Question about Whirlpool Washing Machines
AU AWO 3561 whirlpool washer comes up with FP on the panel and won't empty the water. does this mean the pump is broke
    Genius:
  • 1,239 Answers
Hi it is the problem o outlet valve, clean it...... thank u.......
Posted on Jun 03, 2009
What does F09 mean mean for a whirlpool AW0 3561 front loader?
Washing Machine Fault Cod Fault
FH No Water Inlet
FA Aquastop Failure
FP Drain Failure
F5 NTC Failure
F6 Tachometer Failure (no motor movement detected)
F7 Triac Short Circuit detection
F8 Heating Element, Open Circuit
F9 Overflow Failure
F10 Motor control unit (Thermal)
F11 Communication failure
F12 Heating Element Short Circuit
F13 Dispenser Circuit Error
F14 EEPROM Failure
F15 Motor Control Unit Error
F16 Control Failure (Control Unit)
F18 Control Failure (Control Unit)
F20 Control Failure (Control Unit)
F21 Control Failure (User Board)
F22 Control Failure (User Board)
FDL Door Lock Error
FDU Door Unlock Error
Whirlpool Washing Machine Fault Codes
So the answer is Overflow Failure
Apr 13, 2015 | Whirlpool Washing Machines
My whirlpool awo 3561/5 wont take in water?
either thetimer contacts are bad or the water inlet valve has failed
Mar 10, 2015 | Whirlpool Washing Machines
My Whirlpool AWO 3561/5 makes a loud squealing noise when draining. What could be the problem?
Check your drain filter for any blockage. Make sure when you open the filter that you look up in there as far as possible. Also, I would remove the drain hose from the pump to look for any debris. After clearing the filter and pump, run the machine again. If you still hear the squealing you will need to replace the pump. Here is a link to the replacement pump.
Regards, Richard
Jul 30, 2011 | Washing Machines
Whirlpool front loader - 6th sense AWO 3561. The machine is stopping on the rinse part of the cycle and E09 is displayed in the "remaining time" display. The "water tap closed"and "clean pump" lights were...
please consult the user guide from the manufactures website its usually free to download and go to the problem shooting section for a possible answerer eric
Dec 19, 2017 | Washing Machines
Whirlpool AWO/D 4605 Clean Pump light on, how do I
Remove bottom plastic panel across the front of machine- it just clips off (use a small screwdriver or bread knife to prise off). You will now see a round filter behind this panel- unscrew anticlockwise to remove- this is the filter. Sometimes filter can be hard to remove if you have things jammed in it- give it bit of a jiggle and it should come out without forcing it. Remember- if there is still water in the machine, this water will come out on the floor once you remove the filter- put down some towels!! Happy fixing!!
May 11, 2010 | Whirlpool AWOE8748 Front Load Washer
WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
May 19, 2009 | Whirlpool AWM8163 Front Load Washer
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Washing Machines Logo
867 people viewed this question
Dan Webster
Dan Webster
Sal De
