Question about Maytag Neptune MAH5500B Front Load Washer
Water problems Always leaves water left water at the bottom- the problem know is that is not draining water can it be the water pump?
  • 6,784 Answers
Check the following to address this issue-- 1. Clogged drain line or water pump Check to see if there's something stuck inside the pump or the drain hose connected to the pump (pump is usually located at the bottom and towards the back of the washing machine). 2. Water Pump If the drain line isn't clogged, you may have a problem with the water pump such as a frozen pulley or a broken impeller. If that's the case replace the water pump. Note: if you have a belt driven washer, check the belt(s) for cracks, as this would be a perfect time to replace the belt(s) if needed.
Posted on Jun 03, 2009
My Frigidare dishwasher is not draining so I cleaned the filter. Will there always be a little water left in the lowest part where it drains?
There will always be a small amount of water in the bottom because the pump is an impellor type, not syphon or peristaltic. The water will be whatever is in the drain pipework after the drain cycle has finished. If the machine is leaving a lot of water, the it would be worth checking the drain hose isnt blocked or kinked, and the drain pump impellor moves freely
Jan 11, 2018 | Dishwashers
Do I need a new drain pump?
Get a wet vacuum and hook it to the drain HOSE
May 29, 2015 | Frigidaire Professional Series 24"...
Washer WPSR3100WOWW Will wash but not drain and spin... Stops at the rinse Cycle
Christina,
Does it leave water inside the tub? There are a couple of possibilitys. One could be the drain pump. If this fails the wash/rinse cycle will stop as it can sense the water not being pumped out. Can you hear the light sound of a small motot running when it goes into rinse cycle? Listen down at the very bottom far right side or far left side. If you hear the drain pump motor running is there any water discharging out the drain tube going into the wall? You should easily hear the flowing water. If not you have a few possible problems: Drain pump has an obstruction in or around it or, drain pump is actually bad.
Oct 12, 2013 | GE WSXH208A Front Load Washer
I have a five years old kitchenaid dishwasher that leaves water the in the bottom sometimes. I have replaced the drain pump and checked the drain hose for blockage but I still have the same problem of...
Propably you have leak from the main pump impeller seal.See the video below. It helped me to fix yesterday same problem.
http://www.youtube.com/watch?v=RLkMncM6JDE
If you open the bottom of the dishwasher you can see the leak.It leaves calcium at the base of the pump.
Sep 10, 2013 | Bosch 24 in. SHU43 Built-in Dishwasher
I have an f3 and f4 error code on asko washing machine front loader. i know what the error codes are just dont know where they are anyone can help I need it thanks
F3 indicates a problem with the drain pump. At the bottom left of the machine, theres a square cut-out. This is where the drain pump is located. Using a flat head screwdriver or similar object, insert in opening on right side and gently pry open the drain pump cover.
Once the cover has been opened, be careful when opening the drain pump, as there is always a little water left in the drain pump. Before you open the drain pump, place a small container on the floor below the drain to catch the water. Pull the small black hose from the door and let the water drain into the container. You can now open the drain pump to clean it out. Also clean the pump rotor at the back of the pump housing. Replace the drain cover and reconnect the drain hose securely back to its position on the door. Close the cover.
F4 indicates a problem with the water inlet valve. Make sure the water supply is fully turned on. If no water enters the machine, then turn water supply off. Disconnect the hoses from the water inlet valve to see if the strainer in the inlet connection is blocked. Reconnect the hoses and turn on water supply. Hopefully this solves your problem.
Feb 14, 2011 | Asko W6441 Front Load Washer
Does not seem to drain. Always leaves a couple of inches of dirty water. Also leaves a lot spots on dishes.
Check the float in the bottom of the washer. If it's stuck it could cause problems. Otherwise, maybe the pump that lifts the water up and out into the main drain isn't pumping properly.
Feb 11, 2011 | Frigidaire Dishwashers
The door on my dishwasher everytime you open it is making a loud creaking sound and there is water at the bottom of the dishwasher always. what to do?
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn’t overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn’t working properly, the drain pump isn’t working correctly, or possibly there is a plumbing problem in your home’s drain lines.
First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. Has the disposer been replaced recently? If so, chances are the knockout is still in place. Simply remove the drain hose from the disposer, and knock out the plug. If the disposer has not been replaced, try removing the drain hose from the disposer and use a wet-dry vacuum (prepared for water, of course) to **** any water (and hopefully anything else) from the drain line. Then reconnect the hose, and test the unit. If you have checked the air gap and the drain hose and can’t locate the problem, then it is an issue with the drain pump of the dishwasher.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Mar 03, 2010 | KitchenAid Dishwashers
My dishwasher stiil has water in it when done why? nicks@onlyinternet.net
DEPENDS ON WATER LEVEL, BUT THERE IS ALWAYS SOME WATER LEFT AROUND THE OPENING IN THE BOTTOM AS THE WATER IS PUMPED UP INTO THE DRAIN AND THE WATER IN THE DRAIN LINE FALLS BACK INTO THE DISHWASHER. IF EXCESSIVE SUDS THEN THE PUMP WILL NOT PUMP SUDS, 'FULL OF AIR;
Feb 22, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Washer does not drain, and leaves water in the
hi..The drain is clogged.check the strainer at the
bottom of your unit.Always rinse your dishes of food
before putting them in the washer.
check this out..
thank u..
kindly rate my response..
Jun 09, 2009 | GE 24 in. Profile PDW7800 Built-in...
Whirlpool Ultimate Care II does not completely drain.
Mine will do this if clothes are left in it for a long period of time. The pump will not drain all water out because the will dry out the seals if they do. Your wet clothes dripped in the tub raising the water level to the bottom of the drum and that is why you have wet clothes. Remove clothes as soon as they are done, use cycle signal to avoid this.
Apr 08, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag Neptune MAH5500B Front Load Washer Logo
445 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
