Question about Dell OptiPlex™ GX270 PC Desktop
Upon reinstallation of OS the device manager is showing that the PCI Simple Communication Controller has an exclamation point...I am stumped and cannot get this to correct...Please help...oh...windows XP pro
  • 86 Answers
This means that you do not have a driver for this device. The link below leads to download location on dells website for your machine. Start by installing the chipset driver. If that doesn't fix it, try the modem and network driver sections. without looking at your machine I can't be sure which driver you are missing. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_CEL_GX270&os=WW1&osl=en&catid=&impid=
Posted on Jun 03, 2009
Pci simple communication controller
PCI Simple Communication Controller is a 56k PCI Modem, to know which exactly you have, use Unknown Device Identifier ( Download Here for free ), that will tell your the Model and Manufacturer, then Google for the drivers.
Sep 27, 2013 | Western Digital Computers & Internet
Hi sir, I need help on my pc, i install a usb 2.0 pci to usb card on the mother board but cant get it working, i have on device manager under other devices have an exclamation mark on universal serial...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Available in this download are drivers for VIA USB 2.0 host controller on a system running on Windows 98/98SE/Me. Due to licensing agreements, USB 2.0 drivers for Windows 2000/XP are not available for download. They are supplied on CD with new mainboards or available through Windows Update. This version is a bug-fixing release.
hope this helps
Jul 30, 2011 | NEC Televison & Video
Hi, I've just installed OS. In Device Manager there are exclamation marks by Ethernet controller, Network controller and PCI simple communications controller. I've tried emachines...
You should install the drivers from this link:
http://support.gateway.com/us/en/emac/product/default.aspx?tab=1&modelId=3333
Install the chipset driver first, the you install LAN driver and the appropriate Wireless LAN driver. You would probably find which wireless card you have by looking under your computer, there should be a sticker.
Jun 05, 2011 | E-Machines Computers & Internet
Pci simple communication controller is missing
if you are having trouble with your drivers
here is a general look at the drivers and how to update them
if your computer came with a motherboard disc the drivers could be on it
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver hope this helps
May 05, 2011 | Computers & Internet
In my computer -- properties-- hardware -- device manager -- PCI SIMPLE COMMUNICATION CONTROLLER IS SHOWING QUESTION MARK- DRIVER IS MISSING. MECHINE IS COMPAQ
ports(com&lpt)right click update driver hope this helps don
Mar 09, 2011 | Compaq Computers & Internet
In the device manager (start button, right-click computer, properties, then select device manager) right-click the PCI simple communications controller entry that I assume has a yellow exclamation mark. Then, select properties, and select the details tab of the properties box. In the 'Property' pull-down box, select Hardware IDs. In the "Value" box below you will see the information that tells you what part of the computer is having an issue, but it will be in code!
The code will look something like: PCI\VEN_10DE&DEV_026C&SUBSYS_81CB1043&REV_A2
To crack the code, take the numbers/letters after VEN_ and DEV_ and enter them in the vendor and device search boxes at www.pcidatabase.com . This will tell you the common name of the component in question (for example, IDT High Definition Audio Driver by Intel Corporation).
Once you know the device in question, you can get the appropriate driver to install. This may be an onboard component of your motherboard and require a trip to MSI's download page for this motherboard's drivers: http://www.msi.com/product/mb/K9MM-V.html#/?div=Driver
More details can be provided if you post which operating system you are using and the results of the device info lookup described above.
Jan 30, 2011 | MSI K9MM-V Motherboard
PCI simple communication controller not installed.
First u have to install Microsoft Universal Audio Architecture .... that is UAA. then check in the device manager that is under system devices "pci bus" has excl. sign (i.e. ! ). Delete the pci bus device with exlc. sign. and press the button in the upper side of this window "scan for new hardware" it will automatically install the pci bus device and ur sound comes...
Jun 29, 2010 | Intel D845GVSR Motherboard
Device manager shows a big question mark on multimedia audio controller and PCI simple communications controller, dont know manufacturer to find correct driver, let me know how to find manufacturer of
The reason for these 2 big question marks is that Windows device drivers for the sound card & modem are not installed.
If you don't have the drivers for these 2 cards, let me now the make & model, & I can find them for you.
Apr 12, 2009 | Computers & Internet
hello
mistake how can they format a computer and call it mistake?hm
anyway
it seems like they havent installed the modem drivers. do you have a modem in your computer?
what is your model of your computer?
if you go controllpanel>system>hardware tab->device manager. do you see several questions/exclamation marks or is it just one?
if you want to solve this quickly contact me true live support.
Aug 14, 2008 | Computers & Internet
Reloading software, Hard drive replacment
i hope u re install your operating system,
after the re installation u did not install the drivers that is the reson, best way u buy an ethernet card and try to get net connection and down load the drivers from dell.com ,then remove the card ,thats it.
Jan 15, 2008 | Dell Dimension 4600 PC Desktop
Dell OptiPlex™ GX270 PC Desktop Logo
271 people viewed this question
Alun Cox
