Question about Inter-Tel Axxess Corded Phone
Reset voicemail. I need to set-up the voicemail on my phone, but do not know the password of the previous user. Therefore, the system isn't allowing me to do anything. Please advise how i go about fixing this problem.
Hi, How to change Cisco IP Phone voicemail password on router. Thank you
on the CLI you need to change the username and password on the ephone for that phone. Then you need to session into the CUE module and change the password there as well. do a show run and find the username and password that you need to change and then do config t and change the password. The user can also do this on the phone if they know the previous password.
Aug 31, 2017 | Cisco Computers & Internet
Dont know voicemail password
Are you referring to the voice mail on your cell? What company do you have service with? If using cell, you may be able to try dialing 611 and then press the send or call button. then select the option for reset password. (When you received the phone, were you able to put it in your name with your account info? If so, you may be able to provide answers to the security questions with your account to reset your password.) Let me know if this helps.
Mar 20, 2014 | Inter-Tel Axxess Phone 5504400
Phone is Panasonic KX-T7453, previous user set a password to the voicemail, need an override or reset to voicemail password
The override comes from the Voice Mail System owner logging into mailbox 999 and resetting the extension password.
Carl
Oct 08, 2010 | Panasonic KX-T7453 Corded Phone
How to reset voicemail password on a Mitel superset 420?
contact your system admin or vendor to have the mailbox reset. The mailbox isn't inside the phone, it's a system that supports all the phones in your office/company.
Apr 21, 2010 | Mitel Superset 420 Corded Phone
Need to reset my voicemail password without original password
To reset password on any tel set go to main set and press feature 983 this gets you in to programming you need a password and default password is normly
120000 for 2 digit locals and 1020000 for 3 digit locals etc.enter this password and press ok go in to
mbox type in mailbox press change , press reset password. hope this works
Sep 17, 2009 | NorStar T7208 Corded Phone
How do you change passwords without knowing previous passwords in order to change voicemail greeting??
Actually, even as a technician, you will never know the origonal password.
But you can get in to reset the existing password back to 0 0 0 0.
There are a couple of steps; depending on your voicemail system, voicemail's are done differently, but try this first.
got to a M7310 set
-> dial FEATURE 9 8 3
-> password: 1 0 2 0 0 0 0
-> you should now see ADMIN and under that MBOX, AA, OTHR
press MBOX
-> press CHNG
-> dial the extension of the phones that you need changed
-> you should now see PASSWORD and under it RESET, press RESET (This resets the mailbox back to 4- zero's)
-> hit the * to back up and repeat fopr all the other extensions.
-> hit RLS after all is done and voila... you have now changed those passwords to those mailboxes.
Now when the new users dial F981 at their desks, and dial 0 0 0 0 the first prompt they get is pleasde change password.
Apr 15, 2009 | NorStar Meridian M7310 Phone
Can't access voicemail. I do not have security code
we can reset the password on the mailbox for a remote charge.
If any has the admin password they can log into the admin box and reset a user id.
info@ameritelnj.com
Tony
Dec 12, 2008 | Toshiba DKT-2020 Corded Phone
Need to set up user voicemail box (new employee)
Go back to your vendor and get the password for mailbox 999 and the instructions to log into it.
The mailbox exists or it wouldn't ask for a password (they're assigned by default), so you need to go to mailbox 999 and chose option 6 1 3 which is mailbox administration reset password. That will clear the password and you can log into the voice mail automatically from the extension by dialing the voice mail access code.
Post back if you have any problems.
Carl
Sep 18, 2008 | Panasonic KX-T7731 Corded Phone
Access voicemail from Nortel T7208
Have you set up the voicemail before?
OK, from your set;
-> dial FEATURE 9 8 1 (this is the code to get you to the voicemail)
-> then your passcode, if you never set up the voicemail, the temporary password is 0 0 0 0 (four - zero's).
-> if this is a new installed voicemail, the telephone system will tell you al that you need to initiate the voicemail box.
Jul 29, 2008 | Nortel Business Series Terminal T7208 -...
Inter-Tel Axxess Corded Phone Logo
409 people viewed this question
Top Inter-Tel Lands Phones Experts
george  peters
george peters
David Burbee
David Burbee
Are you an Inter-Tel Lands Phone Expert? Answer questions, earn points and help others
