Question about Philips PSA232 (512 MB) MP3 Player
Philips PSA232 SD Card Problem
I have a Philips PSA232 512MB with a Mini SD expansion slot. Whenever I plug in a Mini SD card, it displays the message "SD card problem." When I hook it up to my computer and try to repair it with the included Philips software it says it cannot read the device.
I have two different cards: a 4gb and a 1gb micro SD that I plug into a Mini SD adapter card. Could this be the problem? Do I need to use an actual Mini SD card (with no adapter).
It works fine without the Micro SD card plugged in.
Thanks for the help
SOURCE: Philips GoGear 512mb
I'm not sure about the Memory Format Error, but you are going to need the software to not only recharge the player, but put music on it as well. To turn it on you have to hold down the play button until you see a little "Philips" logo pop up on it. I looked into downloading the upgrade to see if it could recharge that way, but it seems to be only what it says it is; an upgrade. I suggest you ask your husband's friend for the software disk.
Posted on Sep 21, 2007
SOURCE: Not working.
I have no charge in my philips hdd82 player. Usually I just plug it into my computer via usb and a screen shows up on the player showing its connected and it charges. Usually it comes up as an MTP device on the computer so I can add mp3s as well. Now for no reason at all, when I plug it in, it doesn't charge and the computer doesn't recognize it. The screen shows an outlet when I plug it in so I know the cord works. It just won't let me do anything. When I press the on button with the cord unplugged, I can't do anything either b/c no charge. HELP. plz.
Posted on Dec 16, 2007
ThaMp3Doctor
  • 8596 Answers
SOURCE: SAMSUNG YH920GS- Error Message- device cannot initialize hdd
You are missing a critical update from Microsoft that will allow the computer to recognize this as an MTP device rather than an MSD device - this is a new problem that did not exist before.
Try a firmware upgrade, but it may not be successful since the repair was unsuccesssful.
Otherwise, get all the most recent Windows Updates from www.microsoft.com.
If none of the above work, write me back.
-Tha Mp3 Doctor
Posted on Feb 11, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: GoGear SA261 - not accessing the mini SD card
The GoGear is only compatible with certain types of SD cards. check the Philips website - product information link on SA261 page for specs on which cards are compatible.
-Tha Mp3 Doctor
ThaMp3Doctor
  • 8596 Answers
SOURCE: Philips GoGear memory error
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
What do i buy so i can attach my digi power dp-fcr20/ mini sd/ms duo card reader/writter so i can attach my mini sd to it and sorry if hard to understand
If the card-reader states it's for a mini-sd card, then you should just be able to insert the mini-sd card into one of the slots. However, some card readers double-up on slots by making it so more than one card-type can be inserted into the same slot. See if the mini-sd card can be put into one of the slots successfully. Tip: Read your manual before doing so, so you don't get card stuck in wrong slot.
Mar 31, 2011 | Computers & Internet
Ga3400 reports 384 meg of ram
hello, that sounds right because the system you are reffering to is an "Everex IMPACT GA3400" by default this 512mb of RAM but 128mb of it is shared for your video card hence leaving you with 384mb.
below are specs for your sysem:
Processor
  • 1 x AMD Athlon 64 3400+ 2.2GHz
    Bus Speed
  • 1600MHz
    Cache
  • 1MB L2
  • Memory
    Standard Memory
  • 512MB
    Maximum Memory
  • 2GB
    Memory Technology
  • DDR SDRAM
  • Storage
    Hard Drive
  • 120GB Ultra ATA 7200 rpm
    Optical Drive
  • DVD-Writer (Double-layer) - DVD?R/?RW
  • Controllers
    Controller
  • Ultra ATA
  • Display & Graphics
  • Graphics Controller
  • nVIDIA GeForce 6100
  • Audio
    Sound Card
  • Included
    Speakers
  • Included
  • Network & Communication
    Network
  • 10/100Mbps IEEE 802.3u Fast Ethernet
    Modem
  • 56Kbps Data/Fax Modem Integrated
  • I/O Expansions
    Expansion Slots
  • Flash Memory Card (1 Total)
  • Input Devices
    Keyboard
  • Included
    Pointing Device
  • Included
  • Interfaces/Ports
    Ports
  • 1 x Audio Line Out
  • 1 x Microphone/Line-in
  • 6 x 4-pin Type A USB 2.0 - USB
  • RJ-45 Network
  • 1 x RJ-11 Modem
  • 1 x VGA
  • 1 x 6-pin mini-DIN (PS/2) Mouse
  • 1 x 6-pin mini-DIN (PS/2) Keyboard
  • 1 x IEEE 1284 Parallel
  • Software
    Operating System
  • Windows XP Home with SP2
    Software Included
  • CyberLink Power DVD
  • CyberLink Power2Go
  • Norton Internet Security
  • i would recommend that you visit crucial.com or newegg.com for memory upgrade which will improve your new PC's experince.
    hope this helps,
    good luck,
    regards,
    Amar Sondhi
    Dec 06, 2009 | Everex GA3400 Refurbished AMD Desktop...
    My mini sd card is in raw format and my computer can't read it - how do i change it back to fat file system ?
    1. Place the mini-SD card within the mini-to-SD card adapter. Make sure the tab on the mini-SD is facing the upper side of the adapter. Slide it in slowly, being careful not to damage the pins.
