Question about GE JE1460 Microwave Oven
When the micro is not being used it out of the clear blue sky comes up f3 with the 3 loud beeps. When it is being used everything is okay
  • GE Master
  • 9,098 Answers
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad.
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and please do not leave it running unattended.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
Feel free to contact us with your full model number and we can tell you if yours is one of these models, and if so, we'll also give you the part number you need to order and a link to the best priced supplier.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on Jun 04, 2009
Magic chef microwave just stopped heating, can you tell where the fuse is so i can check it, and i am open for any suggestions. model # hdm111ow
Sounds like the magnetron has failed, if it were the power supply or capacitor or fuse, it would have failed to heat straight away, not faded out. Probably more economic to replace the machine.
Feb 22, 2017 | Magic Chef Microwave Ovens
What is the first thing to test on my micro that is acting up?
Microwaves are not very user friendly when it comes to servicing the. They generate very high voltages and are very dangerous to try to repair without the proper training.
Nov 08, 2014 | Microwave Ovens
My microwave is making a very loud noise and not heating food.
Try plugging it into another outlet and see what happens.
Jun 27, 2017 | Frigidaire FGMV174K Microwave Oven
Maytag microwave going crazy
< - Let ME know your full model number from the tag and I can give you complete detailed instructions on how you or a friend can fix it.
"SE" means you have a shorting membrane keypad.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Jan 05, 2014 | Microwave Ovens
Frigidaire microwave has annoying beep, can it be turned off? model no. FFMV162LQA
Hold the 2 button and Stop button at the same time. To restore hold 2 button and Start button at the same time for 30 seconds.
Aug 19, 2012 | Kenmore 80809 Microwave Oven
The oven makes a loud humming noise when turned on, doesnt heat food, everything else works
This is most likely a bad magnetron, but it could also be a bad high voltage diode.
I would check out this website
http://www.applianceaid.com/micro.html
Or you could call a local Appliance Repair Technician
Dec 10, 2010 | Kenmore 62642 / 62644 / 62649 Microwave...
When we start it does not heat up the food.
If it doesn't make any loud noise when it turns on check the micro switchs on the door
one is not operating and is putting the microwave in the safe mode. It thinks the door is open.
at 6 bucks each change them all. just use the right ones at the 3 different locations.they come out of. No power and do one at a time and remove the micro holder from the microwave it's easyer to work on. Take note to the McDs microwave behind me....
Dec 03, 2010 | Sharp R-303CW Convection / Microwave Oven
Spacemaker beeping loud and f3 message driving us crazy
The error code F3 indicates an oven sensor problem. The oven sensor is most likely the failed part. The oven sensor probe must have the correct resistance readings at specific temperatures. When the electronic range control (ERC) cannot identify the correct resistance of the oven sensor or the resistance is way out of specs F3 will display.
I recommend calling a service technician to diagnose and repair your oven.
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
On the face of the microwave that displays the time, we just noticed ////////////along the bottom of the display under the time, we unplugged the microwave and tried to reset it, but no change
ok if memmory serves me correct
press the pause clear button with start button at same time
holding them for 5 seconds the micro should beep then press1 3 5 7 for the reset micro screen its been a while since i serviced a micro but i believe this is correct display reset config for micro
Jun 02, 2008 | GE Microwave Ovens
Microwave made a loud pop,won't heat,sounds like it's only on half power, makes a low intermittent hum
This is almost certainly a blown high voltage diode.
Please reply back with your brand and model number so we can help you.
May 31, 2008 | Microwave Ovens
GE JE1460 Microwave Oven Logo
78 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
