Question about RIM BlackBerry Curve 8310 Smartphone
WORKS Battery trick works.
  • 407 Answers
You mean the battery reset? Yes for most of the memory related issues it works, although it can cause an issue with hourglass hanging
Posted on Jun 03, 2009
Starter clicks will not turn engine over
next is jumper cable jump start to good running helper car battery.
that cuts cause in 1/2 , 15min works.
car starts, your battery is bad, or not charging, running, or is only discharged. (left head lights on)
wont crank. now?\\
hot wire the solenoid, for cutting possibles in 1/2 again.
what transmission? in car?
see tricks here. (and the hot wire trick)
http://www.fixkick.com/nocrank.html#tricks
Feb 15, 2014 | 2005 Honda Accord 2.0
When my civic gets hot no crank only click sound new starter and battery
hot soak no cranks, nice post, clear as bell...
i bet it not heat. just lucky correlations.
the question is, does jumper starts , crank the engine fast, hot.(failed)
big time check that.
yes, then the battery is weak.
no, then the key line is dead.
see wiggle tricks here, works on all cars
with these, tricks, magic can happen, and the solution
Jan 24, 2014 | 1997 Honda Civic
Lenovo laptop shut down and will not turn on. Tried removing all power and holding down power button but didn't work. When I press power button the te button lights up for a few seconds then goes out. ...
disconnect the adapter +battery HOLD THE POWER button by 30 seconds aprox, this trick is by eliminate all ESD.
Try again connecting the adpater +battery, if work is o.k
If the problem persist, connect only the adapt and see if the computer work, if does , connect the battery, if work is o.k .if doesnot.
The battery is faulty, RUN the software diagnostic with the adapter and see what going on inside of computer, the power supply inside can be faulty or the battery.
As a last trick, open the battery take out the small battery for CMOS, by 20 seconds. And turn on the computer can be TURN on.
God bless you
Jun 23, 2013 | Computers & Internet
Setdead
Sony ericsson w850 is an amazing phone. you just said, it was dead. Sony ericsson phones mostly have battery problems. so check your battery. change it with your friend's one (if he have sony ericsson mobile). If it worked, buy yourself a new battery.
I like to give you a trick. I saw some sony ericsson phones work without a battery inside when you connect the charger and charge up without a battery.
Try this trick too. If it works, buy a new battery.
If your battery is ok, then it might be an IC problem or software problem which can be repaired only by service men for a nominal charge..
Hope it works..
Good luck.. :)
Oct 03, 2010 | Sony Ericsson W850i Cellular Phone
Any tricks for making the mat work? We are
if it's a wireless mat you need to turn it on and put in batteries
Dec 30, 2009 | Konami Dance Dance Revolution Hottest...
Acer aspire 5520 laptop. Is it dead?
To verify it isn't a battery issue you can try taking the battery out completely and plugging in the A/C adapter and turning it on.
Without more information it's hard it's hard to diagnose your issue more specificially. Do you get any lights on the front?
Jun 21, 2009 | Acer Aspire 5520-5579 Notebook
Defective Ni-Cad Battery
Try Re-Conditioning the battery first. Full procedure at: ysuusy.com/easybatteryfix.html
"Cordless Power Tool Batteries and other batteries that contain Nickel Cadmium (NiCd) Cells can be Re-Conditioned to perform as well as new or even better than new. Proper maintenance after the procedure will insure years of usable life.
The First and most common procedure for Re-Conditioning a NiCd cell is by using a Technique called "VOLTAGE SURGING". Over time the crystals within a NiCd cell begin to combine and get larger. This causes them to loose capacitance and also break through the inner seals of the cell.
Surging the NiCd cell using a higher voltage causes the crystals within the NiCd cell to shatter and become smaller. These smaller crystals have a greater surface area and therefore contain a greater capacitance for energy. "
Jan 17, 2009 | Batteries.com 8148 Nickel Cadmium 2-Way...
More iris problems
I tried the cover trick with no success. I wanted to get at the iris by opening the camera . After removing a dozen screws, I could not remove the lens becauce of hidden screws. I placed the batteries back in and it works now. No more black screen.
Pierre
Sep 25, 2008 | Canon PowerShot S2 IS Digital Camera
9 volt battery trick
If you don’t find a solution you may want to try fixityourself123@gmail.com. He was able to give me some great advice and he has used parts in good condition and at a good price. It worked for me.
May 22, 2008 | Casio EXILIM ZOOM EX-Z70 Digital Camera
RIM BlackBerry Curve 8310 Smartphone Logo
171 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
ismael castillo
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
