Question about Aqua Vac Tiger Shark
Our AquaVac Tigershark is less than a year old. It only stays in the deep end and won't clean the walls this year. Any ideas on what's wrong with it?
5 Suggested Answers
  • 77 Answers
SOURCE: Polaris hangs in the deep end
Check to see if one of the drive belts is broken. You'll need to pull the wheels and separate the housing to inspect. Also make sure that the thrust jet is centered and pointing towards 12:00. This unit should back up after 3 minutes and reposition itself.
Posted on Apr 22, 2009
SOURCE: Kreepy cleans the deep end great. It cleans the
keeps getting stuck on the stairs and won't go in the deep end
Posted on Sep 05, 2010
SOURCE: I just bought an aquavac pool cleaner. It was
Mine does exactly the same ,and everyone I speak to has problems with Tiger shark,And try to get it resolved,NO CHANCE.
Posted on Jan 14, 2011
jharwell668
  • 640 Answers
SOURCE: Polaris 380 stays in the deep end only. What's
Make sure that you have enough hose to reach the entire pool. This sounds simple, but this is a common problem with these pool cleaners. Make sure all three thrust jets of water are working on the bottom of the pool, also.
Posted on Feb 01, 2011
Tigershark comes out of the water too far
You need to reduce the flow through the impeller - there should be a baffle (something in plastic, round, that will be installed at the top of the shark) in the box that it came in.
May 29, 2014 | AquaVac Tigershark Plus Robotic Automatic...
Keeps going back and forth in the same spot in the deep end. Up one wall down across up the other wall back down across..etc..
I don't think you will ever get a answer,I have been trying for months now to resolve this problem.
I have called Hayward direct in the USA and all they do is fob you off with some suppler of theirs down in the south of the UK.
Think they are only interested in selling there product with absolutely no after care.
DON'T BUY TIGERSHARK .
Aug 28, 2010 | Aqua Vac Tiger Shark
Turns on but does not move.
Thank you for posting your question here on Fixya.com.
Your problem could still be in the power supply, cable or motor unit. The motor unit is the most likely problem. For starters, try the tip I posted here on Fixya, found at: http://www.fixya.com/support/r3651526-dolphin_pool_cleaner_wont_start_up
If that is not enough, try our sites FAQ section on Dolphins at www.arrowpools.net. Select the FAQ button then from the drop-down select Dolphin. While your cleaner was made by Aquavac (Hayward) they work very much the same way.
It is not recommended you open the cord end that connects to the motor unit as you are breaking the seal for the submersible electronics. For information about sending your unit in for repair use the dolphin form link on the bottom of our site
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Aug 09, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Won't turn on
check the inline fuse.
The Pool Tech
Aug 06, 2010 | AquaVac Tigershark Plus Robotic Automatic...
Won't go in shallow end to clean
If your floats have started to absorb water, the unit may become reluctant to climb the slope from the deep end to the shallow end, although it may still at least start to climb and clean the wall. There are 3 installed floats in the unit bottom plate: 1 "h" float and 2 pocket floats. Aqua Service Distributors in Sequin, TX had a good price on replacements. Good people, too. S. Christian dansker01@msn.com
May 31, 2009 | Aquabot Turbo T2 In - Ground Pool Cleaner
Have power to the floating cord but tigershark will not run.
My tigershark would start working then stop 20 seconds to 20 minutes later. I found that the power switch was loosing good connection after self check cycle, I turned it on and off rapidly to hopefully clean the contact! I now disconnect and restart by pulling the power cord. I have run two cycles with no problem> I will replace the switch when I get a chance.
Good Luck
Apr 25, 2009 | Aqua Vac Tiger Shark
Aqua Vac Tiger Shark Logo
176 people viewed this question
Top Aqua Pool & Spa Experts
Larry Maranto
Shehu Pro
Shehu Pro
Ben Clacy
Ben Clacy
Level 1 Expert
Are you an Aqua Pool and Spa Expert? Answer questions, earn points and help others
