buick
There are few help links provided to resolve this issue of dash board light not working.Click the link below to go through its procedure:-----Dash board lights not working? http://repairhelpcenter.blogspot.in/2012/02/dash-board-lights-not-working-on-gmc.html
----------- light in the dash blinks? http://repairhelpcenter.blogspot.com/2012/01/overdrive-light-in-dash-blinks.html
-----------Orange O/D warning light flashing on dash? http://repairhelpcenter.blogspot.com/2012/01/orange-od-warning-light-flashing-on.html
---------gauge on the dash quit working on? http://technoanswers.blogspot.com/2012/01/temperature-gauge-on-dash-quit-working.html---------No 4x4 light on dash? http://repairhelpcenter.blogspot.com/2011/12/no-4x4-light-on-dash.html
----------Digital Dash Display not working? http://schematicsdiagram.blogspot.com/2011/12/cadillac-seville-digital-dash-display.html
---------warning on dash and alarm sounds? http://schematicsdiagram.blogspot.com/2011/12/chevrolet-tahoe-hood-open-warning-on.html
---------Light Stays On dash of car? http://schematicsdiagram.blogspot.com/2011/06/brake-indicator-light-stays-on-dash-of.html
----------The ABS and Traction Control Lights stays ON dash of car? http://schematicsdiagram.blogspot.com/2011/06/abs-and-traction-control-lights-stays.html
----------warning lights remains steady on dash? http://schematicsdiagram.blogspot.com/2011/12/abs-brake-warning-lights-remains-steady.html
---------light bulb under dash replacement?
http://schematicsdiagram.blogspot.com/2011/12/heating-knob-light-bulb-under-dash.html
Parking lights, tail lights and dash lights not working? http://technoanswers.blogspot.com/2012/01/parking-lightstail-lights-and-dash.html
How to replace Instrument panel and dashboard?
http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-instrument-panel-and.html
Tail lights and dash light fuse keeps blowing? http://technoanswers.blogspot.in/2012/02/tail-lights-and-dash-light-fuse-keeps.html
This will help.
Thanks.
Hi there; I've just started getting a "parking
The most basic check for this is - is your battery up to 100% efficiency. the handbrake module is notorious for faults with low voltage or voltage dips. Next is to check that the brake pads and cables are free and in good condition (pads not worn too far down) as these can cause fault indications. The fact that the park-brake still works and does not jam on or off would indicate that the major components are still working and may just need some attention and recalibrating. T o try a recalibration of the park brake - disconnect your battery for 10 Min's (make sure you have your radio code as this will be needed on reconnect) when battery reconnected follow the instructions on your driver display panel and see if this improves your problem. hope this helps - good luck.
Warning lights
have obd  scanner run on vehicle
9helpful
4answers
Instrument panel went dead
Checked Every fuse in the fuse box (no small task).This includes #4 - Power point Instrument Panel, #14 - Day time running lamps (auto lamps doesn't work nor does auto lock), #27 - ignition switch run feed, #35 - Instrument Cluster, #41 - Instrument Cluster, #42 - Delayed Accessory, #45 - Ignition switch run/start feed, #102 - Door locks body security module, #103 - Ignition switch, #110 - Ignition switch, & #116 - Ignition switch. But I also check all other ones as well, they all register OK. AC panel & radio work. Turn signals work. Mileage does not work, trip computer does. So, basically, everything works except auto head-lights, auto locks, and the dash cluster (no MPH, RPM, mileage display, Fuel, Temp, Tran Temp, and Oil Pressure).
Instrument lights won't turn off
hi,seem lighting switch is grounded or wiring for cluster is grounded,if can remove the lighting switch disconnected the wire,see if light in cluster is off,switch or wiring must check,ty
Top Jaguar Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Jaguar Expert? Answer questions, earn points and help others
