Question about AEG Lavamat W1450 Front Load Washer
AEG Lavamat W1450 2 years old,
Just moved into new house. Washing machine worked great 4 times and now when gets to spin cycle, continually trips the electrics. When we moved I put all the necessary bolts and screws in place for the move. RCD device checked in house and is OK. Anyone throw any light on what could be causing the machine to trip?
  • Anonymous Mar 21, 2014
    After approximate time of 6 mins the RCD trips
  • AEG Master
  • 909 Answers
Possibly wire come loose or try disconnecting heater element and repeat spin cycle.if runs well then, replace heater.
Posted on Oct 24, 2007
I have an AEG Lavamat 74810 washing machine which is 10 years old. On any cycle , the drum does not spin, on pressing the two left hand buttons, you get error code E52.
The E52 code indicates that the motor is not moving. This could mean the the carbon brushes have worn out, the entire motor is bad or that the wiring or control units have damage so that the message to spin is not getting to the motor.
Take off the back of the washer (after unplugging it). Inspect the motor plug and wiring to that plug. If those look okay, take out the motor and inspect the carbon brushes. If those are worn or broken, then you need to replace them. If the brushes are okay, then the entire motor or the control board are more likely to have a fault. See http://shop.aeg.co.uk/search?prpp=20&ppn=1&psfo=A&filter=category%3ALaundry%3AWashing%2BMachines and use the full product number to find out the part numbers you may need. Other sites will have these parts.
I hope this helps. Please add the product number of your AEG Lavamat 74810 if you need assistance finding parts.
Feb 15, 2017 | AEG Washing Machines
AEG Lavamat 64809 error code E30
Lavamat?! Where in the *&%^ is this machine from? Yugoslavia! I'm guessing it will not allow water IN Because only the Spin (Centrifuge) cycle works?! So if that is so you need your water inlet valves replaced, there are Two. Even in machines named after a Bar of Soap!
Jan 04, 2014 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 76400 during spin cycle blows a fuse
its not the heat element its the water pump i would say it has gone to ground try disconnecting the water pump if the fuse does not trip then replace the water pump
Jul 03, 2010 | Washing Machines
16820 dryer not working
I suggest checking the moister sensor and or cycling thermostat. the hi limit thermostat as well, with a meter for continuity. other wise you may have a bad timer
Mar 20, 2017 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
Jun 10, 2009 | AEG Lavamat 88840 Front Load Washer
AEG OKO-Lavamat 1271 VI Turbo (Washer Dryer) 7-8 years old intergrated front loaderSuddenly began clanking during the spin cycle. with no load works normally with a light load, sometimes works on some...
Sounds like the main drum bearings have failed.
At this age , I don't think this is an economical repair to undertake.
Better to replace with a new one.
Dec 13, 2008 | AEG Washing Machines
Aeg 76669 oko lavamat machine not starting all six lights [pre wash, main wash, rinse, rinse , spin, and end] flashing machine three years old just successfully completed wash cycle, loaded up for next...
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Jan 10, 2008 | AEG Washing Machines
Does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
Jan 12, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat W1450 Front Load Washer Logo
430 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
