Question about Pioneer DEH-1900MP CD Player
No power to radio after new battery installed
  • 87 Answers
It sounds like you had a power spike when you installed the new battery. I would check the 2 factory fuses for the radio, one will be for the radio ignition lead and one will be just battery lead (usally assosiated with the clock). Lastly if those 2 fuses were ok you may have to pull the deck and check the fuse in the back of the deck.
If the fuses are all ok and no wires are disconnected, then its possible that something else went out. Good luck and take care!
Posted on Jun 03, 2009
Sony icf sw7600gr won't power up on battery power and showing exhausted battery symbol,only on ac adapter will work
check the connection inside the radio, switch of AC-DC connector maybe loose contact.( leak diode more probability replace it)
Nov 09, 2015 | Sony ICF-SW7600 AM/FM/SW Radio
No volume from factory radio after replacing a dying battery.
Is their any other problems that showed up after the battery change ?
Feb 10, 2014 | Cars & Trucks
Replaced battery, no power to radio now, help!
Most radios have a fuse in main fuse panel and a fuse on the rear of the unit. It is a common problem for the one on the radio itself
Jun 28, 2013 | 2002 Saturn L-Series
1999 Sonata; radio has no power. Got a new head unit, profession install, now there's no radio power and "door open" light is flashing. Help? $450 terribly spent..
please follow the line going to the battery , they have FUSE, and replace and fix it. Disonnect the battery and clean the contacts fuse and install again. The radio must be turn ON.
God bless you
Jun 20, 2013 | Cars & Trucks
2001 FORD ESCAPE - new Battery still wont start - no lights no radio no crank
With or without the fob, you should get lights. Check the installation and the battery voltage between the engine metalwork and fuses.
Oct 07, 2017 | 2001 Ford Escape
Can a new car radio kill the battery?
Yes and that was due to bad installation. I have had 3 car stereos installed on my 98 RAV4 through Best Buy and never had battery problems. I even had 2 amps installed as well but the installers had to make me buy this 200-dollar thing that would not drain the battery.
If you are getting a drain through the radio's power supply it could eventually drain down the battery if it was improperly installed, I would pull the fuse for the radio and see if the drain continues, if the drain does not stop there is another short somewhere. To learn more :
http://www.xcardiag.com/wholesale/automotive-battery-analyser-vat-560-tool-536.html
May 16, 2012 | Cars & Trucks
My Emerson CKA1000 clock radio worked great for years, but now it eats the battery back up, battery will go dead in a month or so and if I set the alarm for radio it will show the 20 ne message when the...
Sounds like the main power supply may have gone bad and you are strictly running off the battery. This is why it works fine for a while when you install a new battery, that is until that battery drains and gets too low. The radio won't play because it is preserving battery life. I bet you could unplug it from the wall and would get the same results. You essentially have a battery powered clock right now. To test this theory simply remove the battery, plug the clock up and see if it comes on. My guess is it will only work with the battery installed.
Jul 23, 2010 | Emerson CKA1000 Clock Radio
I need a new battery but if i take the old battery off i will lose my radio . had car from new 2002 52 reg nissan micra lost code card . nissan rds radio cassette
2 solutions
1. use a jumper cables from another vehicle when you take take cables off, install new battery, remove jumpers
2. install battery as normal and drive to dealer to get code after, make a note of code
note: engine will run rough for two or three drive cycles if you lose power to ECU. This is another reason to jumper battery
Dec 31, 2009 | Car Audio & Video
My mifi XM2go radio will not turn on. I have
Sounds like a bad battery. Try plugging DC adapter directly into the bottom of the unit and turn it on - does it still act-up? If so, bad radio; if it works with adapter only, then battery and charging issue.
Dec 20, 2009 | Delphi MyFi SA10113 XM Radio Receiver with...
I just received my new uniden scanner,and I am having problems with charging the radio. I was wondering do I have to have batteries in it ,to charge it with the dc that came along with the radio. How do I...
The BC72XLT is a battery-operated scanner, and your power supply is a battery charger, not a battery eliminator. You must have batteries in the unit for it to operate. You can install rechargeable batteries and use it in conjunction with the power supply, or you can run it on non-chargeable alkaline batteries.
Mar 21, 2009 | Uniden BC72XLT Handheld Scanner
Pioneer DEH-1900MP CD Player Logo
275 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
