Question about Samsung CLX 3160fn All-In-One Printer
Transfer belt nees replaced
I need to replace the transfer belt on clx3160 fn and can't find one at a reasonable price & how difficult is it to replace if i do order one?
    Champion:
  • 220 Answers
Find samsung dealer,not hard to replace.
Posted on Jun 26, 2009
97 Dodge Ram Transfer case locked up would that also be reason truck wouldn't move and when in park it rolled
Transmission Failure of some sort
You never replace a transfer case,you repair yours
What your given with the tranfer is a junk yard unit
If your going to put more money into a 16 year old
& badly rusted dodge & they all rust terribly underneath,
then install Jasper Engine & Trans units
Time to part with it,too old,too rusty,& no reason to have
spent what you did
I bought a 1992 dakota new & only did the water pump in over
18 years,then donated to the veterans & took $500 tax credit
Feb 01, 2013 | Cars & Trucks
My printer can`t print and shows me to 'Check the transfer belt'
Your printer monitors the life of your transfer belt. When the transfer belt reaches the end of its
life, the printer displays
80 Belt Exhausted. This message indicates it is time for you to
replace the transfer belt. For best print quality, make sure you replace the transfer belt when
80 Belt Life Warning.
Press
Go to clear the message. The Supplies message appears on the second line of the
display to remind you that supplies need attention. You can open the Supplies Menu to see
80 Belt Exhausted
or 80 Belt Life Warning messages.
The printer continues to display the
Supplies message until you replace the transfer belt. To
replace the transfer belt, use the following steps or the instruction sheet supplied with the
transfer belt.
Nov 26, 2012 | Samsung CLP-610 Series
How can i order the transfer belt for a samsung clx3160fn
The part number is JC96-03611C. Though it might be difficult to find at a local store, you can find it online. Places like facsimile.com or printerbuddy.com stocks it.
After you remove the old one and replace it with a new one. The replace transfer belt error message will not go away until you clear the transfer belt count on your machine. To do this, you will need to follow the steps below.
1. Enter Tech Mode by pressing [MENU] [#] [1] [9] [3] [4]
2. If you do not see the Tech Mode menu press the menu button again. (You need to enter the key sequence quickly.)
3. Select Tech Menu
4. Select DataSetup
5. Arrow to Clear Counts and press OK
6. Enter Password 1934
7. Arrow to Transfer Belt and press OK.
Hope this helps you.
Nov 29, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160 fn printer, approx 1.5 yrs old. Has worked well, however now the right side of each page is slightly faded compared to the left side. I have cleaned out what I can and replaced...
I'm not sure if it is a similar problem but I have a CLX-3170FN and it has started to run a strange line down the page, and part of the page was smudged. I cleaned it all out and looked at the drum etc and it was all fine. Then I spotted there is a plastic belt that must run like a conveyor belt behind the drum and there is a split running along it - Found out it is called the transfer belt. It was difficult to see which I why I am suggesting it to you. Now I just have to find how I can replace mine. :)
Feb 22, 2010 | Samsung CLX-3160 All-In-One Laser Printer
My Samsung CLX3160 prints very faintly (colour & b/w)
I have instructions on how to clean the developer blades. It should fix the faint printing that you are experiencing. It is posted in my Tips section.
Jan 08, 2010 | Samsung CLP 300 Laser Printer
Replace transfer belt won't scan or print
Unless you are a DIY er. Callin supplier or repair engineer.
Remember check to make sure what their charges are like set price callout charge?
Are you due to replace???
Nov 12, 2009 | Xerox Phaser 6110MFP/X Laser Printer
My window is showing "replace transfer belt soon" what is that and where is it and where do you find a transfer belt?
www.precisionroller.com will have the transfer belt, and it comes with instructions to replace. At precision you can get the part number and search the internet for a better price.
Nov 03, 2009 | Samsung CLX 3160fn All-In-One Printer
Says transfer belt error, do i need to replace or can i fix?
HI,
The Transfer Belt error is because it is not correctly installed or it is defective,if so it need replacing.
You can Pull out of the Drum Unit, open front door and take out the whole assembly
Then you can look on the Transfer Belt, You can pull it out,
CAUTION: it is difficult to get it back into position again if your not sure what your doing.
You can replace the belt for around $40/$60 for the item + technician fees
Please RATE THIS SOLUTION
RNJ VINOD KUMAR
Sep 24, 2009 | Samsung CLP 300 Laser Printer
Have error code sc457 on copier, have received detailed instructions on how to fix it, but I need to know how to open it?
SC457 Position error for the image transfer belt’s cleaning unit
- Timing & Condition
• When the belt cleaning section touches the image transfer belt, but the belt cleaning sensor signal remains LOW.
• When the belt cleaning section releases from the image transfer belt, but the belt cleaning sensor remains HIGH.
• Dirty Sensor
• Defective sensor
• Defective belt cleaning shift clutch
• Defective drum peripheral component motor
• Defective I/O control board
• Defective main control board
1. Pull out and re-insert the image transfer belt unit.
2. Clean the image transfer belt cleaning H.P. sensor.
3. Replace the sensor. (Input Check: 5-803-012)
4. Replace the belt cleaning shift clutch.(Output Check: SP5-804-036)
5. Replace the drum peripheral component motor.
6. Replace the I/O control board.
7. Replace the main control board. [Signal Check]
• H.P.: CN219-B2 or TP108 on the I/O control board
The above information are taken from the service manual.
Good Luck!!!!!!!!!!!!!
Sep 20, 2009 | Office Equipment & Supplies
Clx3160 bought in11/07 used 12 times will not turn on
replace ac power supply,or thay may call it a print engine control board
Jun 20, 2008 | Office Equipment & Supplies
Samsung CLX 3160fn All-In-One Printer Logo
203 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
