My car does not seem to get warm when it is cold out. If I let it sit and idle for several minutes it blows good warm air. If I drive in town with lots of stop and go it blows warm air. When I reach highway speed it blows only cold air and will not warm up.
Check and make sure the radiator is full of antifreeze take off the radiator cap and top off the radiator then take your hand and cover the hole where the cap goes and squeeze the top radiator hose a few times to help it go down that way if there is a air pocket somewhere it will help push it out when you thank your done top off again and replace the cap and try
SOURCE: Air Conditioning
Sounds like the hig head-pressure cut=out is kicking in and shutting down the compressor. This is probably caused by not enough air being moved across the condensor coil (in front of the radiator). Check and make sure all the engine cooling fan components are in place and functional (fan clutch, shrouding, belts tight) and also check the coil for obstructions (Bug accumulation, road debris, litter). Clean the coil and radiator as much as possible at a self-service car wash, see if that doesn't help.
This can also be caused by an overcharged system (too much Freon). Sometimes when these symptoms first appear, the knee-**** response is to add another can of Freon, only to make things worse. If this is the case, I would recommend a system evacuation and service, replacing the dryer/receiver and pulling a 28mm/hg vacuum on the system, and then refilling with the proper amount of Freon, and cleaning the evaporator coils as well. This can only legally be one by an HVAC Certified technician, to insure excess Freon is not released into the atmosphere.
Hope this helps you figure it out, and good luck!
-WB
SOURCE: Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
SOURCE: heater on ford 2003 ford pick up blows cold air
on the evap box there is a control mtr that switches the hot cold door. these mtrs are prone to failure. the other problem that i have seen is that the door breakes in side the evap box and that means removing the box to replace the door . if i remeber correctly you may have to slide the dash back to gain assces to the control mtr to test it good luck
SOURCE: heater blows cold air ac blows warm air
Your problem is the air temp control blend door actuator is defective and not controlling temp u set. to change/access this part the dash assembly must be removed from the car.
SOURCE: Air Conditioner stops blowing cold air when vehicle is not moving
plus one on the cooling fan problem. if it was low on charge then as you slow down, condensor temps and line prressures would raise therefore it would cool at low speed and and not when moving since the incoming air would drop system temp,reducing line pressure and then cusing compressor to cycle. the auxillary cooling fans must be on whenever a/c is on, if not, thats your problem. get this taken care of because if you get stuck in traffic, your engine will overheat also if fans are not running
