Question about Brother DCP 115C All-In-One InkJet Printer
I have machine error AF on Brother DCP115C
Printer suddenly stopped mid way through page and displayed "unable to initiate" followed by "machine error AF". Does anyone know how to remove the error code?
Mix-it-up
  • 832 Answers
SOURCE: Brother Mfc 420cn says machine error AF
Open the small cover that hides the scanner flat cable. It has to be reconnected to the main pcb.
Posted on Oct 23, 2007
robotek
  • 1512 Answers
SOURCE: dcp115c brother unable to clean
Hi willjenks
Here is the procedure to reset the printer.
1. press the Menu & Mono start keys. next press the up arrow key 4 times to make the machine enter the maintenance mode.
2. Enter 8 & 0 by using the up arrow key & SET keys.
3. press the mono start key several times untill the purge count appears on the LCD.
4. enter 2 7 8 & 3 by using the up arrow key & set keys to reset the purge count to zero
5. press the stop/exit key to return to the initial stage of the maintanance mode.
6. enter 9 twice by using the up arrow & set key's to exit from maintenance mode
If you still have problems, post back to me here and we can go further. Thanks for using FixYa, a FixYa rating would be great for this info. Cheers :)
regards
robotek
Posted on May 08, 2008
BROTHER INTERNATIONAL
ATTENTION: CoDEC0012 "JOHN" email oblacks_pit@yahoo.com
UNABLE TO CLEAN?
1. TO ENTER MAINTENANCE MODE: PRESS MENU, MONO START, 4X ON ARROW UP (WITHIN 2 MINS)
2. USING ARROW UP BUTTON LOOK FOR THE FOLLOWING
a> 8 then press SET
b> 0 then press SET
3. USING MONO START, JUST PRESS IT UNTILL THE WORD "PURGE XXXXX" COMES PUT.
4. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING: "FLUSH"
A> 2 THEN PRESS SET
B> 7 THEN PRESS SET
C> 8 THEN PRESS SET
D> 3 THEN PRESS SET
THIS IS TO RESET THE PURGE COUNTER
5. USSING ARROW UP BUTTON LOOK FOR THE FOLLOWING
A> 0 THEN PRESS SET
B> 1 THEN PRESS SET (TO RESET UNIT)
C> 9 THEN PRESS SET
D> 9 THEN PRESS SET (TO EXIT MAINTENANCE MODE)
THAT'S ALL FOLKS JOHN
Posted on Aug 15, 2008
SOURCE: Unable to clean error on Brother DCP115C
MY bROTHER DCP-115C Always says Unable to clean see trouble shooting and routine maintenance at Users Guide, i want only a guide to reset my printer so that could be able to clean by itself
thanks,
Mr, Elpidio Concepcion
Posted on Jan 02, 2009
cene765
  • 787 Answers
SOURCE: my printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Machine error 50 is a error in Purge unit.You can't fix it by yourself and your printer need service.In most case the cost of repair is more than cost of new printer.
Posted on Nov 03, 2009
Unable to Init. AF in brother mfc 64900 cw printer
initial error AF, check the scanner flex cable or any cable, either they are not fix or not intalled properly..
Jan 28, 2014 | Brother MFC-5440CN All-In-One InkJet...
Just bought Brother Printer dcp-j125,After test copy machine says,machine error af. Removed elec cable,plugged back in ,held menu for 15secs.. machine error af,came back on..it makes a funny noise.
Brother DCVP-J125 manual reset
1.plug the power cord while holding the menu with in 16 seconnds to make the machine enter the maintenance mode.
just follow the steps and hope you can do it......
I try it to my self before i post it and shared to others....thnx and GOD BLESS by Harry Technician.
Mar 12, 2011 | Brother MFC 420CN All-In-One InkJet...
I am facing the problem of clean unable 46 and clean unable Af please give me solution
The error message "Clean Unable 46" is an indication that the machines ink absorbers are full or almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Clean Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Dec 17, 2010 | Brother MFC-290C Printer
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
My printer brother DCP115C ''UNABLE TO CLEAN error code 50''
Nov 03, 2009 | Brother DCP 115C All-In-One InkJet Printer
Keeps wanting to initialize unable to use fax function
My 'BROTHER DCP115c' printer unable to initiate (error 4f). Please can you solve itfor me?
Nov 17, 2008 | Office Equipment & Supplies
Brother MFC-420CN
press menu then start b/k copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press start b/k copy: What two digit error code does the machine display? Post here again.
To leave the maintenance mode press 9 then 9.
Mar 07, 2008 | Brother MFC 420CN All-In-One InkJet...
Oct 23, 2007 | Brother MFC 420CN All-In-One InkJet...
Mfc machine error AF
You have to fix the scanner flatcable on the pcb. Its disconnected :-)
Sep 25, 2007 | Brother MFC-210C All-In-One Printer
Will not initialize
Take it back to the dealer! Better do not fix that problem by opening the printer! If it is a second hand printer, write again here.
Aug 26, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother DCP 115C All-In-One InkJet Printer Logo
625 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
