Question about Nomad Factory Fender Rumble 100 Bass Combo Amplifier - 1x15" 100watt
Not really a problem want to know if I could add a extention speaker to the fender rumble 100 combo it has not ext. speaker out looking to add two 10 inch and if so how?
  • 73 Answers
Hi there. If 10" speakers are 8 or 16 ohm, parallel them. If they are 4 ohm, series them. if "External speaker" output is rated down to 4 ohm. If no external speaker jack, you'll have to tap into existing speaker jack with a "Y". Check the minimum ohm load for the amp.
Thanks
Paul
Posted on Jul 11, 2009
HI CAN YOU PLEASE TELL ME WHY MY FENDER RUMBLE 100 BASS AMP DISTORTS AT LOW VOLUME? EVEN THOUGH THE SPEAKERS IS NOT BLOWN
A common reason for 'distortion' with all bass amps can be either that the screws holding the speaker unit to the cabinet have worked loose or that there has been a build up of dust particles in the corrugations around the edge of the speaker cone, which rattle especially on the lower notes.
The solution is simple - remove the front grille and check the screws are tight. Use a vacuum cleaner to remove dust from the rim of the speaker cone.
Feb 01, 2011 | Fender Rumble 100 Bass Guitar Amplifier
Hello ! Do You have shematic diagram for bass guitar combo Fender Bass Rumble 100 / 15 ? If You have it, please snd me on my e-mail ? Regards Zlatko
Try this link:http://www.fender.com/support/amplifier_schematics.php If your amp isn't listed contact them and they will send you one.
Oct 21, 2010 | Fender Rumble 100 Bass Guitar Amplifier
Speaker has become crackly, only when i play certain notes though. I tried a different cord and bass and its definitely the amp. I have never turned the volume over three quarters, Should I just switch out...
Before changing the speaker, check for debris or other things in the cabinet or grill that MIGHT be rattling..
Also, plug in an external speaker to the ext jack and see if it is clean.
Aug 18, 2010 | Fender Rumble 100 Bass Guitar Amplifier
My Fender Rumble 25 makes a terrible crackling sound when the volume is turned up over the 4 or 5 mark. I don't think the speaker is blown as the same sound comes via the headphone socket.
Here is the schematic:http://www.fender.com/support/amp_schematics/pdfs/Rumble_Bass_Schematic_-B21.pdf Check the tubes to see if one is loose in its socket. Do not attempt to repair this yourself unless you have amplifier repair experience as it is easy to get a bad or life threatening shock without the correct test gear and troubleshooting procedures.I hope this helps.
Nov 26, 2009 | Fender Rumble 100 Bass Guitar Amplifier
Need instruction manual for a Fender 15g combo practice guitar amplifier
Here is the page you need:http://www.fender.com/support/amplifier_schematics.php Look under hard copy archives if you can't find it in the newer section. I emailed them at cosumerrelations@fender.com for a manual and schematics for a Fender Sidekick 10 and they emailed me one right away and were really nice. Please let me know if this helps.
Nov 19, 2009 | Fender Frontman 65R 65W 1x12 Guitar Combo...
My fender rumble 100 used to cut out, now it's
Suspect the input jacks. Wiggle them and see if you get anything. They get yanked sideways because the musicians don't loop their cord thru a handle and they get yanked sideways.
Also you can try spraying sparingly CRC226 into the switches and pots. You can get it at Home Depot in the electrical department.
Oct 08, 2009 | Fender Rumble Series 100/210 100watt 2x10...
I have a rumble 100 bass amp which used to work fine until now! I've had it about 2 months and have only played it about a dozen times. Today, while practicing with a new band, 90% of volume got lost. Now...
It unfortunately sounds like a blown speaker. Try getting at the speaker and gently moving the cone with your fingers. If you feel a rubbing sensation you will most likely have to consider a new speaker. Make sure you get one with the same impedance (ohms) and the same or better power handling.
Jul 07, 2009 | Nomad Factory Fender Rumble 100 Bass Combo...
Fender Rumble 100 210 pop noise then hum after strong low e note
Replace C21 (10uF/50V) and C38 (2.2uF/50V) and it will work great.
Feb 22, 2009 | Fender Rumble Series 100/210 100watt 2x10...
Nomad Factory Fender Rumble 100 Bass Combo Amplifier - 1x15" 100watt Logo
319 people viewed this question
Top Nomad Factory Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Nomad Factory Music Expert? Answer questions, earn points and help others
