Question about Microsoft Windows XP Home Edition
Desktop not appear
Computer start,booting comp.but desktop not appear
  • 3 more comments
  • dtop Dec 16, 2007
    Hi
    I have an emachine desktop L4032. When I start it, the power button lights uo, the cpu fan starts humming, and the cd drive light starts flashing but nothing else happens. I tried keeping it on for 1 hour and the fan keeps running but nothing else! I tried starting it up and pressing the F8 button as to start in safe mode to no avail. any help would be appreciated. Thanks
  • Anonymous Feb 23, 2008
    tried inserting startup disc and nothing accept compaq screen
  • Anonymous Apr 20, 2008
    The system boots to a page that says "windows could not start because the following file is missing or corrupt: \system32\hal.dll. Please reinstall".
    The Cd drives are set to boot at startup, but, the Windows reinstallation CD will not boot.
  • bablusps02 Aug 11, 2008
    when computer starts desktop is not appear and this sentence comes in dialouge box ''you are the victim of guniene counterfiet software''
  • SUSHIL1984 Dec 25, 2008
    i have laptop compaq presario c700 with window vista , i have got same problem that my laptop is starting but after accesing to system through passward desktop not appearing everything is blank...same problem is coming though i am starting in safe mode ..give me solution on this..my mail id is kute_sushil@yahoo.co.in
  • 54 Answers
Check all this-------------
1.Boot from the cd 7 run scandisk
2.run CHKDSK command
3.Reset your bios
4.If possible replace the SMPS
I think your problem will solve.Good luck.
Posted on Mar 05, 2008
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Try going into safe mode once your computer boots up press F8 repeatedly through the first stage of start up then after it should ask you what you want to go on click "Safe Mode" and when your on safe mode if it start up then we know it's not too late to fix it.
Go to My Computer Right click on your "Local Disk Drive" click properties "Tools" where it says "Error Checking" click check now tick both boxes then click start then something will come up saying would you like to scedule a scan when your computer next restarts click "YES" then restart the computer then allow it to scan then see if it works after that.
Good luck. Hope my solution helped.
Posted on Oct 24, 2007
Sounds like a bad processor board
SOURCE:
Message saying windows did not start properly. recent hardware or software change may have caused
There must be a corrupted software drivers.
For quick solution tried to boot in safemode then perform system restore, if it doesn't work tried to restore the last known good configuration.
How to boot in safemode:
  1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
  2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
  3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
  4. Once your on the Windows desktop, click on Start>All Programs>Accesories>System Tools then select System restore
  5. Choose the recent date or restore point that your computer is working fine.
How to boot in Last know good configuration:
  3. When the Boot menu appears again, and the words "Last Known Good configuration" appear in blue at the bottom, select the installation that you want to start, and then press ENTER.
Jul 13, 2011 | HP Pavilion a1620n (882780664494) PC...
I have pcchips m955g motherboard, comp reboots during
If the computer keeps rebooting when you first start it up it is quite possible that the hard drive is broken. It keeps looking for the start up boot sector, but it's broken so it keeps trying again..and again...and well you know.
Hank
Nov 30, 2009 | Computers & Internet
My computer won't boot
does it make some clocking sound when you start your comp? try to reset cmos... pull out power cord, open case of comp, pull out little battery (you can miss it) wait for about 10 seconds, then pull it back in, after that plug in you power cord and start you computer ...
Oct 01, 2009 | HP Media Center m7250n (ED842AA) PC...
I have windows xp a lot of times when I restart my computer a white screen comes up it wont re-boot at times it boots up with a white screen
sounds like its a software problem , however its wise to rule out if its a hardware problem, best thing to do is try to start it up in safemode , this is easily done by retarting comp and pressing F8. now if safe mode shows your desktop it is most likely software, save any file you dont want to loose and try remastering if your comp came with installation disc restart with disc inside . if not it probably has a partition you need to look in manual for the remastering solution to this , could be retart f11 or retart f8 , every comp is different , best advice is to google your model for remastering my computer. good luck
Aug 31, 2009 | HP Pavilion A720N PC Desktop
When comp loads up asking for a boot device
Would you mind and give more information!!
Sometimes "" comp loads up asking for a boot device"" because the wires & the connectors are NOT connected properly . Did you go into the computer [laptop?, Desktop?, Tower?] and move things around? Did you pull?,shove? ,tug? at anything inside the 'comp'.?? Unplug the power and PUSH e v e r - s o - slightly EVERY PLUG, connector (cables coming from computer going to h/d [hard drive], plug power (electricity) and turn her on.... see what happens....
Aug 31, 2009 | Computers & Internet
Start up error message issue: floppy disk fail
if im correct, you havent installed a floppy drive yet...
while the comp is booting press esc (on some comps its F10 it should say on the screen) and access the boot sequence..in there there is a list of boot items...they always list floppy drive as the first boot drive in case you need to recover your comp...remove floppy drive from your boot list making sure that your hardrive (C) is first drive to boot.
After you get your comp set up, you may want to change that sequence in case you ever have problems with your HDD
add a comment if you need more help
Jun 22, 2009 | EliteGroup K7S5A Pro Motherboard
Desktop not appear
Try to boot in safe mode:
Push F8 or F2 when booting.
Jan 04, 2009 | Microsoft Windows XP Professional
My Mac wont work. blinking Folder with "?"
When the "?" mark comes up, it means it's looking for the operating system to boot to. It can be fixed by opening system preferences and in the startup settings, select your operating system as the tarted startup. It should speed up boot up time.
Apr 06, 2008 | Apple Power Mac G5 Desktop
Desktop not appear
Sounds like either you have a process running that is locking out the explorer shell from running properly, or you have hard drive corruption (which is getting pretty rare). Try opening task manager (control-alt-delete) in safe mode and then looking for any processes running at the top of the CPU stack, and then cancel them one by one to see if explorer (desktop) appears. Actually, if you can get task manager up, click on APPLICATIONS along the top, and then NEW TASK at the bottom and then type in EXPLORER and AFAIK it should load your desktop (or try to).
If these all fail, you want to try to re-install the OS, and also check the hard drive for corruption using diskcheck.
Good luck...
Nov 16, 2007 | Toshiba Satellite A100-S8111TD Notebook
Microsoft Windows XP Home Edition Logo
348 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
