My mate gave me a sound lab spm8e mixer amp. when you turn it on & plug line input fron cd player its buzzing..taken apart & found 2 resistors burnt out R15 & R16 There is also a transistor c3200 its cracked open. its collector go's to the base of Q8 C4381 there seems no damage to the output transistors & all the large resistors are fine. no fuses blown. although the 1 fuse looks like it wanted to blow. transistor c3200 is on the underside of board & is pushed into a hole in the bottom of main output heatsink. with no schematics available for this amp has anyone got any idea's what these resistor values are & why they have burned out.
  • JAMES TURNEY Jun 03, 2009
    well wont this stop something working right.
    the 2 resistors a burntout
  • JAMES TURNEY Jun 05, 2009
    NOT CHANGED YET GOT TO GET ONE. WILL LET YOU KNOW THE OUT COME THANKS
3 Suggested Answers
SOURCE: no output to speakers mackie 808s power mixer
I can hardly even tell what you're talking about because you don't use any punctuation.
Posted on Dec 17, 2009
  • 163 Answers
SOURCE: Denon AVR2106 One output channel shorted and
I would also replace 2sa992 (2pcs) and 2sc1845 on preamp board- sometimes they look ok when you test them by regular meter. Check 1.2 kOm and 4.7ohm resistors at preamp pcb. Check diodes on output pcb (could be smd type, connected from base of output transistors to emitter i think)
Posted on Sep 15, 2011
Testimonial: "Great, gives me a new track"
I am not getting no output from peavey 16fx mixer. if i trun it off on & on i get signal for 2 sec
Theres a little switch next to where it says media in on your front panel just above the group sliders.This little button needs to be pressed down otherwise your cd won't come thru.
Feb 13, 2013 | Peavey 16FX 16 Channel Mixer
How to hook up to home amp
If home amp has a phono input and you have no turntable, plug the output of the MP3 player into the phono input and begin with the volume turned all the way down. If you do not have a phono input, you can plug something like a DJ mixer in to get that extra level of amplification you want for comfortable listening. If you do that, the MP3 player would plug into the turntable input and the mixer output would go to the available line level input of the home amp.
The CD player has either the coaxial connector, which is not common for home amps, and a pair of "RCA" jacks (right and left) which are.
The CD output can be connected to any avaialble line level input, such as anunused "Aux", "Tape In" "MD/VCR audio in, etc.
Dec 16, 2012 | Stanton C314 Tabletop CD and Mp3 Player
I have a new set up and i need a step by step instruction on how to set up the mixer to the amp and the decks to the mixer/amp
if this is a dj type set up, the mixer should have a main output (RCA or XLR), that is what you connect to the input on the amp, each deck should have RCA outputs, depending on if they are turntables or cd players, plug the turntables into the phono channel inputs on the mixer and if they are cd players, plug them into the line inputs on the mixer
Mar 28, 2011 | Audio Players & Recorders
Im new with the use of the record player since im tired of MP3's. i bought a Numark TTusb turntable connected everything, but the sound is low. i have to crank the volume to the max, and only get low...
A turntable use a magnetic cartridge and its output is only 5 to 10 millivolts.A moving coil cartridge is even lower,.2 to .5 millivolts(thats 1/2000 of a volt)in contrast, a mp3 puts out a 300 to 900 mv signal..so does a CD player. Your turntable does not have enough signal.You need to get an amplifier that has a phono input. Years ago,radio shack used to sell phono preamps that could plug into a tape or cd input.The other option is to buy a used mixer that has a phono input.The mixer output can drive the cd input easily,as the max output from a mixer is 1.5 volts to 2 volts.
Dec 30, 2010 | Numark ttUSB Turntable
No sound
Your power amp should be connected to MAIN OUT left and right. NOT the MAIN "in".
The CD is connected correctely as you described. Make sure the CD has a line level output to match the input expected by the mixer.
Note:Walkman style CD players require a special cable to go between 1/8 inch stereo to dual RCA plugs.
You have to advance the MAIN fader.
You should be using TRS interconnect cables from the mixer to your amps OR using XLR cables.
Jul 24, 2010 | Mackie 1202vlz3 12 Channel Mixer
Numark cd mix 2
Well, it's not that hard to set up. What do you need help with? If you want to know how to connect:
1) The CD units go into the back of the mixer - in the CD / LINE INPUT - Left side on CD / LINE INPUT 1 and Right side to CD / LINE INPUT 2
The output of the mixer - MASTER OUT - goes to the INPUT of your stereo, amplifier, or receiver's LINE INPUT connection.
That's it. Press PLAY on your CD players, and raise the faders/volumes, and your all ready to go.
- TWEAK AV LAB
Nov 30, 2007 | Numark Fusion 494 Complete DJ Package
I'm have'n a problem
You should be connecting this product to a dj mixer because this unit has no internal mixer.To accomplish this you should connect the two outputs lines for channel 1 from this cd player to the two input lines on channel 1 of your mixer and the same for channel two, connect channel two from your cd player to the channel two input on your mixer and then hook your mixer to a amplifier, then amplifier to speakers. D.J Fire in Louisiana***
Oct 15, 2007 | American Audio DCD-PRO310
New to PA systems......
What brands are we talking about my friend?
Oct 09, 2007 | Audio Players & Recorders
 Grubhead
Grubhead
