Question about Craftsman Garden
I can prime with bulb and runs a couple seconds then shuts off
I can also get it to run if i constantly push the bulb but its pretty hard to cut grass while priming the CRAZY BULB!
  • Dwain Pippen May 11, 2010
    What is the model number on the ENGINE and I'll tell you how to fix it.
  • 1,040 Answers
You need to clean the carburetor. Or, you need a new carb. kit. If you need tips on how to best do this, just let me know.
Jim
Posted on Jun 04, 2009
  • Jim Parker
    Jim Parker Jun 09, 2009
    Did this solve the problem?
    Jim
Will not start
More information would be nice. How old is the cultivator? How long has it been since it last ran?
Possible causes for the primer bulb not to fill: 1. the bulb has a small hole in it (need to replace the primer bulb, usually a pretty easy job, just remove a couple of screws, remove the old bulb and install the new one). 2. One of the fuel lines may have a break or hole in it. If the cultivator is old enough a fuel line may have dry rotted and came apart.
A couple of things to try: Put fresh fuel in the tank then remove the air filter and put a few drops of fuel in the carburator then try to start the unit. If it starts an runs for a few seconds and dies the problem is the carb. is not getting fuel to the engine. If it still will not start check the spark plug. Is it fouled? Worn out or broken? If in doubt replace the plug.
May 20, 2014 | Troy-Bilt TB146 EC 4-Cycle Garden...
Why doesnt electricity to my fuel pump the fuel pump fuse doesnt have electricity
wont have constant power unless its running ,,,, when you first turn on ign it cuts in for a few seconds to prime the fuel system and then only runs constantly when engine starts,,, if its not doing this it could be a faulty relay or a crank sensor
Nov 22, 2013 | 1998 Cadillac Catera
Trouble with carburetor,runs after priming then shuts off.sears push mower model917.382730 installed sears kit need soloution.problem occurs every time it is started.have replaced primer kit which works,...
Sounds like you will need to clean your carburetor.
Be sure to use compressed air to blow out all the fuel and air passages.
After cleaning and before you reassemble the carb, be sure to "set" your float level, turn the carb upside down and make sure the float is LEVEL and not tilting up or down
Sometimes you can get by with priming the carburetor a few times, and letting it run a few times like that and it will flush the gunk out of the jets,but most of the time you will need to rebuild the carburetor.
If the mower/weedeater is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit,because the diaphragm will get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, You will first seat the jet screws and count the number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns they were in/out.
Please rate me
Aug 23, 2010 | Craftsman Garden
Lawn mower keep cutting off when cutting the grass what could be the cause
Sometimes you can get by with priming it a few times, and letting it
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
When you clean your carburetor and remove the jet screws, count the
they were in/out.
Please do not forget to rate me, Thanks
Good Luck, I hope this help
May 21, 2010 | Garden
Wont continue to run after prime and start
often the last ounce of gas in the tank has some crud in it. Get a can of carbeurator cleaner spray. Remove the air filter and squirt three short bursts of the cleaner spray into the air port and then start it. Keep giving it short bursts of carb. cleaner until it runs smoothly again.
Aug 12, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Runs only briefly after priming
Yes, Depending on how old your trimmer is, one of two things is wrong. Either the carburetor just needs a very good cleaning, or you need to purchase a carb. kit and replace the small screen, gaskets, and needle valve. It would probably be good idea to do both if your trimmer is more than three years old and if you have never replaced parts on carb
Jim
May 30, 2009 | Ryobi Garden
Mower won't start
13 to 15 amps electric or battery operated mower may runs slow when cutting thick grass. also recommended not to cut grass when it's wet & need very sharp blade to do the lawn. may overloading it, cutting grass too thick also draws too much power. check house breaker first.
Jun 11, 2008 | Black & Decker 19" Electric Lawnhog...
Garden Logo
130 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
