Question about Microsoft Xbox 360 Console
Xbox won't turn on
What i want to know is: if the brick is red,then the powersupply is faulty and if it's green the console is faulty or are there any scenarios with regard to which is faulty when the box can't turn on. please don't refer me microsoft i just want another clue to fixing this
  • 90 Answers
If its green then you are getting power and it might be the RF board or the power button on your 360
Posted on Jul 03, 2009
My xbox ix switching on and shows three red rings and after 5 minutes the brick turn orange and it now has two red rings whay do i do to fix it
Thanks for your question. To fix the 3 red lights what you will need to do is stop the heat getting to the GPU and the CPU and to do this you can use a good Xbox 360 Repair guide or of course you can send it in.
Jan 10, 2013 | Microsoft Xbox 360 Console
My xbox ac adapter has the button wich is most of the time green has now turned red. It is not the red ring of death it is on the adapter. How do i fix it???????
You will need a new power brick. GameStop sells used ones, take your old one with you as there are two different versions of the brick in older systems.
Oct 08, 2010 | Microsoft Xbox 360 Console
My xbox wont turn on at all
Check power brick . If red your power brick may be faulty . unplug all cables and check power brick again . If green light is on the power brick your good if its red you will want to contact ms at 1-80004myxbox or 1-800- 469 9206 .
Aug 04, 2010 | Microsoft Xbox 360 Console
I have 3 red lights on the xbox and the light is green on the power brick and then it cuts of and then the light turns red on the power brick and it wont turn on
This is the famous red lights of death! It happens because the GPU and the CPU have overheated, to fix it you need to stop the heat build up getting to the chips, you can do this yourself or send it in.
Dec 23, 2009 | Microsoft Xbox 360 Console
Xbox wont power on past orange brick light
You need to have the 3 red light fix service. We can fix it for you. We are a listed repair service on this site. Here is a link to our 3 red light service.
http://www.videogamerepairservice.com/catalog/item/5675532/5556610.htm
Dec 08, 2009 | Microsoft Xbox 360 Console
I play for +- 30 min and the powersupply goes on red is it the powersupply or the box
If you are getting a red light on the Xbox 360 power brick, That happens when the power supply gets to hot or its not getting enough juice. Try plugging it in somewhere else and see if that helps, and make sure not to use any UPS, surge protectors or power strips to plug in your AC adapter
also check if the power connector is firmly connected or not behind your xbox 360, if you still have a problem, check if you can borrow another Xbox 360 from anyone you know and swap the adapter and console which would help you know where the problem is
If none of this works, call up Microsoft for further help and support, since your problem may require servicing of your console.
If you are getting a Red Ring of light on the Xbox 360 power button, please clarify since it requires separate diagnostics.
Hope you get back to gaming on your Xbox 360 ASAP
Dec 01, 2009 | Microsoft Xbox 360 Console
Plugged in powerless 360
The power adapter would have gone green when it was working normlly, its what it does, you need to replace the power adapter 'brick' as it is either faulty or was over heated due to travel. Good luck.
Nov 06, 2009 | Microsoft Xbox 360 Console
Fault alrm
contact xbox customer support for possible replacement, just in case of u left the powersupply to cool down for few hours and didn work.
red light either means, powersupply overheating or powersupply faulty
Jun 20, 2009 | Microsoft Xbox 360 Elite Console
Power cuts off
Might be a faulty power supply mate , when you turn the xbox on observe the power indicator on the power brick.
Green means its okay
Amber means the console is in standby
Red means the Brick has had it.
Try a friends power brick to see if it does the same.
jonno
Sep 03, 2008 | Microsoft Xbox 360 Console
XBOX SHUTS OFF.
You could have a faulty power supply. Have you checked to make sure everything is hooked up properly? When you turn your xbox on have a look at the light on the power brick, its usually green when its working fine and orange when the xbox is turned off, if its red there could be a problem with it.
Hope this helps
Jan 09, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
77 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
