Question about Konica Minolta magicolor 2300DL Laser Printer
Drops offline. power off unit. unit stays on line for about 10 minutes then drops off. can't ping at these times. pretty much every time you print you need to power off then on.
    Scholar:
  • 52 Answers
Hi, Is it possible for you to use it with a different connection (usb, parallel or network) and see if anything happens Also try to remove the memory from the printer if you have an easy acess to it. Then try again (or move the momory to an other slot) Last thing i would try is to do a cold reset (see manual on how to do this) or ask Minolta tech support. Otherwise i would suspect a logic board/power supply issue.
Posted on Jun 03, 2009
Hp 2420 offline error
Upgraded all jetdirects to their latest firmware, DOWNgraded any jetdirect J7949E on firmware v33.15 to v33.14 (.15 is horribly broken and crashes after a couple of minutes usually).
I have enabled SLP protocol on all the print servers, I have then telneted into the jetdirect to set slp-keep-alive (available with the firmware updates) to a value of 2 (2 minutes between slp anouncments).
I have changed the MAC age time on all the switches to 900 seconds from the default 300.
Jetdirects now announce themselves every 2 minutes stopping the switch forgetting that they exist. I have added a logoff-period of 1800 seconds to a single port with a Xerox printer on it which stops it reauthenticating every 10 minutes (unable to change slp interval on it).
This may or may not help, but I've had the printers on line for the last week now and when I ping, they are still there!
Jul 22, 2012 | HP LaserJet 2420 Printer
My daughter is at college and called me. Her printer won't print and it says offline in the control panel. Its a brother mfc 255 cw
Your going to laugh when you see how to fix this! At least I did the first time it happened to me.
Open a document that you want to print. Go to the top of the page and find where it says "File". Click on file and follow the drop down list almost to the bottom where it says Work Offline. Click on Work offline and this will put your printer back on line and able to start printing again.
Sep 30, 2010 | Office Equipment & Supplies
MY LEXMARKX5650 THERE IS A DOCUMENT STUCK IN MY QUEUE. IT SAYS DELETING BUT IT DOESNT DELETE I CANT PRINT MY OTHER DOCUMENTS I REALLY DONT WANT TO HAVE TO RESTART THE PC IHAVE A FILLED IN DOCUMENT THAT...
Disconnect the printer from the computer. Open the print queue, and be sure that the title bar says "printer offline". If it doesn't, select "use printer offline" from the file menu. Then try to delete the file multiple times if necessary to clear the queue. You may have to reboot the computer, but try this first. Also, you can try pressing cancel on the printer itself. If none of this works, disconnect the printer from power for 10 minutes, and try again. Good luck!!
Sep 29, 2010 | Lexmark X4650 InkJet Printer
The printer is shown as offline on print server why ? !!
see if u can ping it 1st.Go to run type cmd then enter.Type ping then space and the ip address of the copier if u get time out then there is a problem with your network or u running dhcp and your server assigned different ip to your copier
Apr 01, 2010 | Toshiba E-Studio167 Copier
Ir c3200 is offline
Check that network settings are still correct in system settings. If they are then power down the machine for 10 seconds and restart it. Wait for 10 minutes to see if it comes online. Try pinging it from a pc on the network to see if it can be seen - to help determine if there is a faulty network card in the machine. Pinging means entering the DOS screen and typing 'PING (SPACE) 'IP ADDRESS OF MACHINE' then enter.
You should get some response if it's connected ending with a number like TTL225 etc. Check that there are no error messages on the machine itself causing it to force itself offline.
Nov 09, 2009 | Canon imageRUNNER C3200 Copier
Window 1.5 AC Problem During Day
Chack size of wire. Should be at least number 10 wire. Check loose connections. Call power company to check your voltage. This time of year in different parts of the country they have brownouts which is a voltage drop becaus of the load on the lines. Have power checked. Rus
Jun 15, 2009 | Heating & Cooling
DURING DAYTIME WHEN HOT OUTSIDE 35-40 DEGREES C, AC TRIPs off
units are not able to work properly above 90, 1.0 T not go for more than 1 room. is outside of unit clean? if not turn off power to unit then spray 409 or simple green or something along those lines of cleaners on the coil part (soak it real good) it should cover entire coil as much as possible. let cleaner sit on it for about 10 minutes then use water hose to rinse as good as you can. wait about 10 minutes then try unit - so work better.
Printer is offline
Press the most left button at the printer front panel.
May 06, 2009 | OKI Pacemark 3410 Matrix Printer
Gateway 3550 Internet shuts off every 10 minutes
I have a gateway laptop with Vista that does the same thing.
In the control panel/power settings, ID what power scheme you are using.
I found that when on power saver mode the wireless and CPU were throttled down to conserve power. In Vista you can adjust these up to max power while keeping the other features on the default power saver settings. It improved the dropped connections dramitically. To end the finger pointing I signed up for connection monitoring using DSL reports (DSLreports.com) This service sends a ping to your modem every 10 minutes and charts your ISP uptime. Using this service I was able to determine that it was not my ISP.
Good luck.
Nov 07, 2007 | Gateway 3550GZ Notebook
Canon MP 600 Will Not Turn On .... grumble.
I had this same issue. Lost power in the house for just a second, but after the printer would not turn on. I think that the loss of power caused the printer to get stuck in a locked state. Tried everything I could think of including changing outlets that the printer was plugged into but nothing seemed to work. Saw a troubleshooting tip on the Canon webpage about unplugging the unit for 5 minutes and thought it was hooey, but tried it anyway. Ended up leaving the unit unplugged for probably 15 minutes and when I re-plugged it in it fired right up.
Oct 09, 2007 | Canon PIXMA MP600 all-In-One InkJet...
Konica Minolta magicolor 2300DL Laser Printer Logo
180 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