    2. Slide the adapter in an SD slot on your computer. If you do not have an SD slot, place the adapter in a USB card reader, and plug that into a USB slot on your computer. Give the computer time to read the card.
    3. Open "My Computer" (usually located in your start menu) and navigate to your mini-SD card. It will usually be recognized as a drive such as "E:" or "H:."
    4. Right-click on the drive and select the "Format" option. A menu window will open.
    5. Make sure that the drive size is set correctly, and that it is set to the file system you wish to use (usually FAT32 on an SD card). If you don't know what file system you should use, just leave it at the default setting.
    6. Enter a volume label, which is the name for the drive, then press start. This process should only take a few minutes.
    WARNING
    • Do not use the "Quick Format" option unless you have just recently formatted the mini-SD card. "Quick Format" doesn't completely erase all data and is not effective unless used after a full format.
    • When you format your mini-SD card, all of the data on it will be erased. Make sure to back up your files on the card before formatting
    Sep 25, 2009 | Electronics - Others
    SD card does not seem to fit in the SD card slot
    Is the SD card a mini type or a standard SD card?
    The standard SD card is 24mm wide X 32mm long.
    If it is a mini SD card you need to purchase a mini SD to standard SD adapter, then you will be able to insert it in your Compaq.
    Aug 13, 2009 | HP Compaq nc6230 Notebook
    I have a T-Mobile G1 with a micro sd card; trying to sync??
    most mini sd cards come with a full-sized sd card adapter that the mini slips into. You can then slip that in your computer if you have an sd slot or sd reader.
    You can also buy very inexpensively, a usb port mini sd reader that you can plug directly into your usb port on your computer. Then after you'v dragged and dropped the files, you can put the mini sd back in your phone.
    Jun 16, 2009 | SanDisk 2GB microSD Memory Card
    Sandisk Adapter Problem in a HP Laptop
    If you install SP3 it may work as SP3 updates the index parameters for file size limitations within such an old OS.
    Oct 11, 2017 | Electronics - Others
    Palce where to insert sim card
    It's not a phone. It's a pocket PC.
    CAUTION: For synchronization to work properly, install Microsoft
    ActiveSync on your personal computer before you connect your
    iPAQ Pocket PC to your computer.
    To install a CompactFlash (CF) or Secure Digital (SD) card into
    an expansion slot on the iPAQ Pocket PC:
    1. Locate the appropriate slot on the top of the iPAQ Pocket PC.
    To identify slot locations, refer to the Getting Started
    document that came with the iPAQ Pocket PC.
    2. Before inserting a CompactFlash (CF) card into the CF
    expansion slot, pull the plastic slot cover from the CF slot.
    3. Insert the expansion card into the appropriate expansion slot
    and push the connection edge of the card firmly into the
    expansion slot.
    ✎If your expansion card is not recognized, follow the card
    manufacturer’s instructions to install it.
    ✎For more detailed help, refer to the Help files installed on your
    iPAQ Pocket PC. From the Start menu, tap Help > Connections.
    ✎To prevent power loss, remove any expansion cards from either
    the CF or SD expansion slots before turning off the iPAQ
    Pocket PC.
    44bf6e2.jpg Your iPAQ Pocket PC supports 802.11b Wireless LAN (WLAN) technology using the expansion slot in the top of the device. Figure 1: Expansion slot c00059391.jpg To make your Pocket PC a WLAN device, you need:
    • To purchase a WLAN CF or SDIO expansion card
    • To have access to a wireless network
    Dec 29, 2007 | HP iPAQ H2215 Pocket PC
    VX8300 - inserting the extra memory card
    On the right side of the phone there should be a MINI SD slot (it has a cover that says MINI sd on it .. open that up)
    The smallest card in your pack is the card that goes into the phone... it goes in "upside down" with the copper teeth facing UP
    Trying to put it in the other way will make it go in all crooked
    Dec 20, 2007 | LG VX8300 Cellular Phone
    Expansion card doesn't stay in.
    Problems inserting expansion cards, or keeping them in your device, may have a simple solution. Try these first: * Make sure the expansion card is facing the correct way. See the handbook for your device for illustrations. * Expansion cards do not fit into the slot if not oriented properly. If a MultiMediaCard (MMC) slides all the way through, it does not operate correctly. Make sure to fit cards carefully in the slot. * The mechanism of the expansion slot is called "push-push." Much like a glass cabinet door, you push to insert the card, and then push it in again to get the mechanism to release. Expansion cards do not need to be forced out of the expansion slot. * Though most expansion cards are notched at the top for removal with a fingernail or other such object, removing the card this away may damage the mechanism. Use an object only when a push fails to release the card. Please be aware that you could damage your handheld if you remove a card improperly, or insert objects other than expansion cards into the slot. * Expansion slots damaged by forced removal of the card do not release the card when pushed, and could refuse to ?lock? the card in the slot. Expansion slot damage can only be repaired by having the entire handheld serviced. * Some expansion cards labeled as SD or MMC do not actually conform to the SD or MMC specification.
    Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
    Philips PSA232 (512 MB) MP3 Player Logo
    47 people viewed this question
    Top Philips Audio Players & Recorders Experts
    Gyula Lacz
     Grubhead
    Grubhead
    Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
