Question about Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman riding mower just stopped moving and stated smoking like a belt was burning up??
  • 3 more comments
  • jschorr33 Jun 03, 2009
    Motor doesnt stop, just stopped goiing forward.
    In the middle of mowing tractor just stopped moving. Engine kept running and started to smoke like a belt was burning??
    could I have burned out the clutch??
    could I have burned out the clutch? Is that possible?
    why didn't you answer my question about the clutch and instead sent me send the same answer?
  • 11,896 Answers
First, check the belts to see if they are glazed and slipping. If the belts all look they are in good condition, than check your differential and transmission oil. Make sure it is not black or have burnt smell to them. They rear ends do have tendency to lock up if oil is not changed regularily
Posted on Jun 03, 2009
  • Nate Stansfield
    Nate Stansfield Jun 03, 2009
    It is very possiblly the clutch. I You may have an adjuster on the clutch cable. If you do, turn it clockwise and tighten it. If not, I would get a closer look at the clutch.
    Brigadier General:
  • 3,614 Answers
for clarification: When the Engine Dies, Can you Restart the Engine or do you have to Wait for a Couple of Hours before?
The Smoke could be The Crankcase Vent Sticking and Allowing Pressure to Build up Inside the Crankcase Forcing the Oil to be Pushed into the Exhaust Port or by the Rings into the Compression Chamber. A Blown Head Gasket causes the Same Problem. I answered a Similar Question a few Weeks Ago and it was the Head Gasket Blown Between the Cylinder and the Valves. The Engine Power Loss is an Indicator of the Vent and the Head Gasket. Im Thinking Head Gasket.
Hope this Helps. Let me know.
  • micromaster
    micromaster Jun 03, 2009
Craftsman LT2000 Does not move (wheels do not move). blade engages and works finr
I would lower the deck to the lowes setting and look between the frame and the deck toward rear wheels and check the drive belt it sounds like it is slipping or busted.
May 19, 2014 | Craftsman Garden
My Craftsman riding lawn mower LT2000 (2002/2003) stopped moving. The drive belt seems to be loose. The engine starts and cutting blade engages fine. Was working fine but stopped working when it started...
there should be a drive belt tensioner somewhere on the belt, it usually works off the clutch/brake, when you push on the brake it apply's the brake and also takes the tension off the belt to stop it from moving.
Not sure of your ride on mower but that is how my ride on mower works so I hope this helps.
New drive belt immediately burned up after replacement
Make sure blades move ok. Check bad spindle bearings too
Oct 22, 2012 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20.5hp briggs and stratton will not go forward or reverse when I let off the clutch it starts to squeal and smokes fronm the drive belt
could be as simple as a worn out belt but look to see if there is a oil leak getting onto the belt
May 04, 2012 | Garden
I have a craftsman garden tractor model # 917.273022. when moving the motion lever forward past the "mowing" speed the tractor slows down all most to a stop. moving the lever back it will start...
Depending on the usage of mower it is possible that belt is worn and likely it is stretched just enough to permit slippage. Usually belts will squeal and even have a burning smell. While the engine is often check to see the mechanical actions on the belt and feel for slackness.
Feb 24, 2011 | Craftsman Garden
I have a 46", 21 HP Craftsman riding mower. The
perhaps it is no oil or too much oil. Check oil level!
If it was too much it would be blowing oil or blue smoke out the exhaust.
Good luck! Hope this helps.
Ashman
Jan 03, 2011 | Craftsman 21 HP 42 in. Zero Turn Tractor...
Craftsman riding lawn mower 15HPOHV model 28N707
14.5 craft riding lawn stop moving i dont know what to do
Jun 11, 2010 | Garden
I have a bolens 38 inch riding mower. it cranked and when i tried to engage the cutting deck the belt smoked off. i replaced the belt and cranked mower. tried to engage and belt smoked and i shut it off....
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Feb 20, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Craftsman riding mower won't move.
yes it is a bad belt unless it is a hydro-stat(no clutch) you need to look under the mower and see if the belt is on correctly
Sep 30, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Lots of smoke when I engaged stuck blades - now runs roughly
Most likely what you did was burn one or more spots on the belt. When the blades and belt stop turning, like in tall grass, the engine doesn't stop and will burn flat spots on the belt at the engine pulley. Every time the flat spot hits a pulley, it will jump and can set up a bad vibration. Run your hand around the sides of the belt or take it off and you will feel or see the thin spot(s) on it. Replace belt.
Jun 09, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Craftsman 42 in. Deck 19.5hp Lawn Tractor Logo
136 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
