From a_gondhaleka to Hank94170. You asked: When was the last time you changed the cmos battery? Answer: Never. I think it is still the original battery. However, I have tested it, the battery shows 2.87 volts.
    Sergeant:
  • 361 Answers
We can change battery when we are getting message of cosmos. battery cause we can not keep time and date constant according actual time and date then we can say our battery is not working.3 volts. battery can work many yers.
Posted on Jul 16, 2009
I changed my "setup settings" : the F2 key and now almost everything crashes. i need the original settings in the different categories.
Unplug the machine, remove the CMOS battery, wait a 15 minutes
, replace CMOS battery, reboot, open BIOS, Set time ONLY. Save and reboot. That begs the question, Why change the BIOS setup?
Feb 03, 2013 | Dell Vostro 200 PC Desktop
Schematic for toshiba p200d-12kbecause i need to change the cmos battery
The CMOS battery will not prohibit the machine from powering on. If you're prompted before boot about the CMOS battery, you should be able to press whatever key-combination it asks for to move forward to boot. Otherwise, you have a separate problem.
Nov 16, 2012 | Computers & Internet
Hp pavilion clock won't keep time
try finding the time zone you are in and use that to set the time, changing the numbers individual will end up with the time going back to the time zone time. So change the time based on the time zone
Aug 04, 2012 | HP Computers & Internet
When I turn off my laptop, my clock on the task bar stops. When I turn it back on, sometime later, it starts from when I turned ot off.
The real-time clock is maintained by a chip on the motherboard. It derives it's power from the laptop battery but there should also be a small 3V battery inside the laptop to maintain the clock and the CMOS settings in the event of total power loss. This battery should last at least 5 years and possibly longer if the main battery is kept charged.
In order to see if it is a Windows issue, start up the laptop and go straight into the bios setup. The clock will be displayed here and if it is the the same time as when you switched it off then the problem is hardware related, possibly with the CMOS battery. If the time is correct here then let the laptop boot into Windows and check the time again. If the time has now changed then the problem is with Windows, in which case you may need to check for possible viruses.
If you think it is the CMOS battery then it os not likely to be easy to get to it. Look on-line for addition info for you particular model. If you manage to get out the CMOS battery then check the voltage on it - it should be above 2.5V for guaranteed operation.
Mar 10, 2011 | Computers & Internet
Hi, I have a dell studio 1535 and the bios clock runs very fast. In one hour the clock pass few days. I try updating the bios, set to default values and nothing changes. This is a CMOS...
I dont think it is a cmos issue because i replaced the cmos battery and it did not help my clock. I also had dell fix the motherboard and it worked for bout 7 months unfortunately after my warranty was up. Til this day my clock last no longer then a few hours until it reverts back to the time i changed it to.
Dec 27, 2010 | Dell Studio 15 Laptop
Hi, can anyone help me. The time on my Acer 5630 is not changing properly. It moves on very slowly when I reset it , which I have to do every time I turn on my laptop. Once I turn the pc off the time does...
i think the cmos battery needs a replacement cauz you say the time is syncronised when you shut down your machine.man resson for this is the cmos battery is off needs replacement.
but befor that check the time option by double clicking on the time on the taskbar and go to internet time option and choose to syn it with world time and also check that you have choosed the corect time region.
Dec 21, 2010 | Acer Aspire 5600 Series 5630-6951 Laptop
Cmos battery dead - needs to be replaced
Sounds like you need to change the CMOS battery, the time being wrong everytime you boot is a good sign but also it losing its settings in bios is also another sign
Dec 26, 2008 | Dell Inspiron 8500 Notebook
Boot problem
Updating the BIOS could be the solution, but, let's leave that until last - if you get it wrong, you'll stuff up your machine (mobo) for good.
Don't worry about the CMOS jumper, it is there to clear the CMOS memory, but I don't think you need to do that.
Can you get into your BIOS during start up OK? (usually by hitting F8, F2, Del one of these keys or similar during start up, it should tell you which).
If you can navigate your way through the BIOS settings ok, don't change anything you're not familiar with - another place you can do damage, and somewhere towards the end, where you have to option to exit BIOS with or without saving there should be another option like "Reset Defaults" or "Load Optimal Settings" or "Set Last best Settings" or something like that.
Click on this then exit your BIOS. Your computer should restart.
Make sure your new memory battery you put in is up the right way, if it's upside down it could be causing a short - the usual way is positive up, that's the whole flat face with the writing on it - the insulated button side is negative (down).
**.The best way to acknowledge contribution is to rate it's relevance.**
Sep 07, 2008 | PC Chips MB PCCHIPS M863G V5.1C w/XP2400+...
Motherboard with mistake in the initialization
after changing the battery the problem is suppose to stop but since it continues i think u have to set the date and then save the changes made after saving cos is not all about changing batteries most times too the new batteries u just bought may be bad as well. so set the date and time then save changes i think it shoukld work well.
thank u
May 29, 2008 | ASUS P4V8X-X Motherboard
Password
your dealing with more than one security.Save time and replace the hard drive.
May 26, 2008 | IBM ThinkPad R40 2722 Notebook
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
