Grandma's nylons wrapped around the bottom of the agitater
Simple as that i need to know how to remove the agitater so that i can untangle the nylons. i've removed the cap off the top of the agitater and then removed a bolt  ()bout 3 inches long) however it still won't come off.
  • missconnie Dec 14, 2007
    I have the same issue with clothes being wrapped around the bottom of the agitater. What parts are needed to fix something like this issue, or do I need to wait until I get the agitater off to see?
  • Washing Mach... Master
  • 909 Answers
Now you need to pull upward firmly but hard.  there are small splines holding the agitator in position. carefull if the agitator has two parts to it as there are usually plastic (dogs)inside which could spring loose if you are not careful.
Posted on Oct 24, 2007
Clothes & sheets get wrapped in agitator and it makes a loud noise in my Whirlpool wtw4800xq1
Here is a video on how to change a part that could be part of the problem, the video shows how to remove the agitator so that you can remove the clothing that is jamming the machine,
Jul 30, 2016 | Whirlpool Washing Machines
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
Jul 27, 2014 | GE GTWN3000MWS Washer
I need to know how to replace the nylon cord in my FS 55RC trimmer.
Hi s cowdroy, I will try to help you out. You have to remove the spool from the head. There are different ways this is done depending on the brand. At the bottom you will see different systems, that you either turn or just pull out. You will have to try just pulling or turning and also some might have left hand threads. As you remove the spool remember how everything goes back in. When you look at the bottom of the spool, different brands have different ways of attaching the cutting cord. One will have an eyelet, another will have holes that the cord fits snugly, etc. Some manufacturers use tape, and that is what I use on every machine I restring. I use packing tape, I wrap it around the cord and then tape it to the bottom of the spool. On the spool will be indicated the way to wrap the cord. When wrapping the cord do it in neat rows to prevent tangling that you will have to clear all the time. Something else to prevent tangling, is to wrap the same way you unwrap it, in other words put the spool and the roll of new cord end to end, and as you roll it on the spool you unroll it from the new roll. I hope you understand what I mean. Do not put too much cord on the spool, leave about 1/4" from top. To install the spool make sure it is the same way you took it out. Insert the cord through the eyelet of the head and install the spool in the same way it came out.
Hope this is helpful. All the best and good luck. Denis.
Feb 23, 2011 | Garden
Agitater will not rotate around...seems mdo i remove?..form top? or bottom?
Assuming this is a kemore,whirlpool washer:
Remove top cap and innner cover. Remove 7/16 bolt and pull up on agitator.
Oct 27, 2009 | Washing Machines
Outer tub seal
you must first remove the agitater,then remove the inner tube,you'll need a spaner wrench,you now can see the tub seal,how you need to remove the 3 bolts around the bottom of the outer tub,now you can remove the outer tub and replace the tub seal,or use some 3m gasket seal,up to you,you can get a new tub seal on line for $10,let me know how you do-mike
Nov 03, 2008 | Kenmore 24032\24036 Top Load Washer
Cord from hoodie caught around shaft
yes just reach in there and **** it up sharpley from the bottom ge just snaps on if you cant get it that way reply to me and ill give you another
Mar 31, 2008 | Hotpoint VLXR1020A Top Load Washer
withoout asking why , heres how to remove the inner tub, simple enough. theres abolt in the top of the agitator,(pop the little cover with a screwdriver). the agitater pops off, insert a screw driver under the maintop perhaps 3 inches in from both sides and pop the clips the main top leans back. Unsnap the white cover from around the outer tub and lastly there will be (2)) 1/2inch screws screwed into asolid block at bottom of agitator, thay are locking the inner tub to the transmission shaft. note the flat spot on the transmission whish the block is resting youll need to reinstall it at same point
Mar 18, 2008 | Frigidaire FWS1339A Top Load Washer
Washing Machines Logo
512 people viewed this question
Top Washing Machines Experts
