Question about HP Presario M2000 Notebook
Disable touchpad in Presario M2000 Notebook
Hi
I need to disable touchpad in my Notebook, but there was no place to do that in the mouse properties in Control Panel.
Please send me a solution for this prob.
BR/
Asitha
Go to Device Manager - right click My Computer >properties>hardware>device Manager
click plus sign next to Human interface devices>right click synaptics touch pad (or whatever hardware you might have) and click disable.
Posted on Jun 03, 2009
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
How do I disable the touchpad? I am running Vista Home Premium. There is no Function key to enable/disable the touchpad. I disabled the touchpad by going to Control Panel, Mouse, and disabling the...
have u gone to control panel - device manager - then on pull down menu's show hidden devices ; click on all the + boxes till you see touchpad ( mouse and pointing devices) right click mouse and click on disable.
i always go through device manager as all devices are in one place!!
Apr 11, 2015 | Gateway M-6827 Notebook
How to unlock touch pad of the hp compac presario cq62 model laptop ?
You can do it from Mouse properties, by going to synaptics tab, Select, Touchpad Disable Zone Settings, and uncheck Double tap to enable or disable touchpad....
Think you got the steps....
Dec 14, 2010 | HP Compaq nc6000 Notebook
I can not disable the touchpad in my Compag Presarioa CQ42
To disable the touchpad, do the following steps.
  1. Click Start , type mouse in the search field, and select mouse from the listing.
  2. In the Mouse Properties window, select the Device Settings tab.
  3. Click the Disable to turn off, or disable the touchpad.
Sep 29, 2010 | HP Compaq Presario V2000 Notebook
How can disable touchpad of my COMPAQ Presario CQ42 laptop
On most Compaq's of the CQ42 model type, there should be a little light on the top right hand corner of the touchpad, not much bigger than a pinhead. When the touchpad is active the light is out so you shouldn't see the lamp. Quickly double tap the area on the lamp and it should light up. This is an indication that the touchpad is now not active.
Jul 22, 2010 | HP Compaq Presario V2000 Notebook
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
A shortcut or way to disable touchpad preasario m2000
You could disable it in Device Manager, but that has the downside of leaving you in a lurch if you are ever without your external mouse.
The latest drivers from Synaptics include a feature called "HandCheck" that will guard against unintentional movement when you are typing and your palm or other broad part of the hand is in contact with the surface.
http://www.synaptics.com/support/drivers (see the link for Features to get a full description).
But I saved the best for last. A little hotkey utility that does EXACTLY what you want: http://www.notouchpad.com/
There's a free trial, but it'll cost you $4.95 if you want to keep on using it.
Good Luck!
Jun 05, 2009 | Compaq Presario M2000 Notebook
Disable touchpad
Click start, ccontrol panel, right click mouse, click on properties and disable. If that does not work then try updating that driver. If it still does not work then go to MSCONFIG and disable it on startup and this will disable it permentaly
Feb 22, 2009 | Acer Aspire 4315-2490 Notebook
How to disable touchpad?
just above the touchpad you will find a small button just press it .and you will notice it is disable so no need to do any changes from control panel.if you want to enable it again press the button......
_______________________________________________________
Was this solution helpful .Show your appreciation by rating it.
Thanks for using fixya support. You have a wonderful day..
Jun 06, 2008 | HP Pavilion dv4000 Notebook
TOUCHPAD
go to mouse setting under control panel.
You will find a place to turn it off.
Dec 01, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
178 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
