Question about McCulloch 26cc Gas Blower Mcb3208
Trimmer wont run unless fully choked - McCulloch 26cc Gas Blower Mcb3208
  • 1,040 Answers
The carburetor needs cleaned or you need a new carb. kit. If you need tips on how to do this, just let me know.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 08, 2009
    Did this solution solve the problem?
    Jim
I have a 30cc ryobi trimmer that will start but not run unless the choke is fully on. The moment I use the throttle or turn off the choke ,it dies. what could be the problem? thanks.
Hi Guy:
The first thing I would check would be the fuel filter.
Try pulling it out and giving it a really good clean.
Probably a good idea to put fresh gas in at the same time if it's been sitting for a while.
Aug 11, 2015 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Gas Trimmer will not stay started
Many times with a gas mix, after sitting for a while, the mix separates and gums up the carb. Taking the carb off and soaking it overnight in a parts or carb cleaner and running carb cleaner through the tank and gas lines will cure this.
Jul 02, 2008 | Ryobi 15" Electric Factory Reconditioned...
How come weedwacker tries to crank while on choke but when you move lever to 2nd position it tries to crank? but wont
When mine does that I go back and reprime repeating the process. It seems the gas does not feed up fully with the initial priming effort. Once it starts I move the choke lever quickly on way or the other to see if I can keep it running until it gets warmed up. Sometimes I have to adjust the choke setting even after it has run for a while.
Sep 21, 2014 | Craftsman WeedWacker Gas Trimmer 25cc...
Why does husqvarna 123hd60 bogs on revs
Mix up some "carburetor & fuel injector cleaner" in a batch of fuel, Nathan, at the rate specified on the bottle of cleaner. Run it through the hedge trimmer just like normal fuel. For right NOW, you can use the choke to keep the trimmer running. As the cleaner works, you should need less & less choke to keep it going.
It may take a while.
Next time you store that trimmer for winter, drain it fully and run it until it dies from lack of fuel. Then it won't form varnish on the carburetor jets over the winter - that varnish is what's causing your problems now.
Aug 04, 2014 | Husqvarna 123hd60 Handheld Dual Sided...
How to start
Full choke until it tries to start, half choke until it does, and once it's running, open the choke fully and wait a few seconds for it to warm up before using it, as well as 15-20 seconds to let it cool down before shutting it off so as not to warp any metal parts of the engine
Nov 08, 2013 | Poulan WeedEater Hedge Trimmer 25cc Engine
Hedger wont run unless it has choke on
Sounds like the carb is lean. Back out the adjustments 1 quarter turn and work from there. Also make sure air filter is clean.That should get ya going.
Dec 20, 2010 | kawasaki Kht600d Gas Hedge Clipper Trimmer
2002 Honda SHADOW SABRE It wont stay running unless it's
More information is needed - aftermarket pipes? any carb work been done to it? is fuel fresh? air filter condition? how are the plugs burning? oily black, white/tan?
Jul 10, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
McCulloch 26cc Gas Blower Mcb3208 Logo
134 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
