Question about RCA D52W19 52" Rear Projection Television
RCA Tv wont come on at all. No light s flash or
RCA Tv wont come on at all. No light s flash or nothing. I unplugged it, plugged it back in and still nothing. Whats the problem?
    Genius:
  • 1,239 Answers
Hi, i think cathode ray tube has burnt out .......first check the fuse also thank u.......
Posted on Jun 03, 2009
Top up tv dtr box froze then staying on orange light, wont work
i had same problem today, it had locked up during deal/no deal
unplugged it three times nothing happened, wouldn't switch on
unplugged again left it for 5 minutes
then plugged in and left alone for 15mins plus
lights flasing then evetually green light went
all ok
May 03, 2009 | Televison & Video
TV shuts off on its own and wont come back on until unpluged.
On the Deflection board CK 3 capacitors cp150,cp114,cp120 If cp150 is puffed up on top it is bad 2200uf 16v /other 2 caps are 220uf 35v.Also resolder all pinns on FBT
Jan 13, 2009 | RCA D52W23 52" HDTV CRT TV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA 32V434T Flashing Red Light
Flashing led..in protect mode..internal shorted component.
Aug 14, 2008 | RCA F32450 32" TV
RCA D52W136D 52 in. TV/DVD Wont turn on
Does the standby light flash in a set pattern? Some tv have a error code system which pinpoints the fault by flashing the standby light a certain number of times. Other than that my best guess would be a fault on the power supply or a fuse blown internally. Good luck.
Apr 08, 2008 | RCA D52W136D 52 in. TV/DVD Combo
RCA 32" wont turn on
It sounds like you may have a bad Horizontal Output Transistor (HOT) and/or a bad Flyback Transformer. The set is trying to start as indicated by the flashing light, but an internal fault is shutting it down right away. It could also be the Power Supply circuit. A 32in. set is not cheap to replace so it may be worth finding a repair technitian and at least getting a quote. The Flyback is the most expensive part, the others are minimal. If it is one of the above problems it could easily be repaired by a qualified technitian.
Mar 11, 2008 | RCA F32650 32" TV
Will not turn on
Does the set make any sounds. DOes the front green led light or flash when you try to turn it on.. if not then it could be as simple as a fuse, if it does flash then it can be many problems
Jan 06, 2008 | RCA D52W19 52" Rear Projection Television
Tv won't turn on.
Possible power supply problem or horizontal circuitry....
Best to have a tech check it....light box chassis comes out
fairly easy to go to a shop for analysis.......T.
Nov 06, 2007 | RCA D52W15 TV
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
RCA D52W19 52" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
