Question about Philips Televison & Video
The back light on a portable philips dvd player is out
Its a philips portable dvd player w/screen and its backlights out. is there any way to fix that w/o sending it to the manufacure
Why is it that everyones solution is to dump it and buy another? Thats why our planet is going to ****! how hard is it to give directions to fix it rather than toss it in the trash? So far I have found 20 sites saying that they have the answer to your DVD players malfunction, untill you read the comontary you find that they all say "well you got you moneys worth, even if you only turned it on once". I say BS. to you people!!!
Posted on Sep 07, 2011
Screen is gone black on my portable dvd phillips DCP951. You can barely see the screen if you look really carefully. I dropped it on the ground. Is there a way of replacing the backlight if this is the...
Sound as if the ccfl backlight tube is busted...you may be able to fix this yourself..but getting parts may be a battle...most consumer electronic manufacturers won't sell parts to consumers..you may need to find a distributor for oem parts...one distributor I used to work for and is a Phillips parts supplier is Union electronic distributors( UED.net). Of course you will need to know the part number for the ccfl lamp tube...which you obtain fron the service manual...you may be able to get the part no. from Phillips Customer service....anyway, the lamp should either have a connector on it of may need to be soldered in..either way..it's not too hard to replace...a word of caution though..the ccfl inverter driver circuit that the tube connects to puts out as much as 2000 Volts..so be sure not to touch it while it's on..
Jan 04, 2011 | Philips DCP951 9" Portable DVD & Docking...
Portable DVD player PET719 image not available, the screen goes totally white. Sound is ok
this problem is usually common with portable DVDs.
The fault is from the flex that connects the screen to the main board.
Fault also usually comes for screen board and the screen itself.
I would advice that you take it for a checkup so that the problem would be fixed.
This problem is a common one.
I wish you the best.
Jan 06, 2010 | Philips PET710 Portable DVD Player
My dvd players screen went dark while in use
is that a portable DVD player? if so it sounds like the backlight had died on you. I would contact the manufacturer and see if it is covered under warranty.
Jun 03, 2009 | Philips Televison & Video
Change region on Philips portable dvd player
Switch the player on
Open the tray door
Press Setup on the remote control
Select Audio
Press RIGHT ARROW
Press 2,1,2,2,2,5
Press LEFT ARROW
Press DOWN ARROW
Press 0 when the screen displays region code
Press Setup to exit
Enjoy
Mar 16, 2009 | Philips PET702 Portable DVD Player
Black screen with sound answer
I found a broken one listed on Ebay that the screen still lights up and swapped the backlight panel. Works perfect again.
Dec 27, 2008 | Coby TF-DVD7005 Portable DVD Player
Phillips Portable DVD player 8.5"
Unfortunatly the " Phillips Portable DVD player 8.5" does not have expandable batterys to buy...... but i do have a tip,to make your dvd player last a bit longer " turn the backlight off,to do this go to settings" this will help!
thanks,and have a nice day!
Sep 13, 2008 | Philips DCP855/37 Portable DVD Player
Portable dvd player insignia ns-pdvd10 screen problem
Check the screen switch on the right top side where the door closes there is a little circle and the release switch usually gets jammed (this is a common defect) you will need a small thin flat head screwdriver to pry out the switch.
Jun 18, 2008 | Insignia IS-PDVD10 Portable DVD Player
WHITE SCREEN
Our Philips PET702/37 Portable DVD player has white screen, when i press the screen appears the image. please help me. thanks
Jun 07, 2008 | Philips PET702 Portable DVD Player
Phillip PET710 Portable DVD Player
The back light of the monitor might be defective. or the drive signal might not be getting to the screen you will need a schematic, multimeter, and an oscilloscope to troubleshoot this issue. This is how you will have to go about this using the schematic locate the screen test points measure the voltages with the multimeter and look at the signals with the oscilloscope. this will lead to you finding the exact problem.
Jul 25, 2007 | Philips PET710 Portable DVD Player
Televison & Video Logo
344 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
