SOURCE: Unable to find Mass Storage Controller Driver
Hi koolkeef, your KT7A-RAID uses the KT133A chipset. You can find drivers for that chipset located at VIA's web site.
http://www.viaarena.com/default.aspx?PageID=2&OSID=1
Happy hunting & good luck!
Mike
SOURCE: scsi \ raid host controller my system dont know
Sounds like you need some drivers, I assume all the connectors are correctly in place. If you can goto your device manager and see if there is a small yellow triangle with an "!" in the middle. Right click on this and search for drivers. If that doesn't work it'll be your chip set drivers. Look on the motherboard or use a program like CPZ to find out your motherboards model, go on HP's website and find the dirver. install manually.
SOURCE: windows keeps asking for driver for SCSI/raid host controller
Cancel and disable in Device Manager. If not in BIOS.
