Question about Linksys Ultra RangePlus Wireless Routr Router
Router interfers with wireless camera
I Have two wireless
security cameras that work on the 2.4ghz band. The
wireless router interfers with their signal. How can i change the
dual band router to the 5.4 ghz band?
  • dlmm_1 Jun 03, 2009
    Thanks, I changed frequencies on the cameras and
    it cleared up the problem.
    Thanks again
    dlmm_1
    Scholar:
  • 145 Answers
Have you tried just changing the channel your wireless is broadcasting on. That has solved the problem for me before
Posted on Jun 03, 2009
  • Brandon Baker Jun 03, 2009
    have you tried just changing the channel your wireless is broadcasting on. That has solved the problem for me before
Cant connect to a new labtop
1, You should always secure your Wireless. 2, try different channels, setup the dual-bands as 2 SSID, 1-2.4 and the other as 5.0 with diferent channels. I would suspect it's the laptop, Disable the UAC and the Anti Virus. Is the wireless adapter, on the laptop turned on? Do you see the Wireless listed in Available Wireless Networks? For dual-band setup :http://www.pcworld.com/article/229521/dlink_setup_a_wireless_router.html
Jan 09, 2013 | Computers & Internet
I get intermittent wi_fi service. Sometimes it works two days in a row and for the next few days it keeps searching and searching for my Wi-Fi connection. I shut airport off and plug in the hard wire and...
You may have people close to you with wireless using the same channels and interfering with your router. Try changing channels in the router settings or move the router to a different location.
Sep 18, 2012 | Cisco Lynksys Dual Band Wireless N Gigabit...
We havea TRENDnet Wireless AP TEW-430APB - keeps dropping wireless
It can drop signal if there are other devices working in 2.4GHz band interfering with it. Try to switch over to 5GHz band.
Aug 29, 2017 | Trendnet TEW-430APB Wireless Access Point...
I have a Dlink wirless extrem N gameing router and for some odd reson it does not work long distance as well it use to be fast now is slow please help. it is fast when close to it.
You may have something interfering with it such as a cordless phone. Try turning off cordless phones or changing the signal the router is working on.
Hope helps
Jul 29, 2011 | D-Link Xtreme N DIR-655 Wireless Router
I can't get this website to work. 192.168.0.253. It's supposed to be the website to configure my BL-131 Network Camera. I got the camera a couple of years ago and just now replaced my router. ...
Replacing the router will not have changed any settings in the camera. The IP address 192.168.0.253 is the factory default for the camera, unless you assigned a new one when you set the camera up.
This is a wired/wireless camera, and if you're trying to connect wirelessly you probably have a router setup issue. Like any wireless device, the camera needs to provide the right key to connect. If you haven't set up your new router's wireless security yet, or set it up with a different key than the old one, the camera won't be able to connect. If the camera's not on your network, you won't reach it and you'll have the problem you described.
The simplest thing to do is to start fresh. Reset the camera to factory defaults with its rear-panel reset button. The button is recessed and you'll need a pen or other object to press it for a couple of seconds. Connect the camera to the router using a cable, and you'll be able to reach it again on 192.168.0.253. Set up the wireless network in your router (assign network name, security key, etc.). Then go through the camera wireless setup steps so it can connect to your network and you'll be back in business.
If you need a copy, you can download the manual and find other information here from Panasonic.
May 28, 2011 | Panasonic BL-C131 Network Camera
Dual band setup/wep
you have dual band router.
It must be working on the 5 GHZ and 2.4 GHZ .
if you access the router set up interface , you will find the wireless settings of the router.
For 5 GHZ , you can set up different SSID than the SSID of 2.4 GHZ.
Make sure that both the wireless network names will be different.
You use the same security settings for both the bands.
For this you will need to access the router set up interface.
Click Here for more info
Oct 31, 2009 | D-Link DIR-825 Wireless QuadBand Router
I brought a set of security cameras that work on 2.4Ghz and this router F5D8236-4v1‏ is interfering with it. Is there a channel that does not operate on this frequency that I can change it to. Also,...
you can go into the routers settings and for wireless change the channel 6 is default and i believe that is 2.4 GHZ the smaller the number the less freq. the bigger the number the higher the freq. if you go higher. It is possible it may interfear with a cordless phone when you make the change so you may need to play with the setting
Mar 25, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
No wireless
first make sure wireless enabled and find out what channel the item your trying to connect to is the same as the router and set both accordingly. I had same problems with security cameras i turned security settings off for wireless and switched everything to channel 6 on router and cam and wet with 806 and works fine had to restart router not reset.
Aug 07, 2008 | Netopia (3347NWG-ENT) Router (3347NWGENT)
Wireless installation for DCS-5220
Plug in the network cable first and make sure the following settings are correct:
1. SSID is the same and set to broadcast
2. You are using the same WPA AES password as the router (or WEP password if you are using WEP)
3. The wireless antennae is connected
4. The camera is located not to far from the router
After that, remove the network cable and restart your camera.
May 19, 2008 | D-Link DCS-5220 Network Camera
Linksys Ultra RangePlus Wireless Routr Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
