Question about Epson STYLUS CX3900 All-In-One InkJet Printer
Epson cx3900 printer
The paper will not feed through the machine to allow printing, I tell a lie it will go through for about 2 inches of the paper and then stops. The printer is still printing but god knows what on because the paper has stopped feeding through.
  • Anonymous Jan 08, 2008
    Just started to have exactly the same difficulty. The paper will start to feed, and then stop, while the printer keeps printing. The paper seems to be catching on something about 6 cm from the right hand edge as it leaves a small crease there. I have tried changing the paper, cleaning the machine (as best I can) to remove any dust etc that may have caught in it. So far no solution.
  • Anonymous Jul 23, 2008
    I have exactly the same problem. The paper appears to feed about 2cm and them doesn't move however the printer sounds and appears to be printing the document. I have tried going throought the manual switching on and oof the power button and holding the ink dop button for 3 seconds whilst pressing the on button.I have looked into the feed area and tried to catch the feed to accept the paper but can see where the paper feeds exactly. Very frustrated'!!!
Cartouch
Posted on Nov 21, 2007
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
My Epson Stylus CX3900 is printing faintly though it is showing enough ink in all cartridges to print another 100 pages. Please let me know the solution. Thanks
Hey
Most epson cartridge monitors lie! unfortunately!
if the image if getting fainter try doing a head clean do this by entering your control panel and bring up the printers and devices file, click on the printers icon and look for the maintence/cleaning tab..tell it to do a deep clean if it doesn't get any better it's more than likely the cartridges are nearly out...
go and buy some new ones:-)
hope this helps,ben
Jan 04, 2011 | Epson STYLUS CX3900 All-In-One InkJet...
I am trying to print my guest receipts and it is only printing out a quarter of the sheet with no ink.
hello, lets see if we can seperate problem with computer and printer, try running printers self test, i am curios if the machine will print properly, turn printer off, then hold paper feed button and turn machine on, paper will feed and print, once the first test pass, if you want to print the rest, press paper feed button, and machine will print and cut paper, this test is rather a little long, but it will give you info regarding paper feed, and cutting as well as impressions. if paper is dragging, check to see if the paper in machine is in correctly, you might want to check this out first, if the paper is in correctly, then problem is feeding, this is a little hard to clean, but you might want to try some isoproply alcohol and put some on the lead in paper, just enough to get paper wet, and try to allow machine to feed in, or maybe, if paper is already feeding in wet some area before going into machine with alcohol, and press feed button, and allow the paper to feed thru. tear off paper and try the printer test again. if still fails then machine has a problem and will need service.
Oct 08, 2010 | Epson TM-U220 Matrix Printer
Epson CX3900 printer indicates paper jam
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Sep 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Print wedding announcements and the print is not straight
Card stock on an HP can be a nuisance, due to the paper feed path. The stock has to curl around the platen.
Some things to check: Make sure you are telling the print driver you are using card stock. It should be in the printing preferences as paper type. The printer will respond differently, knowing it has the heavier paper. Also make sure that your paper guides are adjusted to fit the smaller stock. Just putting in 5.5 x 8.5 paper into an 8.5 x 11 tray may cause it to skew.
I am assuming that you are already telling it to print high quality, as it is for a wedding announcement, but make sure that you are. Slowing down the paper feed speed by putting it into high quality mode can help.
Your printer is an older model, so it could be that the rollers are wearing down, and it just can't feed the last bit as well. You could try to print it in "landscape" mode. Turn the paper 90 degrees in the paper tray, so that the 8.5" is the feed side. This will allow the printer to have a better grip on the paper as it goes through. A word of caution with this method, though. HP's have a 1/2 inch margin at the bottom of the paper where it can't print. Turning the paper 90 degrees will force you to have a side margin of 1/2 inch. Currently, your bottom margin has to be 1/2 inch. I don't know what your layout looks like, so I don't know if you can turn the paper.
If you are the one getting married, the congratulations, good luck, and mazel tov! (Have to cover all the basis).
Jul 17, 2009 | HP DeskJet 5550 InkJet Printer
Paper will not load into my Epson PHOTO R340 printer.
May be the problem is at paper sensor, that dirty. The sensor is at bottom of head casing. When paper feeding, the sensor not get the light back, so the printer "think" that no paper. Try to clean paper sensor.
Jan 12, 2009 | Epson Stylus® Photo R340 InkJet Printer
Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Jan 05, 2009 | Epson Stylus RX580 InkJet Photo Printer
Paper
need to re adjust the guidance stick, the one you move from left to right , it could be that its misalign , check it out , hope this helps AJ
May 06, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
Epson STYLUS CX3900 All-In-One InkJet Printer Logo
144 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
