Question about Lexmark E220 Laser Printer
Toner light blinks and error light shows
Bought a E220 Lexmark and when I put the new (refil) toner cartridge in, the toner low light blinks and the error light is on. According to the Lexmark site they suggest taking the toner out and re-seating it. I have tried this MANY TIMES, but no difference. I have also downloaded the local printer setup software, but it cannot find the printer, even though windows xp can?? Any ideas??
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Lexmark Master
  • 1,362 Answers
1- you either got a bad toner ( the chip on it is telling it it is bad)
happens sometimes with recycled toners.
Return it and tell them it is defective.
The chip needs to be replaced.
Try this but doubt it will work,
open front door hold down go button, all lights will flash in sequence wait for it to stop turn off and on and close door.
Posted on Oct 25, 2007
Error p1500
The printers first error code show all lights flashing:
Flashing Ready'Data
Flashing Toner Low
Flashing Load'Remove Paper
Flashing Paper Jam
Flashing Error
Flashing Press Continue
By pressing continue twice to get to second error codes the lights show:
Flashing Ready'Data
Off Toner Low
Flashing Paper Jam
Flashing Error
Pressing continue twice more shows:
Off Ready'Data
Flashing Toner Low
Off Load'Remove Paper
Off Paper Jam
Off Error
Off Press Continue
Pressing continue twice more brings back to all lights flashing
The computers ( I have tired more than one with diff USB and A parallel cables) do not see the printer as being attached. My toner is half full. I checked the internal power board in base of printer and the fuse is good. The error should not have anything to do with being connected to a computer or not because when it was working and not connect to a computer it would not blink all the indicator lights (If I remember correctly, just the Press Continue light would be lite).
Information I have found so far:
  1. http://support.dell.com/support/edocs/systems/p1500/en/index.htm#online_documentation
o Under PDF Documents Owner's Manual(English) (.pdf) (1.33 MB) shows very little about the indicator lights.
o Under HTML Documents User's Guide shows more information about the indicator lights but mentions nothing about the secondary error codes.
  1. The Lexmark E321/E323/E220 are very close cousins to the P1500 and on Lexmark's website the manuals have more info on secondary codes but nothing that matches my error.
Information I am guessing could be the problem:
  1. The fuser has gone out (need to know how to check) Why else would they sell the fuser if it didn't go out regularly Part Number: 56P1053
  2. Clutch Assembly I'm not sure of the accuracy of the info on this page.
Mar 12, 2014 | Canon Office Equipment & Supplies
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark E120n Laser Printer
The printer toner light is continuously flashing even after putting in a new cartridge
After installing a new cartridge and the blinking light is on Toner Low, it means that the photoconductor is almost full and should be replaced soon. Press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, replace the photoconductor kit.
For further assistance, please call Lexmark Technical Support.
Jun 14, 2011 | Lexmark E260D - QTY 4 - LMB OFFER Laser...
Lexmark E260dn toner light is still on after changing the toner cartridge
Toner light is ON, I would assume that the light is solid and not blinking. You can press and release to clear the light sequence and continue processing the print job. With the printer turned off, remove the toner cartridge and shake it to extend its life. Check the replacement toner cartridge if it is the one suitable for your region.
If the blinking light is on Toner Low, press and release the Continue button (green button) to clear the light sequence and continue processing the print job. If the light is still blinking, the photoconductor is almost full and should be replaced.
Apr 12, 2011 | Lexmark E260dn Laser Printer
ML-2510 Laser Printer : persistent blinking red light
Dear
This problem you will be noticed when toner is 90% empty.
Does the printer is functioning or No. If yes the problem is 90% toner is finished.[10% toner remaining alert]
If printer is not functioning Please change the toner from Genuine dealer. Else your printer fails due to non genuine and refilled toner.
Nov 11, 2009 | Office Equipment & Supplies
IBM Infoprint1120 and Lexmark T520 toner cartridges.
You cannot use Lexmark toner cartridges in IBM models and vice-versa because the toner carts have a smartchip that identifies the toner to the printer. IBM printers expect to see IBM toners and Lexmark machines expect to see Lexmark toners. If you put the wrong cartridge in you will get '32' Unsupported print cartridge error.
Some refillers may swap the smartchip when they refill cartridges and this would be the only reason why you may have seen it done before.. IS your current toner a refilled one? It's technically possible to make an IBM printer into a Lexmark printer to accept Lexmark toners by replacing the System Board... but why would you bother doing that...just use the right toner.
May 19, 2009 | IBM Infoprint 1120 Laser Printer
Samsung printer ML 2510 series
Maybe the toner is low... According to the manual, a blinking red light:
• A minor error is occurring and
the printer is waiting for the error
to be cleared. When the problem
is cleared, the printer resumes
printing.
• The toner cartridge is low. Order
a new toner cartridge. You can
temporarily improve print quality
by redistributing the toner. See
page 8.3.
• The toner is totally exhausted.
Remove the old toner cartridge
and install a new one. See page
8.4.
• The toner cartridge reached the
end of its life.
Feb 24, 2009 | Samsung ML-2510 Laser Printer
IBM infoprint 1312 toner and error light.
If both Lights are solid, it means that the top cover is still open and the toner is low. Please make sure the top cover is closed all the way. If the toner light is blinking and the errror light is solid, it means there is a toner cartridge error. Please try a new cartridge. If that solves the issue, then you should return the damaged one.
Mar 10, 2008 | IBM Infoprint 1312 Laser Printer
Lexmark E220 Laser Printer Logo
452 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
