Question about Weber 1851001 Gas Grill
Second burner will not ignite on Weber grill
Second burner will not ignite Weber Silver two burner
    Problem Solver:
  • 9 Answers
Its probably an obstruction in the burner. Take both the burners off and clean them inside and out with a brass brush. You need to clean them both, since the second burner is dependent on the first working properly.
Step by step procedures are in your manual. Go to http://weber.com/help/manuals.aspx to download it.
Posted on Aug 12, 2010
My grill is a Genesis Silver B. The front burner ignites but the middle and back burner will not. I took off the tubes and can't see where anything is plugged or restricted. I can hear gas through the...
I believe your model Weber has a Cross Over Tube Burner , on the left side of the interior of the grill, just above the middle and back burner. If that's clogged or needs replacing, that's more than likely the culprit. As, it won't carry gas to those two burners. It is easily replaceable, if necessary.
In case you have misplaced your Owners Manual, I have included a link to it. You can download and print it for future reference.
http://www.weber.com/help/manuals/pdf_files/Genesis_SilverB_LP_Owners_Guide_55008_03_21_01.pdf
Apr 09, 2011 | Weber Genesis Silver B Grill
I thoroughly cleaned my Weber Genesis Silver A and have a full tank of gas. It won't get hotter than 250-300 degrees. Flames are blue.
You might have air block. When turning off the grill, leave one burner on and shut the tank valve.
When grill cools, close the remaining valve. When restarting the grill, open the tank valve, then the start burner, then the igniter. When first burner is going, open remaining two valves to preheat the grill.
This has worked on two different grills.
Dec 30, 2010 | Weber Genesis Silver A Grill
The second burner on my weber grill makes a humming sound.
Sometimes, under specific atmospheric conditions, the regulator will hum. This is not a problem in most cases, but if you put on a new regulator and hose it may correct the problem.
Jul 07, 2010 | Weber Genesis Silver B Grill
How do I take my Weber Genesis grill apart to clean the burners? The burners are not heating up properly. The flame is very poor and not hot enough to cook food.
Turn on just one burner, once it is lit, turn on a second burner, if the flame gets lower or goes out, you probably need a new regulator.
Dec 03, 2009 | Weber Genesis Silver A Grill
Second burner will not light
I don['t know the answer but I have the identical problem. 1st & 3rd burner lights but little if any gas getting to second burner. Might be blockage. How do you disassemble burners to clean?
Oct 11, 2009 | Weber Genesis Silver B Grill
I just replaced some parts on weber silver; however, one of the wires from the ignition got loose. Where do I attach the wire?
there are two spots on the push button part one on the bottom and one on the side there are also two next to the grill beside the first burner
Sep 02, 2009 | Weber Genesis Silver B Grill
My silver c igniter does not work..need to manually light..burners work..is new igniter worth pruchase? grill is almost 6 years old
yes replace it. you can call weber and they will send you one FREE just tell them whats wrong and the model number of the grill
Jul 18, 2009 | Weber Genesis Silver C Grill
Weber 1851001 Gas Grill Logo
355 people viewed this question
Top Weber Grilling Experts
paulcarew
Dan Webster
Dan Webster
Treefrog15
Treefrog15
Are you a Weber Grilling Expert? Answer questions, earn points and help others
