Question about Compaq Presario 2100 Series: 1170B01-90 (COMPAQPRESARIO2100SERIES) CD-ROM Drive
Argon PXE Boot Agent v2.01 2002 - PXE - E61
I have a presario 2100. when boot I get the following:
PXE -E61 media test failure check cable
and does not boot. I have used Hirens 9.5 and
the c drive has 0 blocks. I also used Super Winpe UBCD PRO and the C drive has 0 blocks.
what is up with that!
    Genius:
  • 1,552 Answers
Your computer tries to "boot" from several devices:
* floppy-disk
* disk-drive
* CD-ROM
* USB memory-stick
* over a network, via PXE (Pre eXecution Environment)
If you have a network-cable connected to the Ethernet port on the computer, with the other end connected to a "boot-server", then the Operating System can be loaded over this network-connection.
But, if you get "media test failure" and "check cable", then the network-cable for PXE is either non-working or not-present.
Any disk-drive that shows "ZERO" blocks is very probably a DEAD disk-drive. Replace it.
Posted on Dec 28, 2014
3 Suggested Answers
  • 108 Answers
SOURCE: PXE-E61: media test failure check cable
"PXE-E61 Media Test Failure, System won't boot"
1.Go to Bios Settings
2.Remove LAN booting from booting options...For laptop ,type "X" on the LAN booting option.
3.Save The configuration(F10)
This Will Solve this problem
Posted on May 25, 2009
  • 10406 Answers
SOURCE: PXE-E61
Your disk-drive has failed.
So, your computer tried to boot itself over the Ethernet network,
by "broadcasting" a request for booting. When either the network-cable was _NOT_ connected, or when _NO_ computer responded to the "broadcast" message, you get "PXE: media failure".
Take your computer to a qualified technician,
to remove the "dead" disk-drive,
to replace the disk-drive,
and to reinstall Windows.
Posted on May 27, 2009
Booting problem, screen message: Intel (R) Boot Agent FE v4.1.18 Copyright (C) 1997-2005, Intel Corporation PXE-E61: Media test failure, check cable PXE-MOF: Exiting Intel Boot Agent. Operating...
HI there,
The "Error" texts saying:
Are completely normal. This simply states that there is no external cables plugged into the specialty inputs on your toshiba laptop.
The "operating system not found" is stating that your existing hard drive is either A) dead or B) been erased.
Try to re-install your operating system, if it finds no hard drive, you'll need a new one!
May 04, 2011 | Toshiba Satellite M105-S3041Notebook
My laptop does not work it says PXE-E61:Media
Put 'Hard Drive C:' before 'Network' in the boot order
(If the hard drive does not appear in the boot order, that's why the PXE network boot agents start)
Note : Check that the hard drive is seen in the BIOS setup
Cause:
PXE (pronounce Pixie) is an agent used to boot on to the network
It's using the DHCP protocol to localise a server where the image of the OS is located
In order to PXE boot press F12 at startup or configure the boot order in BIOS to display 'Network' before 'Hard Drive C:'
If, for any reason, the hard drive is not seen the computer will attempt to boot on the network controller.
That is caused by the hard drive is missing, unplugged or failed
Jan 11, 2011 | Acer TravelMate 4062LCi Laptop Charger...
I turned laptop on and get this message over and NVIDIA Boot Agent 249.0542 Copyright (C) 2001-2005 NVIDIA Corporation Copyright (C) 1997-2000 Intel Corporation PXE-E61: media test failure, check...
your harddrive is either failed or your harddrive master boot record is corrupt and you will have to reinstall windows or the linux you used
Dec 14, 2010 | Computers & Internet
When I turn the computer on, I get the following message: PXE-E61 media test failure, check cable PXE-M0F exiting intel boot agent Reboot and select proper boot device or insert boot media in selected...
This happens when the BIOS can't find the hard disk. If you're lucky it's just the hard disk that has failed, if you're not it's the motherboard itself the one that failed.
To find out which replace the hard disk with a good one then try to boot in th BIOS - if you can it's the hard disk, if you can't it's the motherboard.
Nov 26, 2010 | Gateway 510 X (10272197) PC Desktop
PXE-E61 Media Test Failure Check Cable on compaq presario 2100
A PXE-61 error message is most likely a faulty hard disk.
Try reseating the hard drive first and if you still get this error message again then you need to replace the hard disk.
To boot up with the CD you maybe able to press the F12 function key when you power up the laptop, this will bring up the a menu option to select an alternate boot device. If this option is not available then go into the BIOS configuration and change the bootup order and make the CD as the first boot device and the hard disk as the second device. You can can it back later.
Sep 14, 2009 | Compaq Armada E500 Notebook
Replaced Toshiba HDD but won't boot from recovery CD
Put the disk in the drive and restart the machine, when the toshiba logo appears press F12 and use the cursor key to select CD/DVD and hit enter.
See if it lets you boot from the CD/DVD drive.
Please keep me informed and good luck.
May 29, 2009 | Toshiba Tecra TE-2100 Notebook
May 25, 2009 | Compaq Presario-Notebook 700 Series, 2500...
Boot
sounds like hard disk faliure, suggest getting a new hard disk or perhaps attempt a system reinstall. Its not the fan but the hard disk.
Geoff
Aug 28, 2008 | Tablets & eReaders
PXE MOF problem
First, try and access your cmos setup. Look to see if your harddrive shows up.
Apr 06, 2008 | Toshiba TE2100 Notebook
Computers & Internet Logo
743 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
