Question about Dryers
Kenmore natural gas dryer model#110.6917721. Igniter comes on and burner comes on for about a minute and goes out. Burner will come back on in a few minutes and then go out. It will do this severalm times and then the igniter comes on but burner does not and after a few seconds the igniter will go off.
  • 97 Answers
Hello Friend, Your problem is very simple to fix. You're dryer needs a gas valve coil kit. To replace coils just remove front of dryer body and look below drum you will see the gas valve. The valve coils are located on top of valve (two little round black cylinders). It's simple, just remove the two screws from the little metal bracket that holds them down, unplug the wires from them and just lift them straight up off of the valve. Take notice that one has 3 wires and one has 2 wires. Just replace with new coils and plug wires back in and re-fasten metal bracket. Your dryer will run like new. Happy to help, Tim.
Posted on Jun 24, 2009
How do you convert to propane a kenmore elite model # 79671622310
You have to get the conversion kit. Mostly the burner gas nozzels has to be changed. Propane has a higher BTU value than natural gas. So the burner nozzle has to be smaller with propane.
You have to have the right nozzle kit for your dryer. Normally the propane nozzle kit comes with the new dryer. It is attached in a plastic seethrough bag and attached somewhere in the back of dryer.
Also you have to adjust the air opening in the burner for propane. Propane need more air than natural gas to burn properly. If you buy the conversion kit or find the conversion kit in the back of your unit, it will clearly give instructions how to do it.
Sep 26, 2014 | Dryers
Kenmore gas dryer 80series model 110.c72852101
if you hear the valve clicking but no gas the valve is bad.when the burner lights theres a probe that senses that it is lit and sends a microvoltage back to the controller to tell its lit.check to make sure all ground wires are grounded to a clean metal surface.
Oct 03, 2007 | Kenmore 74602 Gas Dryer
My. Drier. When. I turn it on the glow bar lights for a few seconds then goes out. What's wrong
The most common cause of a no heat problem on a GAS dryer is worn or blown igniter. These appliances are equipped with a burner assembly with electronic igniters. The following link explains a little theory about how these igniters work:
http://www.fixya.com/support/r401858-replacing_oven_igniter_gas_range
I know the link is for a gas range, but the burner assembly functions are nearly identical, as well as, the type igniters used.
If you are having ignition problems it is probably a simple matter of a weak or bad igniter. The burner assembly will ignite automatically as long as the gas valve, igniter coils and igniter are all functioning properly. It can take up to 90 seconds for the burner to ignite. As the igniter ages, you may experience longer ignition times.
NOTE: Just because the igniter glows, does NOT mean it is good. An igniter may still glow, but could be too weak to properly operate the gas safety valve.
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com pcappliancerepair.com appliancepartspros.com repairclinic.com All these sites have competitive pricing, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying any parts you may need.
If you have any questions, please post back with your complete MODEL NUMBER and let me know. I hope this information is helpful to you.
Apr 20, 2011 | Kenmore Dryers
Gas Dryer. Heat for only one burn cycle.
Try vacuuming out the intake and exhaust of the burner to remove any lint or other debris. If no help, the main burner may need to be replaced.
Feb 03, 2010 | Dryers
Gas pilot light
Most modern appliances that use gas as an ignition source do not have a pilot light. The gas and ignition is controlled by a burner assembly with a gas safety valve. In theory, the way the burner ignites is:
1. You push the start button, the drum begins to turn and the igniter on the burner assembly begins to glow.
2. The igniter must reach a predetermined current potential in order for the gas safety valve to open. Once this current potential is reached, the gas safety valve opens.
3. Gas begins to flow into the burner manifold, and you have ignition.
NOTE: It can take 30-90 seconds for the burner to ignite. As an igniter ages, it may take longer.
The reason burner assemblies are designed this way (especially in dryers) is to prevent free flowing gas from filling up the appliance cabinet without ignition. If such a condition existed, the could be a potential explosion hazard.
If you are experiencing problems with ignition, the first thing to check is your igniter. The do wear out with age and are fairly simple to replace.
NOTE: A glowing igniter does not necessarily mean it is good. If it is weak from age, it may never reach the required current level to open the gas safety valve.
If you have questions, or require additional assistance, please post back with your complete model number (located on a nameplate around the door opening on most dryers) so I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 63942 Dryer
Kenmore gas dryer mod.110-73942. burner comes on as normal. After 5-10 minutes running Cycles off, igniter ( new) glows but no burner ign. Also replaced the sensor adjacent the igniter.
The gas valve coil is bad. When the ignitor is glowing the gas valve should open and allow gas in to be ignited. Change the gas valve.
Aug 05, 2009 | Kenmore 63942 Dryer
Sears kenmore gas dryer 417.92052101does not stay lit.
Watch the burner assembly, shortly after starting the dryer the ignitor should begin to glow. If it glows for several seconds (up to 15 seconds) and then goes out, then the problem is probably the solenoids (coils). If the ignitor glows and stays on, then the problem is usually the flame sensor.
Jul 11, 2009 | Dryers
No heat burner comes on for a few minutes and then goes out
Check the following to address this issue.
1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Jun 02, 2009 | Kenmore 72062 Gas Dryer
No heat
If the burner assembly is not lighting I would recommend you look into an igniter replacement. If the igniter is worn, or does not work at all, the gas safety valve will not open and you'll never get ignition. The part number is 279311.
If the burner assembly lights, then goes out after a few minutes, I would recommend you replace the gas valve solenoids. There are two of them on the burner assembly. It is recommended that you replace BOTH of them at the same time. The part numbers are 69540 and 69539. Searspartsdirect.com has an excellent illustration of your dryer. Just type in your model number and look under the "Burner Assembly" heading. The igniter is listed as item 4. The solenoids are items 13 and 14.
If you have questions, please let me know. I hope this is helpful to you.
Mar 03, 2009 | Kenmore Dryers
Whirlpool Model LG5801XK Gas clothes dryer
first ck gas to unit, next is ck the coils on the burner valve right, there(i just looked up and this is an older unit) set of coils is about $85, the entire burner valve including coils and new ignitor is about $135.that would be my bet the whole thing but is it worth it putting 135 into the dryer
Feb 26, 2008 | Dryers
Dryers Logo
65 people viewed this question
Top Dryers Experts
