Question about Sony Handycam DCR-HC21 Mini DV Digital Camcorder
Wont load tape
The camcorder does not load the tape.
I put it in the tray and closes, and the process of loading the cassette starts, but get blocked halfway.
After a while, an error beep comes, and it shows "please re-insert cassette"
If i close the tray without a cassette, the tray closes just fine.
  • 6,784 Answers
HI, this is a mechanism fault beep you are hearing. the mechanism and load motor is damaged. you will need to send this unit to the Handy cam repair depot for this repair. you will need a new load motor and loading dock mechanism as well.
Posted on Jun 03, 2009
Hi Donald. not sure how many calls you get from
The fault seems to be in the sensor and the mode switch of the loading system which is connected with the main controller processor and loading driver.
This can be a failure of the tape end detector which is a IR - infra red- emitter which is placed in the center of the tape tray and MUST feed continuous signal to the END IR detectors placed at either ends.
Also the tape seems to load with a false detection of the cassette within when the tray is closed for this reason of the failure along with a possible misplaced mode switch settings. This triggers to make the loading move without a reason and so can be due to failure of the the mode switch or unbalanced settings.You will need some experience to remove the tray unit, then check on the IR sensors and also check the settings of the loading drive and mode switch.
Nov 27, 2011 | Cameras
My Canon Elura 60 is not working properly. The cassette will not load. I tried to change the power source to DC from battery, but it didn't solve the problem. The cassette tray loads fine without the...
Unfortunately, you will need to have your camcorder repaired. Inside of your mechanism there are several different components that can go bad and cause this problem. You might have a bad capstan motor or a bad gear. If you hear something spinning like crazy when you try and put a tape in, you have a issue with your capstan. Hope this info has helped you.
www.austintelstarservices.com
Sep 03, 2010 | Canon Elura 60 Mini DV Digital Camcorder
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
Cassette doesn't load and move down into machine
I had the same problem. With the camera on, keep taking the battery off and putting it back on. Start to close the door and then open it. Eventually you should hear it try to move. Keep doing it and it should move down all the way.
Jun 01, 2009 | Sony DCR-HC38 Mini DV Digital Camcorder
Loading tapes
I have the same problem. If I remove the battery for a few seconds, then replace the battery and wait about 5 seconds, the tape compartment closes.
Dec 10, 2008 | Sony Handycam HDR-HC7E DV Digital...
Mv800i camcorder
well there are certain cassettes made for that camcorder. i suggest you search for what the are called and then you can buy them
May 26, 2008 | Canon MV800i Mini DV Digital Camcorder
Loading tapes
I had a similar issue where the tape bay would not lock in and engage the motor mechanism to load the tape. I removed the battery from the unit and let it stand for approximately a minute then reinserted the battery. The tape drawer closed first without a tape then reopened with no issue. I then inserted a new tape with no issue. I guess it needed a hard reboot.
Mar 23, 2008 | Sony Handycam HDR-HC3 HDV Digital...
Zr400 wont accept cassette
You wont belive this but I found on another site something that actually works. Apparently it's called the "fonzie tap". With the camcorder closed tap the side (quite hard) and try putting the tape in again. Repeat this until it works.
I was all out of solutions so I tried this option last and it actually worked lol.!!!
Jan 17, 2008 | Canon ZR400 Mini DV Digital Camcorder
The cassette holder isn't closing......and the tape is not loading
Hi
See if this works--If you are on battery there may not be enough power .Charge the battery or use the the mains power through the transformer and see if it works.
Hope this helps
Jay
Nov 17, 2007 | Sony DCR-PC55E Mini DV Digital Camcorder
not geting in holder tht mean u must open ur casset holder and put in polethin bag for a hour and it will accept tape
Aug 14, 2006 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam DCR-HC21 Mini DV Digital Camcorder Logo
525 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
