Question about Northern Industrial Tools Horizontal Air Sander 7" Dia, 5.3 CFM, 90 PSI, 4500 RPM
WHAT TYPE OF AIR SANDER WOULD YOU RECOMEND TO SAND MACHINERY WITH HEAVY COAT OF ENAMEL PAINT
  • 285 Answers
A random orbit air sander with a fairly course grit paper would probably do the job well. At least 60 grit or even down to 40 grit should remove almost anything.
Posted on Jun 03, 2009
How many Types of Power Sander?
Power sanders are really helpful tools that help the sanding job done in fewer minutes but usually takes hours by hand. The amount of effort requires while removing old peeling paint depends upon the type of sanders is used. If you pick a wrong tool, all your effort may go in vain. Different sanding machines have different specific utilities.
more details Category Sanders
Mar 14, 2018 | Tools & Hardware - Others
I have an inside door that I would like to paint over. It has a coat of polyurethane on it as well as the panes. I am thinking of using sand paper to scuff
That is a good idea. It would help to use a primer also. You can get the primer paint tinted so it is easy to cover withe the final coat of paint.
Jan 03, 2018 | Sander Tools & Hardware - Others
Paint flaked off. How to repaint?
Scrape off any loose paint. Sand it down, removing any rust. Use an enamel spray paint primer first. Then finish with a good quality exterior spray paint like rustoleum. Put on a few thin layers of paint allowing it to dry between coats.
Feb 21, 2016 | Garden
I have an old white refrigerator that works fine, just looks awful. What can I do to the face to make it look nice. I have wooden oak kitchen cabinets and a tile floor.
Paint it with white enamel.
Enamel Paint finishes in high gloss if you want that sort of finish.
Always paint in a dust free invironment with plenty of ventiallation.
With the expensive cost of many home appliances, sometimes replacing an old refrigerator is out of the question, especially if it still works well.
This can be a problem if you've recently painted your kitchen or if you're just sick of looking at an old, outdated fridge.
Instead of learning to live with your boring or unattractive refrigerator, you can give it a bright new look with a few coats of paint.
Mix a few tablespoons of vinegar into a bucket of warm soapy water.
Use this mixture to clean the refrigerator.
Scrub away any grease, dirt or other grime with your soapy water and a stiff bristled scrub brush. Wipe the refrigerator dry with a towel when it is clean.
Use painter's tape to cover parts of the refrigerator you do not want to paint such as the handle or the grate at the bottom of the refrigerator.
Apply a coat of appliance paint to your refrigerator with a paint roller to prime the surface.
You can also purchase appliance paint in a spray can and use it to spray paint your refrigerator.
Sand the paint with an extra fine grit sanding sponge when it is completely dry.
Try to make the surface as smooth as possible and then wipe away any dust created with a clean towel.
Paint the refrigerator with an enamel paint tinted to the desired color and a paint roller.
You can use oil-based or latex-based enamel depending on your preferences.
Oil paints usually have a stronger odor than latex paints but they may last longer.
Apply a second coat of paint when the first coat is completely dry.
Sand the final coat of paint when it is dry with a wet extra fine sanding sponge.
Spray the refrigerator with water while you work to keep it damp and keep sanding until the paint is smooth and shiny.
Remove all of the painter's tape from your painted refrigerator.
Sep 08, 2013 | GE Refrigerators
Paint colour for 1973 tx750 yamaha
Can duplicate the 73 paint but it is gold candy over silver metal flake.
  1. apply Grey primer sealer
  2. apply silver base coat, apply 3 coats
  3. apply silver metal flake mixed with clear, about 3 coats
  4. apply about 2 coats heavy clear
  5. sand clear smooth because metal flake makes it rough
  6. apply about 3 coats of tinted clear (candy gold or yellow)
  7. let it dry, inspect it, wet sand with 600 or finer
  8. apply final coats of clear to all parts except the fuel tank, apply only one coat to tank
  9. lightly wet sand the tank
  10. paint the gold and black striping on the tank, don't have any stickers and paint is thinner
  11. apply 3 medium coats of clear to the tank
  12. west sand with 1200 grit and polish all parts
  13. mix huge glass of good tequila, get lawn chair, sit back and admire
hope this helps
John
May 23, 2011 | Yamaha TX 750 Motorcycles
Orbital sander flicking the sand paper off
You did not specify how the sanding discs are meant to be attached to your sander's backing pad.  My experience with this type of problem is material from the sanding process builds up on the backing pad and does not allow the sanding discs to adhere properly.  If you have a velcro type system, clean the hooks on the sander's backing bad by soaking the pad's face in a plate of paint thinner for 20 to 30 minutes then use a wire brush to remove the rest of the paint physically.    For adhesive pads clean the sander's backing pad surface with denatured alcohol.  Do not use isopropryl or rubbing alcohol as this may not be 100% alcohol and could contain a lubricant like glycerin.  When the sander's backing pad is completely dry and clean it will hold adhesive backed pads fine.    Flaky paint is best scraped off before sanding, use a wide putty knife or a paint scaper to remove large flakes before sanding.  This will minimize airborne dust and cleanup.    For best results with adhesives, always keep your surfaces  clean!    Good luck and happy sanding!  Michael Mittelsdorf
Jan 07, 2009 | Bosch Power Tools Sanders Orbital Sanders
Painting The Frame
Your going to have to sand prime sand prime sand paint. Just increase the grit number each time, there has to be some adhesion
Nov 20, 2008 | 2006 Honda CBF 600 ABS
PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Aug 30, 2008 | Microwave Ovens
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Microwave enamel wearing away
It will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Enamel should work, but appliance paint is better.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 20, 2008 | GE JVM1650 1000 Watts Microwave Oven
Northern Industrial Tools Horizontal Air Sander 7" Dia, 5.3 CFM, 90 PSI, 4500 RPM Logo
69 people viewed this question
Top Northern Industrial Tools Tools & Hardware - Others Experts
john h
Are you a Northern Industrial Tools Tool and Hardware - Other Expert? Answer questions, earn points and help others
