Question about Gateway FPD2275W LCD Monitor
What is the solution for monitor flickering?i have tried wit 75hz refresh rate,but it didn't work
    Problem Solver:
  • 11 Answers
There is a possibility that the backlight has a problem,it would make the screen flicker no matter what settings you choose.try it on another computer without changing settings
Posted on Jun 18, 2009
Hello, I have been using my asus vw222u monitor for a while now, connected to my dell dimension 4600 pc. I have been running the resolution at 1024x768, and been getting relatively clear pictures, but...
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
http://www.scan.co.uk/products/512mb-pny-nvidia-geforce-6200-graphics-card-agp-8x-4-cores-d-sub-dvi-i-s-video-passive-cooling
Apr 22, 2011 | ASUS VW222U 22 inch LCD Monitor
Tip
How to adjust or change a monitor's refresh rate.
If you've ever used a CRT monitor, you know that fine-tuning your refresh rate is essential. The refresh rate of a display is measured in Hertz (abbreviated Hz) and specifies the number of times per second that a display is illuminated.<br /> <br /> Setting the refresh rate to 60 Hz - a common default value - tells the monitor to redraw itself 60 times per second. For most people, that setting on a CRT monitor is too slow, resulting in an annoying flicker that can cause headaches, eyestrain, and fatigue. Bumping the refresh rate to a higher number can reduce that flicker, as long as the monitor itself can handle the faster rate.<br /> <br /> If you're using an LCD monitor then a safe refresh rate lies in the 60Hz-75Hz range. A greater refresh rate when it comes to LCD's means greater performance.<br /><br /> <b><u>How to adjust the refresh rate</u></b><br /> Firstly you will need to right click on your desktop background and select <b>Properties</b>.<br /> <img src="slasher_x_72.JPG" /> <br /> This will display the <b>Display Properties</b> window as show below.<br /> <img src="slasher_x_73.jpg" /> <br /> You will need to click the <b>Settings</b> tab.<br /> <img src="slasher_x_74.JPG" /> <br /> Once in the <b>Settings</b> tab you will need to click on the <b>Advanced</b> button.<br /> <img src="slasher_x_75.JPG" /> <br /> Then click on the <b>Monitor</b> tab.<br /> <img src="slasher_x_76.JPG" /> <br /> Here you can change the screen's refresh rate. Make sure the box next to <b>Hide modes that this monitor cannot display</b> is ticked. After you have selected the refresh rate you wish click <b>OK</b>. It would be a very good idea if you have the user's manual for the monitor handy just so that you can see what the manufacturer suggests the refresh rate should be set to.
on May 31, 2011 | Computers & Internet
Problem with setting refresh rate.
Most LCD manufacturer recommend 60Hz, all the LCD monitors (close to 100, 2 monitors per work station) at my office are set to native resolution and @60Hz, LCD refresh rate does not work the same as the old style CRT. You can tell by using the digital camera to see if the screen is flickering or not, point the camera at the CRT monitor and you will see the screen will be rolling but not on hte LCD screen. Try this monitor with other PC.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Apr 13, 2010 | Samsung 943NW Monitor
Resolution and refresh rate
1280x1024 native and will go to 75hz x 81khz
I'd probably look more at what your video card supports.
Jan 08, 2010 | Samsung Syncmaster 17" 720N Monitor
How can I change refresh rate on Phillips 190B monitor from a thin client? We are currently set to 75Hz but need to try 60Hz.
If your Operating system is XP , from your desktop , right click => properties => settings => Advanced => Monitor = set your desired refresh rate , then click apply and ok.
Oct 19, 2009 | Philips 190B6CB/27 19" LCD
Monitor flickers
Goes in the config panel, in display section, then the parameter tab, chose advance button.Then usually under the monitor tab, you'll find a refresh rate settings. Try 70hz setting. Also some time not using the protected ''power bar'' and connecting direct to wall helps alot. Let us know!
Oct 10, 2009 | IBM NetVista X41 PC Desktop
Acerview 76e
hi shouldibuyit
resolution 640x480 70Hz
800x600 70Hz
best 1152x 870 75HZ
Max 1280x 1024 60hz
these machines dont usually last long if left running at max refresh rate of 85Hz for long periods
Oct 27, 2008 | AcerView 76E Monitor
Monitor flickers
First check whether you didn’t put the Inverter or UPS or any kind of huge power supply which content the big or higher voltage transformer...
Secondly try the degauss button on the front panel of the monitor…
Third thing is CRT’s power supply section capacitor is leakage so you need to change…
(If you know how to remove the parts from the CRT other wise go to the CRT repairer.)
Dec 06, 2007 | LG Flatron 775FT 17" CRT Monitor
Gateway FPD2275W LCD Monitor Logo
147 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
