Question about Philips Televison & Video
My picture is like a 3d look. I can't adjust the
My picture is like a 3d look. I can't adjust the picture. it is blurry
    Genius:
  • 1,239 Answers
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ... thank u.........
Posted on Jun 03, 2009
Samsung 55" blurry picture and words are blurry...netflix comes in perfect...whats wrong
Is it a 3D TV. Try changing the refresh rate in the Picture Menu 60HZ is normally the standard but try others. Or if you're TV has Auto Motion Plus options you try turn it on it can be found in your television's menu under Picture Options. The Auto Motion Plus menu contains several options, including On, Off, Clear, Smooth and Standard. If changing your Auto Motion Plus options doesn't correct blur, call Samsung.
Jan 24, 2015 | Samsung Televison & Video
My rca hdtv has a 3d look, and it is blurry, what can i do
this 3d look is coused by bad convergance ics you have to replace them no adustment will fix this
Dec 24, 2007 | RCA HD52W59 HDTV Projection Television
Blurry picture
By focus is the set looking 3d etc--called a convergence issue---if so go into the menu with the Mitsubishi remote and see if it will adjust---if off and will not adjust in some area of the screen the set needs the convergence chips replaced.
If convergence is good and not the issue describe the problem a bit more----these sets have 3 picture tubes with lens---from rear of set (safest way) the lens can be cleaned with a lens cloth---dust on them will make the picture look darker and dull looking and usually is done one time a year--do not try to adjust anything until you try this first.
Nov 05, 2012 | Mitsubishi WS-48311 48" Rear Projection...
Really blurry
Look in main menu for convergence and see if it will adjust--if off either adjustments or a bad chip---picture will look 3d and red or blue outlines around lettering etc.
Oct 22, 2012 | Toshiba 61H70 61" Rear Projection...
Picture is blurry, out of color and the letters on tv look like 3D
If you can`t adjust your convergence via the menu then you have a faulty digital and/or analog convergence board
Oct 30, 2009 | Sony KP-53HS10 TV
Pictureis blurry and bottom of screen is wavey
This is a common problem. Your convergence has gone out.
Common symptoms are...
1) 3D Video
2) Warped Video
3) Convergence menu does not adjust the red or blue correctly.
Go here for a solution...
http://www.fixya.com/support/r2861627-updated_convergence_problems_amp
Sep 06, 2009 | Televison & Video
Blurry vision on picture
This is a very common failure on Projection TV sets.
Screen looks 3D
Colors don't line up
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed or warped.
You can see some example photos and find a solution here...
Sep 05, 2009 | JVC AV-48WP30 48" Rear Projection...
3D blurry picture
The convergence ICs and resistors need replacement. The DPTV305-345 convergence repair kit works for most Phillips rear projection Tvs. The kit contains the two ICs 12 resistors and the CD with detailed instructions
http://www.tvrepairworld.com/
Jul 22, 2009 | Hitachi 43UWX10B 43" Rear Projection...
Looks like 3D Picture
You probly have a convergence cicuit failure. Replacing the convergencr IC's will probly fix it.
I recommend a professional repairman to
do it though. Particularly if it needs further adjustments after the IC's are replaced.
Jun 16, 2009 | JVC AV-48WP30 48" Rear Projection...
Picture is blurry
remove front panel and check the 6 control knobs adjust the intensity of each color as well as the focus of the picture with those colors.be sure to mark the knobs so you can return them to there original position if the set shuts off. Good luck
Jan 28, 2009 | Hitachi 51F500 51" Rear Projection...
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
