Question about Compaq Presario 5000 PC Desktop
About hard disk
Sir,
     i using compaq presario laptop.there is a problem that my laptop is not working .Showing a problem your HDD is not properly connected or not switched off. i am in a big trouble so Sir, What i can do .............ple help me.
  • 3 Answers
I am assuming you got this error while trying to install Windows XP. If so, The solution to this problem will result in the LOSS OF ALL DATA ON YOUR HARD DRIVE. This is a two part process.
1) Check to make sure hard drive is seated in laptop well.
   Enter BIOS and ensure that your hard drive is detected. If not, try the auto detect feature that most BIOS' have and see if this detects your hard drive. If not, try restoring the BIOS defaults and see if that works. If not, hard drive may be bad.
   Continue to part 2.
2) Insert your Windows XP CD and boot computer from the CD and wait for setup to load.
  • At the Setup Notification screen, press Enter to continue.
  • At the "Welcome to Setup" screen, hit Enter to continue.
  • Read the Windows XP Licensing Agreement and press F8 to agree.
  • On the Xp Setup screen, you'll create an installation partition, but first some housekeeping. If you have any existing partitions you must delete all of them before proceeding.  After deleting all partitions, select "Unpartitioned space" and pressing Enter. And then press Enter again to confirm the partition size as is (it should already be set to the maximum size).
  • Next, select "Format the partition using the NTFS file system" and press Enter. Xp will now install.
If the same error appears then the hard drive is probably bad.
Posted on Oct 25, 2007
Just replaced my hdd on Compac Presario 2100 but the system is not detecting it.
This model laptop came with a 60Gb hard disk and if you installed a much larger capacity hard disk then the BIOS cannot detect this hard disk.
For the BIOS to detect a large hard disk a BIOS upgrade is required (if there is one available) Check the HP/Compaq WEB site to see if there is a BIOS upgrade.
If not the try a 120Gb or smaller capacity hard drive.
As an alternative -
You can keep the existing hard drive in your laptop and use an external USB hard drive to store your data.
Nov 10, 2012 | HP Compaq Presario 2100 Laptop
How to install sata driver while i setuping xp on it.....now blue screen is showing telling that to reboot pc or do chkdsk
for blue screen : just change slot of ram or change ram.. for sata driver : just insert partitionmagic disk and partition your hdd.. otherwise clean your hard disk using any hdd utility or Hiren's Boot CD
Aug 12, 2011 | Compaq Presario Notebook
I took out my hard drive in my Compaq Presario V2000 laptop...and I'm not sure what type it is..like an IDE, SATA...and whether it needs a 2.5 or a 3.5
Hi
Normally a laptop computer using the hard disk type 2.5 "
Here I attach the hard drive example for your reference.
Pic 1> 2.5" IDE HDD
Pic 2> 2.5" SATA HDD
Tq and regards
Mar 21, 2011 | HP Compaq Presario V2000 Notebook
Compaq Presario C700 sled off bed. Getting error
Your hard drive came loose i would take the cover off your hdd and remove and then place it back in should fix it but if not then you need a new hdd.
Oct 24, 2009 | Compaq Presario 700 470024-192 Notebook
Asi gave mine laptop compaq c700 pc notebook to hp service centre for check up. they told me that there is a hard disk problem .so the problem was "HDD test fail & check with another HDD.& all...
Only Hp knows what that means in their diags. Get it shipped back and take it to a Locally owned PC shop and have them take a look at it. It is possible that you have just enough file fragmentation and file structure corruption that it is fail diags. Why did you take it in to be looked at anyways?
Sep 11, 2009 | Compaq Presario 700 470024-192 Notebook
HDD Upgrade and Specs for Compaq Presario M2000
Yes the M2000 will support at least an 80GB hard drive.
Jun 11, 2009 | Compaq Presario M2000 Notebook
Samsung Hard Disk MP0804H
maybe your HDD are not compatible in your laptop. try to look it in your manual if it is compatible or not.
Jan 29, 2009 | Samsung (MP0804H) 80 GB Hard Drive
Compaq Presarioe A900
Webcam driver probably did not install properly.
Go to Device Manager. Unistall the Webcam. Reboot.
Vista will scan for new hardware, locate the Webcam and reinstall the driver.
Good luck.
Jan 15, 2009 | Compaq Presario Notebook
Does not startup or boot, displaying a blank screen
remove the battery and try to start the machine om AC power only
regards
Nov 26, 2008 | HP Compaq Presario v3000z Notebook
Blank screen on start up
It means that your system cannot detect Windows on your hard drive. Check the connections inside if you can. If everything is connected properly, then your hard drive is probably is at fault. You can do a disk check in dos but may not be accurate.
Oct 30, 2007 | Compaq Presario M2000 Notebook
Compaq Presario 5000 PC Desktop Logo
88 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
