Question about Frigidaire GLTF2940ES Front Load Washer
Frigidaire Front loader washer water in door gasket
Frigidaire Gallery Series Washer GLTF2940ESO
The washer seems to work fine, but water is pooled in the door gasket after use. Is there a good way to get rid of this water after use? Is there a drain blocked or something? Currently, I wipe out with a towel after each use. My model number ends with ESO
SearsTechToo
  • 261 Answers
SOURCE: no spin
E47 and E48 are door lock error codes, also check the wire harness connections too.
Posted on Oct 29, 2008
duby1990
  • 367 Answers
SOURCE: I have a Frigidaire Gallery
It can be be your speed control unit. It also can be your door switch. Even though it locks there is still another switch inside that sometimes fails. That is your cheapest way to start and a lot of times that fixes it. If not replace the speed control unit.
Posted on Nov 18, 2008
  • 10 Answers
SOURCE: Front loader will not spin
The problem is the door latch assembly. You can get it at your local parts supplier or oder it through repairclinic.com. Should cost $50-$55. My hubby is replacing mine now. Not an easy part to replace, but by all information I have gathered from the manufacturer and the parts department, this is a common problem and most likely the cause of the machine not spinning. It runs through all the rest of the cycles, but will not spin, even on spin only cycle. The good news... if you replace the door latch assembly once, the replacement part is much stronger than the original and shouldn't have to be replaced again.
Posted on Jan 02, 2009
  • 99 Answers
SOURCE: front loader GLTF2940ESO frigidaire washer
this is joyce
can you exsplain what is going on with your washer?
Posted on Feb 07, 2009
SOURCE: washing machine will not drain the water??!?
Check the drain pump it may be clogged or not working. This is a common problem i have working at a camp with 15 washers.
Posted on Apr 15, 2009
Troubleshooting kenmore washer front loader 417 390 12890
basket rubbing to the door gasket ..could be bad bearing or broken spider
Mar 01, 2014 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Front loader GLTF2940ESO frigidaire washer
this is joyce
Feb 06, 2009 | Frigidaire GLTF1670A Front Load Washer
No spin
Oct 29, 2008 | Frigidaire GLTF2940ES Front Load Washer
Water filling tub on washer
First thing is to run the machine as normal. After the cycle is complete and the clothes are removed, turn the water off, hot and cold, to the machine. If on the next usage there is no water in the tub then the fault has been found. And, no, the water valves are fairly easy to access and replace if needed.
Jan 26, 2008 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine collects water behinf door seal
your washer is a great washer BUT you Have to wipe the silly gasket all the time and leave the door open to let it vent and dry I deal with this all the time and no they dont tell you this when you buy them (they Should) but they want the sale then its your baby.I do warranty work for all the name brands and I see this on all of them good luck
Dec 17, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
182 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
