Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker motor not working - Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
  • magicofseatt Jun 03, 2009
    ice maker motor not working
  • 34 Answers
If it is stuck or not working at all
If it is trying emptyu the ice bucket in to a bowl or something
Then put it back and using a cup pour hot water over the ice that is trying to be pushed out the will free the jam
Then using paper towel try to take out as much water from the ice tray
It should start working
Posted on Jun 06, 2009
5 Suggested Answers
  • 219 Answers
SOURCE: ice maker not working
could be watervalve icemaker or sensor boards try valve first
Posted on Mar 19, 2009
  • 744 Answers
SOURCE: ice maker won't work
If you are sure that power is getting to the ice maker unit inside the freezer and you're sure that water is available for the ice maker...
Try these next steps:
Follow the water line for the ice maker back to the ice maker water solenoid
Follow the wiring from the water valve to its source - either a timer or circuit board
Check the timer and/or circuit board for any bad connections, burned connections and power to the board or timer. This arrangement can vary by refrigerator model number...
Posted on Apr 11, 2009
  • 136 Answers
SOURCE: ice maker is not making ice...no water to tray
there may be a sensor in the bin where the ice cubes drop into. It tells the ice maker when the bin is full so it stops making ice. Check to see if that sensor got bumped or moved or needs to be reset
Posted on Jul 07, 2009
heatman101
  • 43501 Answers
SOURCE: The ice maker has stopped working, the motor is co...
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Posted on Sep 30, 2010
GE Profile Model PSS26LGSC Ice maker not working
Did the ice buildup appear to resemble the water overfilling the top of the ice maker? The only thing that I believe that may work is removing the ice maker, clean the excess ice buildup.dry and reinstall the ice maker and see it works. If the ice is above the normal level the ice can cause the motor that pushes the ice out of its slots to strain more than the gears or motor can handle stripping the gear or damaging the motor beyond repair, When harvest takes place the first thing that happens is a heater below the ice maker warms the cubes a little just enough to allow them to slide out of their slots and fall into the ice bin. The ice make for your model does not have replaceable parts and if bad or damaged it is less expensive and time consuming to by a new ice maker. If the water fills above the top of the ice maker it is usually the fault of the water control valve not closing all the way once it fills the ice maker after each harvest. Did water refill the ice maker when you cleaned it? Did the water overfill after you cleaned out the ice maker? What I am asking is water over filling ice maker again after you cleaned out the excess ice? If the water continues to flow from the WR57X10032 Water Inlet Valve
Apr 07, 2013 | GE Refrigerators
I'm considering on purchasing anice cream maker.How does the ice cream maker run?
There are four main ways on how ice makers operate; 1.Manual Ice Cream Maker. If you have a way to keep the icecream frozen, you can make it anywhere - even outside on a picnic. It is nostalgic - this is how ice cream was made in the past. Results are less consistent and it invovles hard work. 2. Electric Ice cream Maker ; Motors might wear out because of work load on motor.Some models have safety features to prevent motorburn-out.
Aug 12, 2010 | Kitchen Appliances - Others
heatman101
May 20, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker is not working.
Ice maker has built in thermostat that turns cycle on at around 10 degrees F. If freezer temp does not reach that point the ice maker will not cycle. So either the freezer is not cold enough or the thermostat is faulty.
Make sure that the ice maker motor that turns the cams and controls the various stages is also working.
Apr 08, 2017 | Frigidaire 20.6 cu. ft. Top Freezer...
My ice maker wont dispense the ice that is in the tray, the water works fine
You either have a bad ice maker thermistat which is mounted between the motor modualand the ice maker mold or a ice maker motor modual on the newer models, or could have a stripped gear on the older models.
Mar 02, 2010 | Refrigerators
Ice maker dispencer motor won't spin. You can hear a click, and the ice dispenser light dims. The water dispenser works fine.
Best solution is to replace the ice maker. The ice makers are a cheap item and very hard to work on. It is easier to replace the ice maker rather than trying to take it a part and replaced the motor or gears. If you do want to take on the project you have to remove the ice maker and check the gears for a worn spot and the motor to see if it is still running. Parts can be purchased at a local appliance dealer. In tulsa we have Greers appliuances.
Nov 15, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker repair and still no ice
  • The refrigerator has a duel water valve, one for the ice-maker and one for the water dispenser . The valve that the ice-maker relies on may be bad,
  • or it could be the ice-maker itself.
  • Another thing that could cause it would be the temperatures in the freezer. The ice-maker will not call for water until it reaches under 15 degrees.
  • In addition, check the water tube behind the ice-maker to make sure it is not frozen, blocking more water from entering.
  • Note: The water does not go to the ice-maker or thru the filter unless the ice-maker turns on the water valve.
btw- you can replace the whole icemaker system for around  $115.00.
  • charging you $250 for a $20 drive motor is ridiculous! my 12 year old son can change the drive motor in 15 minutes.
Jul 06, 2008 | Refrigerators
Ice Maker
PLEASE CLARIFY THE TERMS "MOTOR", "ICE MAKER SWITCH" AND "ICE TO COME OUT"
FAN MOTOR? COMPRESSOR? AUGER MOTOR?
ICE MAKER ON/OFF SWITCH? DISPENSE SWITCH? DOOR LIGHT SWITCH?
ICE TO COME OUT OF THE ICE MAKER? ICE TO COME OUT OF THE DISPENSER? ICE TO COME OUT OF BIN?
Feb 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker does not dispense cubes
THE SOLENOID IN THE ON THE ICE MAKER MOTOR IS NOT WORKING IT HAS ICE BUILD UP ON IT OR IT HAS A SHORT IT PULLS THE PLUNGER THAT OPENS THE FLAP THAT LET ICE CUBES FALL OUT. REMOVE ICE MAKER AND THER ARE 2 5/16 SCREWS THAT HOLD PANEL IN THEN UN PLUG MOTOR AND USE HAIR DRYER & DEFROST MOTOR AND SOLENOID SHOULD WORK IF NOT MAY NEED TO REPLACE SOLENOID.
Dec 22, 2007 | GE GSS20IEP Side by Side Refrigerator
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
195 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
