Question about Karcher G 2600 VH Gas Pressure Washer
Cant change the high pressure hose on a Karcher
Does anyone know how to get the high pressure hose off of a Karcher pressure washer? I am trying to attach my new telescoping wand.
It seems that Karcher has made it so their hoses cannot come off of the pressure washer.
There must be some way to get the hose out. Any info would be appreciated.
  • jamesgland Jun 03, 2009
    Thanks for the reply but I was looking to findout how to remove the hose from the machine so I can attach a new hose and telescoping wand/gun.
  • Anonymous Mar 27, 2014
    The hose attached to the lance is leaking, where can i get a new one
    Scholar:
  • 72 Answers
On the Kärcher, you have a bayonet mount at the base of the tip end of the pistol grip. This is where you attach different types of nozzles and gadgets after having removed the existing sprayer tube. Just push in and turn a quarter of a turn, then you pull it off the pistol grip. The hose is possible to remove from the machine as well, an ordinary threaded mount but since you need the pistol grip to regulate on/off this is probably not what you want to do. If the telescopic wand is made by Kärcher it should be very easy to snap it into place just like when you removed the sprayer tube/nozzle. If the attachment was made to fit Alto washers there is an inexpensive adapter that works very well. Good luck!
Posted on Jun 03, 2009
  • Håkan Sterner Jun 04, 2009
    Do you have the model in the category header or is it another model?
    On my rather old machine the hose is attached to the machine with a threaded mount. On newer machines the hose has quick connects that click into place, then there is a tab on the side of the mount that is lifted with a screwdriver to release the quick connect.
    Maybe there are some different variants that I don't know about. If you need a manual for your machine you can try downloading it from www.karcher.com (that is, if it is a relatively new machine).
How do I fix my pressure washer when the high pressure hose keeps blowing off.
If hose fits over a hose barb try using a hose clamp from any auto supply store Or replace the hose barb GL
Oct 08, 2015 | Karcher K 367 M 1750 PSI 15 GPM Electric...
Karcher k3.575 high pressure quick connect high pressure hose not locking
clean out the dirt and check the hose support that likes to slides down to the end of the hose
Mar 20, 2012 | Karcher K3.68MR Electric Pressure Washer
OUR KARCHER 2600 PSI PRESSURE WASHER W/ HONDA ENGINE WON'T START. WE BOUGHT IT A SAM'S CLUB LAST YEAR AND PROBABLY HAS ONLY BEEN USED ABOUT 4 TIMES. PLEASE ADVISE.
Hello:
Have you tried changing the gas, Especially, if it has been in the machine of a while. Also some Honda engines will not start if the oil is low. Also try removing the high pressure hose before you start it? Do not run it very long without water flowing through the pump, though.
Sep 20, 2009 | Karcher Garden
Poor pressure
i had this same problem on my pressure washer.the pump had some broken parts in it .i found my replacement pump on EBay.
May 29, 2009 | Karcher 2500 PSI Pressure Washer
Karcher Power Washer that surges up and down with water pressure.
Before you start it up:
1. Disconnect the high pressure hose 2. Connect the water supply and turn on 3. Make sure water is flowing through the pump
Start the motor, run for about 10 seconds and then turn off.
Turn off the water supply, connect the high pressure hose, turn water back on, start the motor and away you go.
Karcher high pressure hose pops off high pressure outlet. I think it is stripped.
Try one of the products from your local DIY store, i,m talking about the two part putty that you mold with your fingers, can be drilled tapped and can do amazing bodges, plumbers are never without it! Good Luck - the Yeti
May 17, 2009 | Karcher PSI Electric Pressure Washer
Can't get the spray gun onto the hose from the washer...no manual
Your posting is incomplete, so I'm not quite sure what we're dealing with here.  I understand the machine and the high-pressure hose are Karcher - right?  Is the gun also a Karcher part?  If all are Karcher parts, they should fit unless the screw threads have been damaged.  If they are not all Karcher parts, they will not fit because Karcher connectors are different from almost all others.
Please post again if this doesn't help, giving as much detail as possible, and I'll see what else I can offer.
Apr 04, 2009 | Karcher PSI Electric Pressure Washer
LOST KARCHER INSTRUCTION BOOK, ARE INSTRUCTIONS ON LINE
Here is the offical link to manuals and warranty cards for the residential models of Karcher Pressure Washers
http://www.karcherresidential.com/us/Service/usermanuals.htm
Jan 22, 2009 | Karcher K2.26 Electric Power Washer
Gas pressure washer
I have the same problem with a Karcher 2400hh.
Go to: http://www.wmpcs.com/index.php?main_page=page&id=14
they have the best diagrams and answerss that I have found.
May 02, 2008 | Karcher 2500 PSI Pressure Washer
Karcher G 2600 VH Gas Pressure Washer Logo
1,630 people viewed this question
Top Karcher Garden Experts
John Trevino
Are you a Karcher Garden Expert? Answer questions, earn points and help others
