Question about Gateway FPD 1830 18.1" Flat Panel LCD Monitor
Gateway FPD1830 Monitor Flickers then goes black
I too have the exact same problem. Just started about 3 weeks ago. My Gateway system is about 3 or 4 years old, using Windows XP media edition. I too tried different power settings, I also tried different refresh rate settings. The only way I can get the monitor on is, like you, cycle the monitor power button and while its flickering it seems I can keep it from going black for a few seconds more, if I am wiggling the mouse and tapping the spacebar. Then before it goes black I have to click on an icon. If it has an action to complete, or program to start, that seems to give it enough oomph to stay on.
  • Buddy Mcsparrin May 11, 2010
    It sounds like you have a monitor with a common problem. After a few years some LCD monitors
    will blow a power supply. The problem is caused by parts called
    capacitors overheating in the confined space of the monitor. If you are
    good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work
    fine. The capacitors do need to be installed with the correct + and -
    connections, note the stripe on the old one and insert the new one the
    same way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
    I hope this helps, if so please rate my solution.
    Buddy
    Corporate Computer
    www.ccl-la.com
    Over 21 years of computer and printer support/repair
  • 1,684 Answers
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
Buddy
Corporate Computer
www.ccl-la.com
Posted on Jul 19, 2009
    Scholar:
  • 53 Answers
After usual overheating the capacitors, the weakest spot in FPD1830 are four chip resistors located in the inverter board a bit above the middle, you can recognize them as they are bigger than others and located all four in one row. Holding by tweezers simply re-solder them to get rid of micro-cracks in the tin between pads and resistor contacts.
Posted on Sep 09, 2009
Lcd monito fpd1830 is not showing the display
If the indicator light is on but black screen, then replace all fiur caps (100uF 25vdc) with on single cap form DIGIKEY PANASONIC FM or FC, it muat be LOW ESR type! (this is very common problem, I fixed about 30 of these already)
See my pictures here: http://s807.photobucket.com/albums/yy352/budm/Gateway%20FPD1830/
The caps look OK but have high ESR as shown in my albums.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 14, 2010 | Gateway FPD 1830 18.1" Flat Panel LCD...
Gateway Monitor 22" flicks on at start up, then shuts down
Coulld be a MBR problem.Try to debug and check in safe mode.Reinstall Operating System.
Jul 06, 2009 | Gateway GT5468 Desktop PC
My Gateway monitor FPO 1975W is blinking?
Hi there, it sounds like this monitor is going out on you. Try a different monitor if you can, see if that fixes the problem!
Apr 06, 2009 | Gateway FPD1975W 19" LCD Monitor
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
Jan 08, 2009 | HP Vs17 17" LCD Flat Panel Monitor
Startup
dear sir.
"checking disc comes up" this message is hard disk message and it's showing becoust missplase of harddisk thru yr laptop scoket if u know bout laptops u need to plug off then reconnect yr laptop harddisk otherwise contact system wonder near u.. it's help u.
Jan 01, 2009 | Computers & Internet
Screen only stays on for 1 sec
Assuming you changed all the caps and did it correctly.
IF you get flickering, It could be a transistor on the inverter board.
OR !!! and probably more likely,
It could be one of the bulbs in the lcd itself is failing. It only takes one bad bulb to stop an inverter from firing up !! You can check them one at a time if you have another working monitor.
If you do unplug a good bulb from the good monitor and try each of the questionable ones, one at a time.
Doesn't have to be a gateway monitor to test it, just needs the same backlight plug.
ebays bammbammfran
Jun 05, 2008 | Gateway FPD2185W 21 in. LCD Television
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Gateway Flat Screen FPD1830
Well, this problem is going to only get worse. You can probably send it back to the manufacturer if you still have a warantee, but if you can't just buy a new monitor.
Nov 13, 2007 | Samsung SyncMaster 204B 20.1" LCD Monitor
Gateway FPD 1830 18.1" Flat Panel LCD Monitor Logo
829 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
