Question about JVC GR-D270 Mini DV Digital Camcorder
My JVC GR-D270 stuck in safeguard mode error 03 Took battery out same problem. Once in a while, when I remove and replace tape the it goes into pause mode. Then I go into record and for about 3-4 seconds seems to work but goes back into pause and then the screen error, remove and reinsert tape unit in safegaurd mode 03 comes back on.
magic seadog
  • 38 Answers
SOURCE: safegaurd mode
Unfortunately this is a repair issue. There are several failures that can occur, none of which will be resolved without service, that create this safeguard situation. Often the fpc cable which carries sensor information to the micro has been injured and that requires repair. Good luck, magic seadog
Posted on Aug 12, 2007
  • 34 Answers
SOURCE: jvc gr-d270 camcorder
Please inform of error code.E0?
Posted on Sep 05, 2008
SOURCE: unit stuck in safeguard mode
I can't find e setup for sony
camcorder
Posted on Dec 30, 2008
welcomejee
  • 10594 Answers
SOURCE: JVC GR-DV3000. Goes to
If camcorder accepts normal MiniDV tape without any problem and you can record or playback it correctly then please try another brand video head cleaning tape as existing head cleaning tape might be not good that is why camcorder rejects it.
Hope this will help.
Thanks.
Posted on Mar 30, 2011
caroldon
  • 17130 Answers
SOURCE: my JVC GR-D32 keeps saying
Use a hair dryer heater into the opening tray to warm up the inside. It is possible that the DEW SWITCH is triggered and so the system goes to safe mode so that it does not entange if moisture is present on the drum. If not there are errors on the servo section and can be a failure on the board.
Posted on Jul 13, 2011
MY CAMERA SHOW E03 ;unit in safeguard mode ;EJECT AND REINSERT TAPE WHT SHOULD I DO............
JVCGR-D270.Digital Camcorder. When we put the tape in the cam it chews the tape whiles loading and says that it's in 03 safe guard mode. Please help.
Jan 24, 2011 | JVC GR-D73AG Mini DV Digital Camcorder
My camcorder is on a safeguard mode, how do i take it out of the mode
Please go further down on the message, you must see a numeric code, like 03, or 02. In case you'll see 03, open the cassette door(let it open until cassette come out) about 5 sec or more(make sure you have enough batt. charge or use adapter). Once ejected do not use that cassette again. Using new cassette and same thing happen, have your camera checked by the expert. Error code other than 03, you need to consult the expert. Hope it helps
Mar 01, 2010 | JVC GR-D270 Mini DV Digital Camcorder
I'm getting an E04 ( error) when I try to record or play
Here is some information regarding the E04 error message from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
This doesn't seem uncommon, and indicates a bad tape is loaded, or unfortunately, that the camcorder requires servicing.
May 22, 2009 | JVC GR-DVM50 Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/,
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
I am recieving error E04 "safeguard mode"
An excerpt from http://www.techlore.com/article/10974/JVC-Camcorder-Stuck-in-Safe-Mode/:
According to this, E04 denotes a problem with the recording media or the mechanical bits that deal with the tape. Hopefully trying another tape helps.
Mar 09, 2009 | JVC 580136 Camcorder
Unit stuck in safeguard mode
camcorder
Dec 30, 2008 | JVC GR-D270 Mini DV Digital Camcorder
Safeguard mode
My camera is on unit in safeguard mode and it says eject and reinstall tape! What do you suggest??
Jun 03, 2007 | JVC GR-D275 Mini DV Digital Camcorder
Unit in safeguard mode
You mix te info with Write protected tapes.
Safe guard mode is caused by the motor that takes the tape out of it's case, through the mechanics and past the video head.
If for some reason the electronics detect that it's been done by too much force, the safe guard issue promts.
Mar 29, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-D270 Mini DV Digital Camcorder Logo
476 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Steven Wander
Steven Wander
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
