Question about Brother DCP-330C All-In-One InkJet Printer
Brpther DCP 330c does not recognise new black ink cartridge
I have just replaced black ink cartridge for my brother DCP 330c. As printer said black was empty. However the original cartridge is not empty & printer will not recognise new cartridge being inserted, so am unable to do test print or print anything.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 86 Answers
Usually there is more than one cartridge empty when you receive this kind of problem. Try opening the top cover and check if the display changes - it should change to specify one (or more) of the color cartridges as empty. That one(s) should be changed too.
Posted on Jun 03, 2009
My Brother DCP 330C hasn't been used for a while and now does'nt print at all, just spits out a blank page. When copying it only prints yellow. Changed all the cartridges, but still the same.
you have a blocked or faulty printhead/ inksystem, you can print an internal print quality check and do deep head cleans, but in my experience this only helps 10-20% of the time.
deep head cleans use A LOT of ink
if you dont see a big improvment after 2 deep head cleans dont continue as you are just wasting ink
Oct 15, 2014 | Brother DCP-330C All-In-One InkJet Printer
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
My Brother DCP 330C says " Unable to print 4F" What does this mean and what can i do to fix it please??...... Thank you Kindest reagrds Milli
Hi millih,
An error coded 4F means that there is a mechanical problem with the printer, usually, "unable to print means one of two things. Firstly an empty cartridge, secondly a full absorbing pad. I am guessing that the latter is not the priblem as the code would be #46, so if the ink cartridges are empty, get them replaced or refilled then disconnect the machine from the power for about 5 minutes, then reconnect and it should reset itself.
Sincerely
rover620
Sep 20, 2010 | Brother DCP-330C All-In-One InkJet Printer
DCP-330C says Ink Empty, but after replacing a new cartridge it still appears Ink empty!
Make sure the inks are all full, you may need more than one replaced. If all have ink just hold the stop key while you power up and that error should clear.
Nov 13, 2009 | Brother DCP-330C All-In-One InkJet Printer
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
I have changed inks keeps saying low on inks yellow empty wont print
tape up the side thats the outside theres a black bit inside just cover it up that will do it
Oct 25, 2008 | Brother DCP-110C All-In-One InkJet Printer
Replacing the cart holder on a Brother MFC 240C
Somethings that have worked for some Brother owners to get cartridges recognised.
1. With your MFC powered up, open it up and remove the cartridge you are having a problem with, then close the MFC, leaving it powered up. It should report that there is no cartridge in the machine.
Still with the MFC powered up, open it up and reinsert the ink cartridge, then close the MFC. It should either ask if you have replaced a cartridge or go into its cleaning mode.
Answer "yes" to "have you replaced cartridge?" and it should either "print" or "clean" and then "print".
2. The cartridge holder in the printer has an "electronic eye" (light sensor) of some type for each cartridge.
Some users have found that putting either permanent marker/sharpie/black PVC tape either on the area of the ink cartridge that goes near the sensor or alternatively putting tape over the sensor itself allows printing to occur.
The problem with this method is that the printer will no longer recognise near-empty cartridges and so will not warn you to replace them and so the print head may be damaged. This is said to work on LC57 icartridges used with the following models: DCP-330C, DCP-350C, DCP-540CN, DCP-560CN, FAX-2480C, MFC-240C, MFC-440CN, MFC-465CN, MFC-665CW, MFC-685CW, MFC-885CW, MFC-3360C, MFC-5460CN, MFC-5860CN.
Sep 23, 2008 | Brother MFC 240C All-In-One InkJet Printer
Black cartridge doesn't print
you need to do a hard reset on the printer as well it might clear up the problem and recognize the ink at its proper levels.
refer to your user manual or let us know and we will find the procedure to do so.
i have a similar model and know how picky they can be.
Aug 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Ink cartridges....
Which cart arent recognized? The yellow one or the cyan(blue) one or both?
Anyway:
Unplug machine from power. Wait three minutes. In this time take all carts out and close cover. reconnect machine to power. Machine demands carts. Open cover. Reinsert carts. Make sure that the support clip of the cart.holder is secured above the cart cover.
If you still have probs with one cart. the led contact on the circuit board is defectiv. You need a new cart holder then, which can be ordered as a spare part from a service partner near your home (see brother homepage).
Nov 13, 2007 | Brother MFC-3240C All-In-One InkJet...
Brother DCP-330C All-In-One InkJet Printer Logo
699 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
