Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag fav6800aww not draining
We had this problem under warrenty, tech found lent clog in one of the drain hoses. now not under warrenty, i have pulled both hoses-to pump and from pump-no clogs. I didn't check insided pump-guess that is my next step. any suggestions?
  • rockhead255 Jun 03, 2009
    Thanks. I did the service mode run, but no water is being put out by the pump. It clicks then the pum hums, I am going to drain the water manually and pull out the pump to see if there mey be debris in the pump itself. will let you know what happens after that.
    OK, working on the washer is not for a redneck with big hands and arms!!!! Gound blockage in pump, removed and re-installed. Works fine. Wish there was a way to take just that side panel off, it would really help. Hardest part was re-alligning pump mount tight and low visability!! Thanks to all for the help on previous questions/solutions
  • 335 Answers
Are you taking an “ND” error to the display? Good job on checking for the clog from the sump cap to the input to the drain pump and out the drain pump to the drain pipe. The sump cap is sort of semi transparent if you shine a flash light on it do you see any restrictions? I had half of a bank card stuck in mine. This the sump cap item 9 of the parts view.
Drain Pump opened up;
I would try to turn on the drain pump in service mode and see if you hear it spin up. I guess the impeller could be jammed up. So let’s try that first. I post these links constantly for support so disregard if you have them. Link to Service Manual for reference. Sears Parts Direct for reference.
I would go to page 16 of the SM lower right hand part of page, Board Output Test and turn on the drain pump in service mode and see if the motor runs. Here is the test; close the lid and enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
Pressing the Delicates key will lock the lid. Now press the Presoak key the drain pump will turn on do you hear it run? Stop the test as the SM states with off button or hit the Presoak key. If the drain pumps sounds like it turns on I would put in a bucket of water in the wash basket and see how the output stream looks out of the drain hose when you turn on the Drain Pump in service mode. I get about a 2.5" vertical lift of the output stream from the drain pump.
Post back for questions or any help we can provide. Rich
Posted on Jun 03, 2009
  • dh1200s
    dh1200s Jun 04, 2009
    Yep it’s a tight area. I pull the washer away from the wall and lean it back for a better reach angle when working on the clutch or the drain pump. I took a stainless steel sink screen and fit it into the Sump Cap to help prevent clogs in the drain lines and the pump impeller. I’m sure it’s over kill but I don’t want to have to get back into that area if I can avoid it. The Sump Cap is much easier to remove and clean out in the front of the machine. Have some picks if you are interested.
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Does not seem to drain completely - ran very long today and the last code I saw was "nd" - not draining? or not done?
nd code indicates a problem with draining. The problem could be:
1. Clog in the drain hose - 2. Drain pump in the washer needs replacement 3. Clog in your sewage
Some simple things to try out
a. Run a wet/dry shop vac at the end of the drain hose to clear out any crud/cloth debris. b. Replace the drain hose altogether (will require a bit of work). Remove the back panel (small) that holds the drain hose in place and disconnect the clamp that connects to the drain hose to thepump outlet. The whole drain hose can be purchased for under $20 at your local hardware store...
Good Luck!
Jun 11, 2011 | Maytag Neptune MAH5500B Front Load Washer
Water will not pump out of my Maytag dishwasher!!
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 25, 2011 | Maytag Dishwashers
How do i get to the drainage hose in back of neptune FAV6800AWW?
You have to remove the front cover from the machine.
Do you have the FAV6800A/FAV9800A Service Manual?
I'll see if this site can let me post a pic of the wash tub removed. In this pic you can see the Drain Pump/Pressure Switch and drain line on the right side of the machine. There is no side or rear panel access.
What is the issue? Won't drain?
I would suggest you Google "Maytag neptune FAV6800aww wont spin" this forum has a Sticky for Maytag FAV6800A and FAV9800A machines and you can get the Service Manual from this site. I feel it's a better DIY site.
OK let me see if I can attach a pic;
Jan 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Clogged dishwasher?
disconnect the drain hose from the disposal or under the sink use a 5 or 6 foot long piece of plastic ice maker hose run it down the dishwasher drain hose till it want go any more also put one cup of bleach in the bottom of the dishwasher and let it set for at least 1 hour then turn the dishwasher on to drain and see if that cleared your clog
Mar 30, 2010 | Maytag 24 in. MDB5600A Jetclean II...
Maytag MAV4755AWW. Water remains in clothes after spin cycle.
Check the drain hose for kinks and clear it from any clogging. If no clogging or kink is found, drain the water manually.
Remove the rear access panel to access the drain pump. Press the hose clamps and move it away from the pump. Remove the hoses from the pump and drain the remaining water from the tub drain hose into a shallow pan.
Lay the machine on its side on a cushioned surface to allow easy access and removal of the drive belt.
Remove the three screws securing the drain pump to the base of the machine. Check the pump impeller for any damage and clear it from any debris that may be preventing it to pump the water out. Replace the drain pump (part #35-6780) if the impeller is damaged. Secure the new drain pump to the base of the machine with the three screws and reinstall the drive belt and the rear access panel.
Note: Disconnect the machine from the power outlet before servicing to avoid the hazard of electric shock.
Feb 22, 2010 | Maytag MAV4755A Top Load Washer
Top tray not draining
I called the service tech, before Maytag stopped supporting this unit. (built by Fedders with Maytag name). Fedders has gone out of business (7-09). The tech guy said that the tray gets clogged up with crud and the solution is to try to flush the tray out with water and compressed air. I had the problem of water leaking from the trays but not properly draining through the drain hose. This solution did the trick.
Jul 24, 2009 | Maytag Portable Air Conditioner M6P09S2A
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Removed coins now won't work Maytag MAH2400
your part is prob number 26 on this drawing: http://www.partselect.com/Schematics/Maytag/56573.gif
You can purchase a new one here.. http://www.partselect.com/MultiModels.aspx?ModelNum=MAH2400&searchTerm=&RefineSearch=0
Aug 18, 2008 | Maytag MAH2400A Front Load Washer
How to clean pump
If you can turn the impellar on the pump with your hand and it runs freely, then the pump is ok. You should maybe look at the hose that leads to the drain pump from the drum, or the drain hose that goes from the pump to the sink/tub. It may be clogged with lint. Remove the drain hose from the spigot under the sink/tub and check the spigot. It too may be clogged. It is not possible to get into the pump. It is a sealed unit, unless you are able to unscrew the impellar from the motor shaft to check underneath it.
Oct 12, 2007 | GE Energy Star WCVH6260F Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
354 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
