Question about JVC Televison & Video
No blue in picture
Problem: No blue....CRT good.
The blue vidio panel has no signal Where does the panel get the signal ?
    Genius:
  • 1,239 Answers
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ...it may be also cathode ray tube... thank u.........
Posted on Jun 03, 2009
Blue screen no picture
Your television had a problem in vidio circuit, check the tuner input and output, if you not get any pulse in tuner output, you can change the tunner block with the new one.
Nov 17, 2013 | Televison & Video
Analog channels are fuzzy but the digital channels are clear
So what's wrong??? Analog signals that may seem pretty good on an old CRT would seem terrible on the newer TVs because all the flaws show up much sharper. Thank goodness for digital signals. With digital signals, unlike analog signals, you either get a good clear picture or no picture at all.
Aug 07, 2011 | Televison & Video
Philips DPTV 60PP9753/17. Problem started when blue CRT seemed to "fuzz" out. Tried to increase the brightness via the Blue G2. Made no difference. The sound quit while the picture was running. Turned...
Hi my name is Roety,
I can help you with your issue ,
First of all lower the blue and any other screen controls or service menu settings back to where they were or lower.
Then see if it powers on again with a picture.
If it still shuts off, unplug the Blue CRT circuit board and see if it works.
If it does work the blue CRT may be shorted .
Your problem may have been corroded CRT pins.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Nov 02, 2009 | Televison & Video
Model AVM-20M8. serial # 3091012 no vidio
Chroma is the color part of the TV set signal picture if a set has a chroma control but has a color, they both are and do the same thing!!!
Sep 06, 2009 | Televison & Video
Samsung 460Px monitor turns on but no vidio signal going through. Screen turns from black to a dark blue meaning the unit is powered and I get a solid green light.
I have the same problem, the monitor has power, but i can't even switch sources, the front panel is locked and i can't tell if it responds to the remote because there is no menu or picture of any kind
Apr 24, 2009 | Samsung 460PXn Monitor
VIZIO L37 HDTV
daewoo37in(dlt37g1) freeview will not store saying no signal but freeview will install on other equipment using same imput
Jul 08, 2008 | Televison & Video
The picture on my Sony KP57WS500 is starting to fade to blue after being on a short period of time. ANY IDEAS?
Good Day;
A blue picture after it's been on for a bit is normally one of several things. The most common for your Sony is the CRT, tube, the second most common problem is the blue CRT 'IC'(chip). The IC is located is on the blue crt board.
The best way to determine this is to remove the speaker grill(on front of TV), then inner panel, the blue tube will be on your right hand side. Remove that little board at the end of the tube.THIS AFTER YOU HAVE UNPLUGGED THE POWER FROM THE WALL. Plug TV back in turn TV on. If TV comes on with picture and there is no blue in the picture, The tube is bad, if TV turns off it's the IC.
Good Luck, BI.
Jun 18, 2008 | Televison & Video
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
Retuning having moved to a new area
blue screen is due to problem in blue video circuit. please check 1 supply to blue video ckt. 2 crt base loose. 3 components in blue video ckt. 4 loose contact in blue cathode ckt in crt base. 5 blue video transistor. 6 signal coming to blue video from signal processor. 7 signal processor ic. good luck.
Sep 29, 2007 | Thomson 14MG135 14" TV
Lg tv and parcific vidio
YES, DOES YOU PACIFIC VIDEO HAVE COMPONENT , COMPOSITE OR HDMI OUTPUTS ON THE BACK ? THE HDMI HAS BOTH AUDIO AND VIDEO SIGNALS AND IS THE BEST QUALITY PICTURE. BUY THE CABL AT RADIO SHACK, WALMART ETC.
COMPOSITE IS THE YELLOW RCA CONNECTOR FOR VIDEO AND RED AND WHITE RCA CONNECTORS FOR LEFT AND RIGHT AUDIO.COMPONENT IS THE RED, BLUE AND GREEN RCA CONECTORS AND RED AND WHITE FOR AUDIO L & R.
Nov 24, 2006 | LG TU-60PY2DR 60 in. TV/DVR Combo
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
