Question about Multitech Systems Multi-Tech MultiMux MMV-3216 Multiplexer (MMV3216C/V)
I have an Multitech 4500 Analog Descrambler unit that went into ANT mode so I am only getting channels up to 13 and there is a small u on the display. I need instructions on how to switch it back to CATV mode so I can get all channels.
2 Suggested Answers
  • 11800 Answers
SOURCE: How to unlock channel at
The are 2 types of locks:
1. parental ones - in which you can input a code (the default one is 0000) to access it; later you can go in the menu and completely remove the lock.
2. package ones - in which the lock has been put by the cable company and you are allowed to access them only by purchasing a new package; to remove them you must either buy access to that channel or hack your way in. But for that you will need a new cable box, one that allows hack keys to be used - it will cost you around $300; and then you must find the key for your cable supplier and load them in the new box. Beware, this is illegal and the fines, if caught, are huge.
Posted on Dec 11, 2010
Antenna installation
The tuner in that unit is analog ntsc and so you need a digital converter for it.
Feb 17, 2014 | Hitachi Televison & Video
How do I attach an antennna?
On the back of the TV look for the connector marked Ant/cable. This is a silver connection with threads on it. If you have a digital indoor antenna, connect it there. Same goes if you have an outdoor antenna. Now go to the setup screen and select AIR for antenna type. After that do a channel search and select digital and analog channels. Let the TV find all the stations it can. When it's done searching, it will show a picture. You may need to aim the antenna to get a better picture .
Sep 05, 2013 | Sharp Aquos LC-13E1U 13 in. EDTV LCD...
How do I retune my Panasonic Viera TV?
Hello
To tune your Panasonic Plasma to on air TV channels do the following:
Connect the antenna connection to its antenna in at the back panel.
Automatically searches and adds available channels to the memory.
Select "ANT in"
Select Cable or Antenna Select "Auto"
Select a scanning mode
Auto channel setup
Select "Auto program"
Select "ANT in"
Select "Auto"
Select scanning mode (ALL channels/Analog only/Digital only
Start scanning the channels
Available channels (analog/digital) are automatically set.
All channels: Scans digital and analog channels
Analog only: Scans Analog channels only
Digital only: Scans Digital channels only
Confirm registered channels
If OK is not pressed after selecting "Apply", the channels will not be saved.
The channel will be saved when no operation is performed for 60 seconds and
the "Manual program" menu will also exit automatically.
If you perform scanning more than twice, previously saved channels are erased.
About broadcasting systems
Analog (NTSC): Conventional broadcasting
Digital (ATSC): New programming that allows you to view more channels
featuring high-quality video and sound
[Use "UP ' DOWN ' RIGHT ' LEFT] AND 'OK"] keys to selcet and proceed.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have the am hooked up correctly but it wont work.
its a good idea get vom and start from power ant coming from head unit ussually 13.80 volts to the trigger of amp also check battery power to be present on power terminal (13 volts)positive. also getting a good ground connection , again digital or analog volmiter get the difference.
Nov 24, 2010 | Jl Audio E1200 Car Audio Amplifier
Only picking up one digital channel
digital air signals are weak and fussy. They are easily lost by having trees or large buildings in the way too.
The best thing to do is install a long range roof top antenna and re program the set. Be sure to aim the antenna correctly. if you cannot use a roof top antenna you can try the indoor digital antennas,but less likely to work consistently
Jun 02, 2010 | Toshiba 40RV525U 40 in. LCD TV
My Samsung LCD (LA46A850)does not tune Analog
Hi my name is Roety,
I can help you with your issue ,
Even before you run the auto program you should see a picture when entering a channel below 13 when entering the numbers in the remote. If no picture shows check the signal source the center connector may be bent.
Another possibility is selecting ant 1 or 2 make sure you are selecting the correct input the check the picture then run auto program
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Jan 19, 2010 | Samsung LA46A550 46 in. HD-Ready LCD TV
VCR Connection
If your vcr has an ant. in and out to tv coax type jacks the signal should pass through when the vcr is off or in tv mode. Make sure tv is on the output channel of the converter box(usually ch 3 or 4). If your vcr is different please give more info.
May 14, 2008 | Insignia Digital-to-Analog Converter for...
Can't get cable channels, only goes up to ch. 13
First check and see if you are on Cable or Ant. It sounds like you are on ant. Change it to cable. If you are on cable then it's you tuner, you need to replace it.
Sep 14, 2007 | Zenith A25A23W 25" TV
Pic n pic
can get my pc n pic to work. it says can not view same channel please clarify problem in more detail thanks
Sep 09, 2007 | Mitsubishi WS-65615 65" TV
Multitech Systems Multi-Tech MultiMux MMV-3216 Multiplexer (MMV3216C/V) Logo
264 people viewed this question
Top Multitech Systems Computers & Internet Experts
Vladimir Frolov
Larry Fostano
Larry Fostano
Karen Gibson
Level 1 Expert
Are you a Multitech Systems Computer and Internet Expert? Answer questions, earn points and help others
