Question about IBM ThinkPad 600E 2645 Notebook
Error 161 and 163
Please help me to repair my problem on my mashine
    Novelist:
  • 148 Answers
The ThinkPad 600E is at least 5 years old? If so, have you changed a RTC Battery (CMOS Back-up Battery) 3V Button cell type that goes somewhere inside the Laptop and sits on the System/Motherboard. I hope you put it back the right way polarity is critical. If not then i have no idea to what it is, though someone will be able to help also you might want to try http://www.computing.net/answers/hardware/ibm-thinkpad-bios-error-code/ good luck, Bastian
Posted on Jun 03, 2009
We are facing error code e004 Scanners in Konica Minolta c224, please help us if you have any solution.
Try to upgrade the firmware of the mashine to c224e. Remember to use USB device max 2gb volume
Jan 11, 2015 | Konica Minolta Office Equipment & Supplies
Sir canon ir2830 error code E743
sir meri mashin me ir2830 me error code E000-0743 aa raha he kriapya esaka solution batao
Jul 25, 2012 | Canon Ir 2830 Digital Copier
Washing mashine MW511 top loader was running good but this morning tried to start but it is making a beep beep tone and flashing lights
It is giving out a fault code,
Of the 8 wash progress lights, tell me witch are on,
I will tell you the fault code and info on how to fix.
Jan 29, 2012 | Fisher and Paykel Washing Machines
My new omega washing mashine shows an E2 error code 5 miniutes into the wash how do I fix this?
Manufactured by omega washing mashine have an electronic controlpanel that must be unlocked in order to set or make changes to your washingcycle.
E2 indicates a water leak. When a leak occurs, it trips thefloat device by dumping water into the dishwasher's base. The incoming watervalve will be switched off, and the drain pump will turn on until the sump isempty
However, if an error light is blinking on your dishwasher'scontrol panel, the panel must be reset before you can gain access. Blinkinglights on your washer control panel may signal a mechanical problem that needsto be repaired. If the lights continue to blink after you've reset the controlpanel, contact Sears to service omega washing mashine or considertroubleshooting the appliance yourself carefully.Instructions
1 Press and hold the "Heated Dry" button onyour omega washing mashine for four seconds to unlock the dishwasher controlpanel.
2 Press the "Heated Dry," "Normal Wash,""Heated Dry" and "Normal Wash" buttons one after theother, in fairly quick succession.
3 Wait for the washer to run a short diagnostic test.
4 Press the "Cancel/Drain" button at the endof the diagnostic test cycle. This should reset the control panel on your omegawashing mashine. Thankfor using fixya.
Jul 30, 2011 | Washing Machines
After mashine is in the middle of the cycle it
I am not a repair professional. I am just a 78 year old man who has been making his own repairs for about 50 years. Therefore the washer ID doesn't mean
anything to me. It's been about 55 years since I had experience with front load washers. I believe you may have a bad lid switch. I suggest you go to www.acmehowto.com where they have an excellent video on directdrive washers. If you need additional help you could try www.applianceaid.com where they have very good trouble shooting and repair information on washers as well as other appliances. You can search for the meaning of the error code on the site. I think you'll find what you need there. Don't worry about the timer, they hardly ever go bad. Good luck with it. If I have helped you, please rate my advice on fixya.
Nov 25, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Washing Mashine LG WD8050FH
that is a tE Error you have a faulty thermistor hope it helps
Sep 04, 2008 | Washing Machines
Copier problems
What model gestetner is it? There are different ways to rest it. What generation are you talking about? 10 years old or two days old model?? Need some more info. The problem may just needs to be rest, it most likely a fuser code to cold or to hot.
Mar 10, 2008 | Office Equipment & Supplies
To restore to origionalfactory settings
Are you getting registration errors or are you getting registry errors . If you are getting registration errors then you can call up the microsoft activation helpline and they would guide you through the registration process. if you are talking about registry errors then its something about the hard drive being faulty. so try to do a format reinstall. If you need more detailed help. write back. Thanks Ashish.
Sep 21, 2007 | E-Machines eMachines Desktop PC
Open Questions:
ibm thinkpad does not boot My IBM Thinkpad 600 (Type 2645-310) stops and hang during bootup. What happens is: 1. LED test, then green Power on and orange battery/charging 3. RAM OK (Responds when I take out /put in different amount of RAM and displays correctly. I have 128 + 32 removable, + 32 internal not possible to take out) 2. I can hear fan, CD drive and evt diskette drive. If I use diskette drive the LED wil give 1 blink, if I use CD drive it will give 14 blink. 3. No cursor seen, but this is displayed: Upper left show the amount of RAM present: 196032 KB OK Upper right IBMs logo in blue; IBM Lower left shows "ThinkPad(R)" in large letters and red dot over "i". 4. Then a "rrrrrr" sound from the loudspeakers after a while, this is in fact 28 clicks shortly after each other. Then nothing more happens. Diskette and CD drive is OK (But can not be used because bootup is never finished). I hear CD speed up and then down again but nothing more happens. No effect in booting with bootable diskette or CD, "Live Linux" CD or else. Backup battery OK (3V) and if I take it out I will be asked for correct date and time when Power on. I can then use keyboard or TrackPoint to set date and time, and after that hangup at the usual point. Starting without battery, HDD, CD drive and removable memory sticks makes no difference in symptoms. Pressing and holding F1 before and during poweron and startup (in order to enter BIOS and selftest) has no effect. I could not find help on IBMs home page, but maybe I did not look at the right place. Is somebody able to help me?
Feb 28, 2017 | IBM ThinkPad 600E 2645 Notebook
See all IBM ThinkPad 600E 2645 Notebook Questions
IBM ThinkPad 600E 2645 Notebook Logo
176 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
